Unsolved Firmware downgrade
And when sliced with absolute extrusion it works fine?
@Phaedrux said in Firmware downgrade:
Yes. I stopped printing after 2 successful layers.
M122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.2 running on Duet 3 MB6HC v1.01 or later (SBC mode) Board ID: 08DJM-956BA-NA3TJ-6J9D8-3SN6T-1AAYV Used output buffers: 1 of 40 (11 max) === RTOS === Static ram: 149788 Dynamic ram: 63740 of which 92 recycled Never used RAM 145212, free system stack 128 words Tasks: Linux(ready,83) HEAT(blocked,296) CanReceiv(blocked,834) CanSender(blocked,344) CanClock(blocked,352) TMC(blocked,19) MAIN(running,705) IDLE(ready,19) Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:05:12 ago, cause: power up Last software reset at 2021-01-22 22:12, reason: User, GCodes spinning, available RAM 145212, slot 2 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task Linu Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Aux1 errors 0,0,0 MCU temperature: min 27.9, current 34.7, max 35.1 Supply voltage: min 24.0, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.2, current 12.2, max 12.3, under voltage events: 0 Driver 0: position 52000, standstill, reads 31010, writes 27 timeouts 0, SG min/max 0/1023 Driver 1: position -50400, standstill, reads 31011, writes 27 timeouts 0, SG min/max 0/1023 Driver 2: position 12453, standstill, reads 31006, writes 32 timeouts 0, SG min/max 0/1023 Driver 3: position 0, standstill, reads 31006, writes 32 timeouts 0, SG min/max 0/1023 Driver 4: position 0, standstill, reads 31006, writes 32 timeouts 0, SG min/max 0/1023 Driver 5: position 0, standstill, reads 31006, writes 32 timeouts 0, SG min/max 0/1023 Date/time: 2021-01-22 22:17:38 Slowest loop: 164.33ms; fastest: 0.04ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 125, maxWait 107133ms, bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves 671, completed moves 671, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 2], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 0 is on, I-accum = 0.0 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File* is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue* is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === CAN === Messages queued 1655, send timeouts 0, received 3629, lost 0, longest wait 2ms for reply type 6049, free buffers 48 === SBC interface === State: 4, failed transfers: 0 Last transfer: 1ms ago RX/TX seq numbers: 10758/10758 SPI underruns 0, overruns 0 Number of disconnects: 0, IAP RAM available 0x2c8a8 Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v3.2.0 Code buffer space: 4096 Configured SPI speed: 8000000 Hz Full transfers per second: 9.49 Maximum length of RX/TX data transfers: 2816/1480
M122 B121 Diagnostics for board 121: Duet TOOL1LC firmware version 3.2 (2021-01-05) Bootloader ID: not available Never used RAM 4032, free system stack 50 words HEAT 90 CanAsync 89 CanRecv 83 TMC 54 MAIN 218 AIN 64 Last reset 00:06:01 ago, cause: power up Last software reset data not available Driver 0: position 60224, 415.0 steps/mm, standstill, SG min/max 0/304, read errors 0, write errors 0, ifcnt 14, reads 49787, writes 14, timeouts 0, DMA errors 0 Moves scheduled 374, completed 374, in progress 0, hiccups 0 No step interrupt scheduled VIN: 24.1V MCU temperature: min 48.8C, current 52.6C, max 54.6C Ticks since heat task active 32, ADC conversions started 360855, completed 360854, timed out 0 Last sensors broadcast 0x00000002 found 1 35 ticks ago, loop time 0 CAN messages queued 4238, send timeouts 0, received 3670, lost 0, free buffers 36
Can you share these macros?
; Velocity, acceleration, and current settings are in these macros
M98 P"/macros/Drive/xy_fullcurrent.g"
M98 P"/macros/Drive/z_fullcurrent.g"
M98 P"/macros/Drive/e_fullcurrent.g" -
Thanks.
Very strange.
Will take a look.
