    Compensation and calibration issues
    52
    • Tpmoses
      Tpmoses last edited by
      Hello all,
      I am working on a large format printer 1100x1100x1100 build volume, and when I tell the printer to either true bed level or to do mesh compensation it only runs on a small section of the build plate. I have redefined the mesh calibration area, however when run it says that it cannot reach points and skips them only to go back to the same small area on the build plate. Any help would be much appreciated.
      thanks,
      T
      • Tpmoses
        Here is what the consul says when one of the calibrations are run.
        	G32
        Warning: Skipping grid point (100.0, 100.0) because Z probe cannot reach it
        Warning: Skipping grid point (200.0, 100.0) because Z probe cannot reach it
        Warning: Skipping grid point (300.0, 100.0) because Z probe cannot reach it
        Warning: Skipping grid point (400.0, 100.0) because Z probe cannot reach it
        Warning: Skipping grid point (500.0, 100.0) because Z probe cannot reach it
        Warning: Skipping grid point (600.0, 100.0) because Z probe cannot reach it
        Warning: Skipping grid point (700.0, 100.0) because Z probe cannot reach it
        Warning: Skipping grid point (800.0, 100.0) because Z probe cannot reach it
        Warning: Skipping grid point (900.0, 100.0) because Z probe cannot reach it
        Warning: Skipping grid point (1000.0, 100.0) because Z probe cannot reach it
        Warning: Skipping grid point (1100.0, 100.0) because Z probe cannot reach it
        Warning: Skipping grid point (1100.0, 200.0) because Z probe cannot reach it
        Warning: Skipping grid point (1000.0, 200.0) because Z probe cannot reach it
        Warning: Skipping grid point (900.0, 200.0) because Z probe cannot reach it
        Warning: Skipping grid point (800.0, 200.0) because Z probe cannot reach it
        Warning: Skipping grid point (700.0, 200.0) because Z probe cannot reach it
        Warning: Skipping grid point (600.0, 200.0) because Z probe cannot reach it
        Warning: Skipping grid point (500.0, 200.0) because Z probe cannot reach it
        Warning: Skipping grid point (400.0, 200.0) because Z probe cannot reach it
        Warning: Skipping grid point (300.0, 200.0) because Z probe cannot reach it
        Warning: Skipping grid point (200.0, 200.0) because Z probe cannot reach it
        Warning: Skipping grid point (100.0, 200.0) because Z probe cannot reach it
        Warning: Skipping grid point (100.0, 300.0) because Z probe cannot reach it
        Warning: Skipping grid point (200.0, 300.0) because Z probe cannot reach it
        Warning: Skipping grid point (300.0, 300.0) because Z probe cannot reach it
        Warning: Skipping grid point (400.0, 300.0) because Z probe cannot reach it
        Warning: Skipping grid point (500.0, 300.0) because Z probe cannot reach it
        Warning: Skipping grid point (600.0, 300.0) because Z probe cannot reach it
        Warning: Skipping grid point (700.0, 300.0) because Z probe cannot reach it
        Warning: Skipping grid point (800.0, 300.0) because Z probe cannot reach it
        Warning: Skipping grid point (900.0, 300.0) because Z probe cannot reach it
        Warning: Skipping grid point (1000.0, 300.0) because Z probe cannot reach it
        Warning: Skipping grid point (1100.0, 300.0) because Z probe cannot reach it
        Warning: Skipping grid point (1100.0, 400.0) because Z probe cannot reach it
        Warning: Skipping grid point (1000.0, 400.0) because Z probe cannot reach it
        Warning: Skipping grid point (900.0, 400.0) because Z probe cannot reach it
        Warning: Skipping grid point (800.0, 400.0) because Z probe cannot reach it
        Warning: Skipping grid point (700.0, 400.0) because Z probe cannot reach it
        Warning: Skipping grid point (600.0, 400.0) because Z probe cannot reach it
        Warning: Skipping grid point (500.0, 400.0) because Z probe cannot reach it
        Warning: Skipping grid point (400.0, 400.0) because Z probe cannot reach it
        Warning: Skipping grid point (300.0, 400.0) because Z probe cannot reach it
        Warning: Skipping grid point (200.0, 400.0) because Z probe cannot reach it
        Warning: Skipping grid point (100.0, 400.0) because Z probe cannot reach it
        Warning: Skipping grid point (100.0, 500.0) because Z probe cannot reach it
        Warning: Skipping grid point (200.0, 500.0) because Z probe cannot reach it
        Warning: Skipping grid point (300.0, 500.0) because Z probe cannot reach it
        Warning: Skipping grid point (400.0, 500.0) because Z probe cannot reach it
        Warning: Skipping grid point (500.0, 500.0) because Z probe cannot reach it
