    heatbed rebel FRW 3.2
    • Pillcciaundefined
      Pillccia
      Hello
      I have a problem with the heatbed. after several autopid (m303) and data readings, save and reset.
      insists on not functioning normally.
      I went from megatronic where it worked, with duet I have a time / c ° error.
      the plate is 8mm aluminum + 5mm glass.
      My config.g is:
      ; generated by RepRapFirmware Configuration Tool v3.2.2 on Wed Jan 20 2021 20:48:08 GMT+0100 (Ora standard dell’Europa centrale)
      M550 P"Bad Printer 2 (3.2)" ; set printer name
      M669 K1 ; select CoreXY mode
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P4 S0 ; physical drive 4 goes backwards
      M584 X0 Y1 Z2 E3:4 ; set drive mapping
      M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
      M92 X81.00 Y81.00 Z1600.00 E94.00:94.00 ; set steps per mm
      M566 X900.00 Y900.00 Z300.00 E300.00:300.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X12000.00 Y12000.00 Z600.00 E6000.00:6000.00 ; set maximum speeds (mm/min)
      M201 X1500.00 Y1500.00 Z100.00 E10000.00:10000.00 ; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000 E1000:1000 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S180 ; Set idle timeout
      M208 X-26 Y-12 Z0 S1 ; set axis minima
      M208 X235 Y225 Z215 S0 ; set axis maxima
      M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop
      M558 P0 H10 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
      M557 X10:200 Y10:200 S40 ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 R4700 ; configure sensor 0 as thermistor on pin bedtemp
      M143 H0 S100 ; set temperature limit for heater 0 to 100C
      M143 H1 S285 ; set temperature limit for heater 1 to 285
      C
      M308 S2 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 2 as thermistor on pin e1temp
      M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
      M
      307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
      M143 H2 S285 ; set temperature limit for heater 2 to 285C
      M106 P0 C"testa" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
      M106 P1 C" cpu" S0 H0 T40 ; set fan 1 name and value. Thermostatic control is turned on
      M563 P0 S"hot end 0" D0 H1 F0 ; define tool 0
      M563 P1 S"hot end 1" D1 H2 F0 ; define tool 1
      G10 P1 X0 Y26 Z0 ; set tool 1 axis offsets
      G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
      M501
      ; Custom settings
      override.g
      M122 ; stop emergenza esterno
      M591 ; rilevamento filo inceppato
      M500 ; salva eprom
      M581 ; configurazione del trigger esterno
      M555 ; imposta compatibilità
      M501 ; legge i parametri memorizzati
      M70 ; caricamento del filamento
      M70 ; scaricare il filamento
      M90 ; Imposta data e ora locali
      M911 S10 R11 P" M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
        Phaedrux Moderator @Pillccia
        @Pillccia said in heatbed rebel FRW 3.2:
        M500 ; salva eprom
        Don't put M500 in config.g. It's only used immediately after tuning is finished to save the results. Send it from the console.
        Only put M501 in config.g once.
        Pillcciaundefined 1 Reply Last reply Reply Quote 0
        • Pillcciaundefined
          Pillccia @Phaedrux
          @Phaedrux
          i uploaded frw 2.05.
          now the bed, and the rest, works, done autotuning of all the heaters, and the next step is to do the first test pieces, to see the last calibrations.
          • deckingmanundefined
            deckingman @Pillccia
            @Pillccia There are no PID parameters anywhere in either your config.g or your config_overide.g files. You've got M307 B0 to disable bang-bang mode but you haven't put the result of the M303 tuning parameters in your config.g file, nor have you saved the result to config_overide (according to the information that you've posted).
            • Pillcciaundefined
              Pillccia
              Hello and thanks
              But I didn't understand which line I have to write in config.g, M307 vp13,4 10950 d51,5?
              Exact
                No.
                In the console send M303 H0 S60 to tune the bed.
                Wait for it to finish.
                Then send M303 H1 S200 to tune the hotend.
                Then send M500 to save the results.
                Then add M501 to the end of config.g.
                That's it.
