    Trouble using endstop exp_e3
    • Sphyloid
      Sphyloid last edited by
      When I ground this pin the endstop is not triggered when switch is closed.
      When I apply 3.3v it triggers the endstop but sometimes it stays triggered for just long enough after the switch is opened that the 2nd pass of homing is triggered too leaving my idex 5mm out of sync.
      Connecting the endstop to E1 resolved the issue but now I have no filament sensor :(.
      How does the duex handle endstop input.
      • fcwilt
        fcwilt last edited by
        What does your M574 command look like?
        Thanks.
          You could add a G4 delay after the back off move.
          What Duet?
          What firmware?
          Post your config.g and homeall
          Post the results of M122 and M98 P"config.g"