        Warning: Skipping grid point (600.0, 500.0) because Z probe cannot reach it
        Warning: Skipping grid point (700.0, 500.0) because Z probe cannot reach it
        Warning: Skipping grid point (800.0, 500.0) because Z probe cannot reach it
        Warning: Skipping grid point (900.0, 500.0) because Z probe cannot reach it
        Warning: Skipping grid point (1000.0, 500.0) because Z probe cannot reach it
        Warning: Skipping grid point (1100.0, 500.0) because Z probe cannot reach it
        • Veti
          Veti last edited by
          as always post your config.g
          • Tpmoses
            Here is my config.g
            ; generated by RepRapFirmware Configuration Tool v3.2.2 on Fri Jan 22 2021 11:13:01 GMT-0600 (Central Standard Time)
            M550 P"Caymas 3D Printer"                          ; set printer name
            M569 P8 R1 T2.5:2.5:5:5 S0                                         ; physical drive 8 goes forwards
            M569 P6 R1 T2.5:2.5:5:5 S1                                         ; physical drive 6 goes forwards
            M569 P2 S0                                         ; physical drive 2 goes forwards
            M569 P5 R1 T2.5:2.5:5:5 S1                                         ; physical drive 5 goes forwards
            M584 X6 Y8 Z2 E5                                   ; set drive mapping
            M92 X320.00 Y320.00 Z640.00 E40.00                 ; set steps per mm
            M566 X200.00 Y200.00 Z12.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
            M203 X3000.00 Y3000.00 Z3400.00 E4000.00            ; set maximum speeds (mm/min)
            M201 X200.00 Y200.00 Z12.00 E250.00                ; set accelerations (mm/s^2)
            M906 X2000 Y2000 Z2800 E800 I30                    ; set motor currents (mA) and motor idle factor in per cent
            M208 X1100 Y1100 Z1100 S0                          ; set axis maxima
            M574 X1 S1 P"!xstop"                                ; configure active-low endstop for low end on X via pin xstop
            M574 Y1 S1 P"!ystop"                                ; configure active-low endstop for low end on Y via pin ystop
            M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
            M558 P1 C"zprobe.in+zprobe.mod" H5 F240 T3600      ; set Z probe type to unmodulated and the dive height + speeds
            G31 P500 X570 Y570 Z1.8                            ; set Z probe trigger value, offset and trigger height
            M557 X100:1100 Y100:1100 S100                      ; define mesh grid
            M308 S0 P"spi.cs1" Y"thermocouple-max31856"        ; configure sensor 0 as thermocouple on pin bedtemp
            M307 H0 B0 S1.00    							   ; disable bang-bang mode for the bed heater and set PWM limit
            M303 H0 S60										   ;Tune for 60C
            M308 S1 P"spi.cs2" Y"thermocouple-max31856"        ; configure sensor 1 as thermistor on pin e0temp
            M303 H1 S200									   ;Tune for 200c
            M500
            M143 H1 S320                                       ; set temperature limit for heater 1 to 320C
            M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
            M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
            M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
            M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
            M575 P1 S1 B57600                                  ; enable support for PanelDue
            M501
            • jay_s_uk
              jay_s_uk last edited by
              In the G31, is your probe really 570mm away from your nozzle in X and Y?
              Owns various duet boards and is the main wiki maintainer for the Teamgloomy LPC/STM32 port of RRF
              Tpmoses 1 Reply Last reply Reply Quote 0
              • Tpmoses
                Tpmoses @jay_s_uk last edited by
                @jay_s_uk ah, no. Those are values generated by RRF configurator, will adjust those values.
                Veti jay_s_uk 2 Replies Last reply Reply Quote 1
                • Veti
                  Veti @Tpmoses last edited by
                  @Tpmoses said in Compensation and calibration issues:
                  the default in the configurator for the values are 0
                  • jay_s_uk
                    jay_s_uk @Tpmoses last edited by
                    @Tpmoses
                    Once you've set those, the majority of your issues should go.
                    Just remember that you need to consider the offset in M557 as its not taken into account.
                    e.g. if your probe is 50mm to the left of your nozzle, it won't be able to reach the last 50mm of your bed on the right unless nozzle can go off by 50mm (and the M208 maxima reflects this)
