New firmware issue - temp not reading
hi,
So just updated my duet pi and the temp on the web interface isnt displaying and only show n/a. Here is a screenshot.
Im using firmware 3.2 on pi+duet3 and Im using a tool board which looks to be connected.
; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Duet 3" ; set printer name ; Drives M569 P0.1 S1 ; physical drive 0.1 goes forwards M569 P0.0 S0 ; physical drive 0.0 goes forwards M569 P0.2 S0 ; physical drive 0.2 goes forwards M569 P0.3 S0 ; physical drive 0.3 goes forwards M569 P0.4 S0 ; physical drive 0.3 goes forwards M569 P20.0 S1 ; physical drive 0.3 goes forwards M584 X0.1 Y0:4 Z2:3 E20.0 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X3200.00 Y3200.00 Z3200.00 E873.00 ; set steps per mm M566 X490.00 Y490.00 Z5.00 E1000.00 ; set maximum instantaneous speed changes (mm/min) M203 X1500.00 Y1500.00 Z70.00 E5000.00 ; set maximum speeds (mm/min) M201 X120.00 Y120.00 Z5.00 E5000.00 ; set accelerations (mm/s^2) M906 X3900 Y3900 Z1800 E1300 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; s9t axis minima M208 X890 Y925 Z780 S0 ; set axis maxima ; Endstops M574 X1 S1 P"io0.in" ; configure active-high endstop for low end on X via pin !io8.in M574 Y1 S1 P"io1.in" ; configure active-high endstop for low end on Y via pin !io2.in M574 Z0 S1 ; configure Z-probe endstop for low end on Z ; Z-Probe M558 P8 C"20.io0.in" H5 F90 T100000 ; set Z probe type to unmodulated and the dive height + speeds G31 P500 X0 Y0 Z0.1 ; set Z probe trigger value, offset and trigger height M557 X0:885 Y0:985 S80 ; define mesh grid ; Heaters M308 S0 P"20.temp0" Y"pt1000" ; configure sensor 0 as thermistor on pin 20.temp0 M950 H0 C"20.out0" T0 ; create nozzle heater output on 20.out0 and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit ;M308 S1 P"temp0" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin temp0 ;M950 H1 C"out0" T1 ; create bed heater output on out0 and map it to sensor 1 ;M307 H1 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit ;M140 H1 ; map heated bed to heater 1 ;M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"out8" Q500 ; create fan 0 on pin out8 and set its frequency M106 P0 S0 H0 T45 ; set fan 0 value. Thermostatic control is turned on M950 F1 C"out9" Q500 ; create fan 1 on pin out9 and set its frequency M106 P1 S0 H0 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 S"Titan Aqua 1.75" D0 H0 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined
Can you send M122 B1 to check if the firmware on the toolboard also got updated? If not, send M997 B1 to update it.
ok thanks i thought i just had to do one single update after sending the sudo apt-get update and sudo ad-get upgrade. well, problem is fixed.
