    IR sensor troubles, hotend fan not running too
    IR Height Sensor
    • knutselsmurfundefined
      knutselsmurf
      I am testing the IR-sensor, it works but I can't print..
      2 issues:
      1. after calibrating (using the method from https://miscsolutions.wordpress.com/mini-height-sensor-board/, I started a testprint. When it starts the bed is raised too high: the melted filament can't get out the hotend and after some time the tube-clamp is pushed out the top of the hotend.
      2. something else: when the hotend is heated up, the hotend FAN is not running: I can start it by moving the fan-slider in the duet browser panel, but that is not what we want ofcourse.
      Below my configuration, I have used the webbased configtool but it looks it's not making the right configuration (ofcourse, I loaded the zip-file when it was ready with the configuration..)
      Maybe the IR-sensor is not a good idea to use ? (I have the orginal dc24).
      I hope somebody can help.
      Many thanks in advance!
      Regards,
      😉 Arthur
      code_text
      ; generated by RepRapFirmware Configuration Tool v3.2.2 on Sun Jan 24 2021 16:39:46 GMT+0100 (Midden-Europese standaardtijd)
      M550 P"BLV mgn Cube" ; set printer name
      M669 K1 ; select CoreXY mode
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S1 ; enable FTP
      M586 P2 S0 ; disable Telnet
      M569 P4 S1 ; physical drive 4 goes forwards
      M584 X0 Y1 Z2 E3:4 ; set drive mapping
      M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
      M92 X200.00 Y200.00 Z400.00 E420.00:420.00 ; set steps per mm
      M566 X720.00 Y720.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z1500.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z250.00 E1000.00:1000.00 ; set accelerations (mm/s^2)
      M906 X1600 Y1600 Z1600 E1200:1200 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X0 Y5 Z0 S1 ; set axis minima
      M208 X345 Y350 Z640 S0 ; set axis maxima
      M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X-2 Y-16.4 Z1.398 ; set Z probe trigger value, offset and trigger height
      M557 X40:320 Y40:320 S50 ; define mesh grid
      M143 H0 S100 ; set temperature limit for heater 0 to 100C
      M308 S1 P"e0temp" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin e0temp
      M143 H1 S260 ; set temperature limit for heater 1 to 260C
      M106 P0 C"BED-FANS" S0 H0 T55 ; set fan 0 name and value. Thermostatic control is turned on
      M106 P1 C"HOTEND-FAN" S0.5 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on
      M106 P2 C"HOTEND-FAN" S0.5 H1 T45 ; set fan 2 name and value. Thermostatic control is turned on
      M563 P0 S"Extruder0" D1 H1 F1:0 ; define tool 0
      M563 P1 S"Extruder1" D0 H1 F1:0 ; define tool 1
      G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
      G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
      T0 ; select first tool
      code_text
      • Vetiundefined
        Veti
        @knutselsmurf said in IR sensor troubles, hotend fan not running too:
        adjust with babystepping until its fine. then apply the babystepping to the offset.
        what firmware version are you running?
        also you dont have a part fan configured. all your fans are Thermostatic control