Just found out another thing. In spite of successful print, if I start printing the same job right after finished one the first layer becomes a mess. But if I restart printer by switching the power off an on the model is being printed with no issues.
M122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.2 running on Duet 3 MB6HC v1.01 or later (SBC mode) Board ID: 08DJM-956BA-NA3TJ-6J9D8-3SN6T-1AAYV Used output buffers: 1 of 40 (12 max) === RTOS === Static ram: 149788 Dynamic ram: 63740 of which 168 recycled Never used RAM 145136, free system stack 126 words Tasks: Linux(ready,83) HEAT(blocked,296) CanReceiv(blocked,809) CanSender(blocked,335) CanClock(blocked,352) TMC(blocked,19) MAIN(running,717) IDLE(ready,19) Owned mutexes: HTTP(MAIN) === Platform === Last reset 01:28:13 ago, cause: power up Last software reset at 2021-01-22 22:12, reason: User, GCodes spinning, available RAM 145212, slot 2 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task Linu Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Aux1 errors 0,0,0 MCU temperature: min 27.3, current 37.9, max 38.0 Supply voltage: min 24.0, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.2, current 12.3, max 12.3, under voltage events: 0 Driver 0: position 52000, standstill, reads 14513, writes 31 timeouts 0, SG min/max 0/1023 Driver 1: position -50400, standstill, reads 14512, writes 32 timeouts 0, SG min/max 0/1023 Driver 2: position 12153, standstill, reads 14498, writes 46 timeouts 0, SG min/max 0/1021 Driver 3: position 0, standstill, reads 14498, writes 46 timeouts 0, SG min/max 0/1023 Driver 4: position 0, standstill, reads 14498, writes 46 timeouts 0, SG min/max 0/1023 Driver 5: position 0, standstill, reads 14499, writes 46 timeouts 0, SG min/max 0/1023 Date/time: 2021-01-23 19:26:43 Slowest loop: 175.45ms; fastest: 0.04ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 125, maxWait 134829ms, bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves 4010, completed moves 4010, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 4], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 0 is on, I-accum = 0.0 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File* is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue* is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === CAN === Messages queued 235551, send timeouts 0, received 63653, lost 0, longest wait 2ms for reply type 6031, free buffers 48 === SBC interface === State: 4, failed transfers: 0 Last transfer: 1ms ago RX/TX seq numbers: 1465/1465 SPI underruns 0, overruns 0 Number of disconnects: 0, IAP RAM available 0x2c8a8 Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v3.2.0 Code buffer space: 4096 Configured SPI speed: 8000000 Hz Full transfers per second: 48.83 Maximum length of RX/TX data transfers: 2880/1684
M122 B121 Diagnostics for board 121: Duet TOOL1LC firmware version 3.2 (2021-01-05) Bootloader ID: not available Never used RAM 4032, free system stack 50 words HEAT 86 CanAsync 89 CanRecv 83 TMC 54 MAIN 218 AIN 64 Last reset 01:28:35 ago, cause: power up Last software reset data not available Driver 0: position 2810351, 415.0 steps/mm, standstill, SG min/max 0/112, read errors 0, write errors 0, ifcnt 16, reads 36525, writes 16, timeouts 0, DMA errors 0 Moves scheduled 214161, completed 214161, in progress 0, hiccups 0 No step interrupt scheduled VIN: 24.1V MCU temperature: min 56.6C, current 70.4C, max 74.8C Ticks since heat task active 1, ADC conversions started 5294991, completed 5294990, timed out 0 Last sensors broadcast 0x00000002 found 1 5 ticks ago, loop time 0 CAN messages queued 63941, send timeouts 0, received 262230, lost 0, free buffers 36
@dc42 said in Firmware downgrade:
What issues are you having? Right now I can't think of any issues present in firmware 3.2 that are not also present in earlier versions.
Is that some sort of bad joke? This is new in 3.2 as I have repeatedly pointed out.
https://forum.duet3d.com/topic/20756/error-homing-failed-after-upgrade-to-rrf3-2/23
