    Raise Z when outside build area
    • macguyver
      macguyver last edited by macguyver
      Title says it all. Is there a way to make sure that any travel moves outside the main build area raise the Z first to clear clamps/screws?
      fcwilt 1 Reply Last reply Reply Quote 0
      • fcwilt
        fcwilt @macguyver last edited by
        @macguyver said in Raise Z when outside build area:
        That would have to be done in the slicer.
        To avoid collisions you could set the min/max of your axes in your M208 to limit the printable area.
        • macguyver
          The problem with M208 is that I need the nozzle to be able to go outside of the build area to purge and brush the nozzle. I'm probably just going edit the purge, pause, resume macros, but I'd love a way to tell the printer that any moves below 0 on X or Y should raise Z though.
          • fcwilt
            That would seem to make sense since you would have complete control.
            If it was a feature of the firmware how could you brush the nozzle - once moved to the desired location for "brushing" wouldn't moving during the operation trigger raising the nozzle again?
            Thanks.
            macguyver 1 Reply Last reply Reply Quote 0
            • macguyver
              macguyver @fcwilt last edited by
              @fcwilt It's a corexy so the nozzle only moves on X&Y and the brush is on a bracket fixed to the frame.
