    Mini5+ "mcu-temp" sensor definition does not work
    Using Duet Controllers
    • oc_geek
      oc_geek last edited by oc_geek
      ; Define MCU sensors which will be available in DWC Extra View
      M308 S3 A"MCU" Y"mcu-temp"
      M308 S4 A"Duet Drivers" Y"drivers"
      For some reason the M308 "mcu-temp" doesn't work - error sensor "mcutemp" does not exist (and yes the "-" is removed in the error message)
      (The drivers one perfectly works)
      Any help please ?
      Does the Mini5+ use a different name for the MCU Temp Sensor ?
      (i saw this same command in the Wiki)
      Thanks
        Can you send M122 and report the results? Should be running fw 3.2 final.
        https://github.com/Duet3D/RepRapFirmware/releases/tag/3.2
        • oc_geek
          Yes i'm on Rel 3.2
          Here is the dump of M122
          1/21/2021, 9:46:46 PM M122
          RepRapFirmware for Duet 3 Mini 5+ version 3.2 running on Duet 3 Mini5plus WiFi (standalone mode)
          Board ID: F8W09-K196U-D65J0-40KM0-LH03Z-Z1XLX
          Used output buffers: 3 of 40 (11 max)
          Static ram: 98732
          Dynamic ram: 113696 of which 92 recycled
          Never used RAM 32696, free system stack 200 words
          Tasks: NETWORK(ready,202) HEAT(blocked,316) CanReceiv(blocked,947) CanSender(blocked,372) CanClock(blocked,363) TMC(blocked,123) MAIN(running,440) IDLE(ready,20) AIN(blocked,267)
          Owned mutexes: WiFi(NETWORK)
          Last reset 00:01:05 ago, cause: power up
          Last software reset at 2021-01-19 23:49, reason: User, GCodes spinning, available RAM 32696, slot 0
          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
          Error status: 0x00
          Aux0 errors 0,0,0
          Aux1 errors 0,0,0
          Supply voltage: min 0.0, current 0.9, max 0.9, under voltage events: 0, over voltage events: 0, power good: no
          Driver 0: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
          Driver 1: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
          Driver 2: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
          Driver 3: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
          Driver 4: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
          Driver 5: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
          Driver 6: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
          Date/time: 2021-01-21 21:46:45
          Cache data hit count 137638723
          Slowest loop: 27.84ms; fastest: 0.12ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 3.8ms, write time 0.0ms, max retries 0
          === MainDDARing ===
          === AuxDDARing ===
          Bed heaters = 0 -1, chamberHeaters = -1 -1
          Heater 1 is on, I-accum = 0.0
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          SBC is idle in state(s) 0
          Daemon is idle in state(s) 0
          Aux2 is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 21.01ms; fastest: 0.00ms
          HTTP sessions: 1 of 8
          • WiFi -
            Network state is active
            WiFi firmware version 1.25
            WiFi MAC address f4:cf:a2:6f:e9:87
            WiFi Vcc 3.46, reset reason Power up
            WiFi flash size 2097152, free heap 25104
            WiFi IP address 10.0.0.7
            WiFi signal strength -58dBm, mode 802.11n, reconnections 0, sleep mode modem
            Clock register 00002002
            === CAN ===
            Messages queued 585, send timeouts 583, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 16
            dc42 administrators @oc_geek last edited by dc42
            @oc_geek said in Mini5+ "mcu-temp" sensor definition does not work:
            Unfortunately the SAME54P20A chip used in the Duet 3 Mini does not have a functioning temperature sensor. In theory it does have an on-chip temperature sensor, but the errata document for the chip says it doesn't work. Microchip has told me that they don't expect to fix this in a new revision of the chip any time soon.
            • oc_geek
              ok that explains a lot, thanks !
              Perhaps worth to mention it in the docs so others will know as well
                I'll add a note to the documentation.
