    UNSOLVED Tool board Failure during Print
    89
    • Turricann
      Turricann last edited by Turricann
      During my Last Print approx 2h in the print failed after a reset i have lost all comms to the toolboard,
      I have disconnected everything except power and comms,
      looking for ideas to whats gone wrong.
      Turricann 1 Reply Last reply Reply Quote 0
      • Turricann
        Turricann @Turricann last edited by
        @Turricann said in Tool board Failure during Print:
        Well found the Issue the driver on the tool board has a hole in it.
          Ouch. That's a big crater. Any idea what might have gone wrong? Shorts? Anything else damaged?
          Otherwise...
          Can you provide some more details?
          What's your hardware? SBC mode?
          Firmware version?
          config.g?
          • Turricann
            No Connected everything except motor to duet and it works fine. checked motor wiring with meter and all seems ok . Blue led and red led lit solid on tool board but no comms and does nothing if you try to reset the tool board oh and hotend cooling fan come on as expected.
            The board had been working perfectly been used for the last two weeks printing upgrades for my printer.
            Current Firmware RRF3.2
            System setup Pi3 to Duet 3 6hc connected to tool board,
            Config.g
            G21 ; Work in millimetres
            M550 P"Duet 3" ; set printer name
            M669 K1 ; select CoreXY mode
            M569 P0.0 S0 ; Duet 3 physical drive 0.0 goes backwards (X)
            M569 P0.1 S1 ; Duet 3 physical drive 0.1 goes backwards (Y)
            ;M584 P0.2 S0 ; Empty Header for Extruder Motor.
            M569 P0.3 S0 ; Duet 3 physical drive 0.3 goes backwards (Z1 Right Middle Motor)
            M569 P0.4 S0 ; Duet 3 physical drive 0.4 goes backwards (Z2 Front left Motor)
            M569 P0.5 S0 ; Duet 3 physical drive 0.5 goes backwards (Z3 Back Left Motor)
            M569 P20.0 S0
            M584 X0.0 Y0.1 Z0.3:0.4:0.5 ; 3 * Z motors connected to 0.3 (Right Middle), 0.4 (Front left), 0.5 (Back Left Motor) Need to keep in this order to match lead screw postions.
            M584 E20.0 ; set drive mapping -- tool board
            M92 X160.00 Y160.00 Z1600.00 E839.86 ; set steps per mm M92 Z400 for 1.8º degree steppers and M92 X160 Y160 for 0.9º (calculated extruder 839.86)
            M671 X205:-205:-205 Y0:-205:205 S20 ; Bed Pivot points Where kinnermatic mounts are located the Actual leadscrews Positions @ Right middle (X245 Y30),Front left (X-245 Y-173), left Rear (X-245 Y-225) (Sxx = tollerance ie 20mm)
            M566 X600.00 Y600.00 Z360.00 E600.00 P1 ; set maximum instantaneous speed changes (mm/min)
            M203 X6000.00 Y6000.00 Z600.00 E1200.00 ; set maximum speeds (mm/min)
            M201 X3000.00 Y3000.00 Z120.00 E120.00 ; set accelerations (mm/s^2)
            M906 X900 Y900 Z900 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
            ;M593 F34.2 <---- look into. ; cancel ringing at 34.2Hz
            M84 S30 ; Set idle timeout
            M208 X-195 Y-195 Z0 S1 ; set axis minima
            M208 X200 Y200 Z450 S0 ; set axis maxima
            M574 X1 S3 ; configure sensorless endstop for high end on X
            M574 Y1 S3 ; configure sensorless endstop for high end on Y
            M558 P8 C"^20.io0.in" I1 H10 F500 T6000 ; Toolboard P8 Z probe mode for ToolBoard, Prusa PindaV2 sensor config.(F= Bed speed to probe.) (H= distance bed moves during probing) ( S= tollerance) (p= probe type)
            M308 S2 P"20.temp1" A"Pinda V2" Y"thermistor" A20 T100000 B3950 ; Toolboard, Prusa PindaV2 temperature config.
            G31 P500 X-30 Y15 Z0.235 ; set Z probe trigger value, offset and trigger height
            M557 X-180:180 Y-170:170 S42 ; define mesh grid
            ; Bed Heaters
            M308 S0 P"temp0" Y"thermistor" T100000 B3950K ; configure sensor 0 as thermistor on pin temp0
            ; Hotend Heaters
            M308 S1 P"20.temp0" Y"PT1000" ; Toolboard configure sensor 0 as a PY1000 thermistor on pin temp0
            M950 H1 C"20.out0" T1 ; Toolboard create nozzle heater output on out1 and map it to sensor 1
            M143 H1 S301 ; set temperature limit for heater 1 to 301C
            M950 F0 C"20.out1" ;Toolboard create fan 0 on pin out1 and set its frequency
            M106 P0 S0 H-1 Q500 ; set fan 0 value. Thermostatic control is turned off
            M950 F1 C"20.out2" Q500 ; Toolboard Partcooling Fan1 on pin out2 and set its frequency
            M950 F2 C"out7" Q500 ; Toolboard Partcooling Fan1 on pin out2 and set its frequency
            M106 P1 S1 H1 T25 ; set fan 1 value. Thermostatic control is turned on
            M563 P0 S"HOTEND" D0 H1 F0 ; define tool 0
            G10 P0 X-9 Y-13 Z0 ; set tool 0 axis offsets from bed center.
            ;Custom settings are not defined
            ; Retract
            ;M207 P0 S1.8 F2400 Z0.3
            T0 ; select first tool
              So this was a brand new tool board that had been working otherwise fine?
              • Turricann
                5 weeks old, yep printed quite a few things used about 1/2 a roll of PETG and was just finishing a E3D Hemera mount when it failed.
                  This is the first time I've heard of a TMC2209 failing in a Duet3D product. I authorise a warranty replacement of this tool board. Please contact your supplier.
                  • Turricann
                    Turricann @dc42 last edited by
                    @dc42 Thanks I have contacted ooznest who was the supplier.
