    Hotend cooling fan not starting
    • Chriss
      Chriss last edited by
      Hi *,
      I have a problem with my IDEX setup. The cooling fan for the hotend do not start when the hotend reaches 45 °C and I do not find any miss-configuration. Both hotends (tools) have one toolboard 1LC, T0 works as expected, T1 not.
      The fan works when I add 12V to the screw terminals, so the wiring is OK.
      The communication between the Mini5+ and teh toolboards work as expected because the heater, thermistor and endstop work.
      Firmware: 3.2
      ; Configuration file for Duet 3 Mini 5+ (firmware version 3)
      ; generated by RepRapFirmware Configuration Tool v3.2.0 on Thu Dec 31 2020 04:37:36 GMT+0100 (Central European Standard Time)
      M550 P"Marge"                                      ; set printer name
      ;M552 P0.0.0.0 S1                                   ; enable network and acquire dynamic address via DHCP
      M552 S1
      ;; Toolboards
      ;  M115 B121  ;; Show board 121
      ; M997 B121  ;; Update tool 121
      ; M122 B121   ;; Detailed status of toolboard
      G4 S1                                              ;wait for expansion boards to start
      ;; Drives
      ; Z
      M569 P0.0 S0                                       ; physical drive 0.0 goes backwards
      M569 P0.4 S0                                       ; physical drive 0.4 goes backwards
      ; Y
      M569 P0.1 S0                                       ; physical drive 0.1 goes forwards
      ; Left and Right tool stepper !!!!TODO!!!!   X U
      M569 P0.2 S1                                       ; physical drive 0.2 goes forwards  X
      M569 P0.3 S1                                       ; physical drive 0.3 goes forwards  U
      ; Extruder steppers !!!!TODO!!!!
      M569 P121.0 S1                                     ; physical drive 121.0 goes forwards  X
      M569 P122.0 S1                                     ; physical drive 122.0 goes forwards  U
      M584 X0.3 U0.2 Y0.1 Z0.0:0.4 E121.0:122.0                 ; set drive mapping
      M350 X16 U16 Y16 Z16 E16:16 I1                            ; configure microstepping with interpolation
      M92 X160.00 U160.00 Y161.20 Z800.00 E420.00:420.00        ; set steps per mm
      ;M92 X80.00 Y80.60 Z403.02 E805                           ; set steps per mm from RatRig
      M566 X900.00 U900.00 Y900.00 Z60.00 E120.00:120.00        ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 U6000.00 Y6000.00 Z1000.00 E1200.00:1200.00 ; set maximum speeds (mm/min)  Z180
      M201 X500.00 U500.00 Y500.00 Z20.00 E250.00:250.00        ; set accelerations (mm/s^2)
      M906 X800 U800 Y800 Z800 E800:800 I30                     ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                                   ; Set idle timeout
      ; Z-level settings
      M671 X-31.5:300.3 Y120:102 S30                     ; Position of the leadscrews :: Snn Maximum correction
      M208 X0 U100 Y0 Z0 S1                              ; set axis minima
      M208 X230 U300 Y300 Z200 S0                        ; set axis maxima
      ; Endstops -- Display status with: M119
      M574 X1 S1 P"121.io2.in"                           ; configure active-high endstop for low end on X via pin io0.in
      M574 U2 S1 P"122.io2.in"                           ; 2=high end 2=low end
      M574 Y1 S1 P"!0.io0.in"                            ; configure active-high endstop for low end on Y via pin io1.in
      M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
      M950 S0 C"121.io0.out"                             ; create servo pin 0 for BLTouch
      M558 P9 C"^121.io0.in" H5 F120 T6000               ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X0 Y0 Z2.5                                ; set Z probe trigger value, offset and trigger height
      M557 X15:215 Y15:195 S20                           ; define mesh grid
      ;; Heaters :: Tune with: M303 H0 S110
      ; Bed
      M308 S0 P"0.temp0" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"0.out0" T0                               ; create bed heater output on out0 and map it to sensor 0
      M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
      ; Head 1 (left)
      ; Tune in with:  M303 H1 S270
      M308 S1 P"121.temp0" Y"thermistor" T100000 B4138   ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"121.out0" T1                             ; create nozzle heater output on out1 and map it to sensor 1
      ; Head 2 (right)
      M308 S2 P"122.temp0" Y"thermistor" T100000 B4138   ; configure sensor 2 as thermistor on pin temp1
      M950 H2 C"122.out0" T2                             ; create nozzle heater output on out1 and map it to sensor 1
      M307 H2 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
      M143 H2 S280                                       ; set temperature limit for heater 1 to 280C
      ;; Fans
      ; Fan for the printed part left:
      M950 F0 C"121.out1" Q500                           ; create fan 0 on pin 121.out1 and set its frequency
      M106 P0 S0 H-1 C"Part L"                           ; set fan 0 value. Thermostatic control is turned off
      ; Fan for the left hotend
      M950 F1 C"121.out2" Q500                           ; create fan 1 on pin 121.out2 and set its frequency
      M106 P1 S1 H1 T45  C"Hotend L"                     ; set fan 1 value. Thermostatic control is turned on
      ; Fan for the printed part right:
      M950 F2 C"122.out1" Q500                           ; create fan 2 on pin 122.out1 and set its frequency
      M106 P2 S0 H-1 C"Part R"                           ; set fan 2 value. Thermostatic control is turned on
      ; Fan for the right hotend
      M950 F3 C"122.out2" Q500                           ; create fan 3 on pin 122.out2 and set its frequency
      M106 P3 S1 H1 T45 C"Hotend R"                      ; set fan 3 value. Thermostatic control is turned on P=No. S=Speed H=ThermostaticMode
      ;; Tools
      ; Tool 0 aka "the left wing" X
      M563 P0 S"L" D0 H1 F0                              ; define tool 0
      ; Filament sensor
      ;M591 D0 P5 C"121.io0.in" R160:400 E3.0 S0         ; S0 = Disabled
      ; Tool 1 aka "the right wing" U
      M563 P1 S"R" D1 H2 F2 X3                           ; define tool 1 P=No. S=Name D=Extrudor H=Heater F=Fan X=Mapping to X
      ;G10 P1 X0 Y0 Z0                                    ; set tool 1 axis offsets
      ;G10 P1 R0 S0                                       ; set initial tool 1 active and standby temperatures to 0C
      G10 P1 Y0 U0 Z0 S0 R0
      ; Filament sensor
      ;M591 D0 P5 C"122.io0.in" R160:400 E3.0 S0          ; S0 = Disabled
      ;M575 P1 S1 B57600                                  ; enable support for PanelDue
      M501                                               ; load saved parameters from non-volatile memory
      T0                                                 ; select first tool
      ;;;;;;;;;;;;;;;;; DISABLE  protection for testing
      ;M564 S0 H0
      What did I do wrong?
      Cheers, Chriss
      • Veti
        Veti last edited by
        @Chriss said in Hotend cooling fan not starting:
        i assume you want the second heater there H2 not H1
        your thermistor setting is incorrect. find the correct beta value in your thermistor documentation.
        Chriss 1 Reply Last reply Reply Quote 1
        • Chriss
          Chriss @Veti last edited by
          @Veti said in Hotend cooling fan not starting:
          🤦 Thanks.... It is sooo helpfully when a other pair of eyes have a look at a problem. 😉
          Indeed, they are not correct yet. I just added something to get them working somehow. The thermistor settings seems still like witchcraft to me, time to read some documentation.
          Cheers, Chriss
