    Question/Suggestion about current manual delta calibration process
    • fcwiltundefined
      fcwilt
      I am currently working without a Z-probe so am using the manual method as available in the most recent firmware 1.19 RC1.
      It works well.
      However I am using "mag ball" mounts for my effector plates and for manual calibration I swap in a plate with a dial indicator mounted on it. This indicator is accurate to 0.0005".
      When doing the manual calibration the up/down Z increments are 0.10 mm which is about 0.0040".
      Would it be possible to add two addition up/down buttons with 0.01mm increments?
      If so, could the manual calibration process benefit from the increased accuracy when it came to getting the dial indicator to read zero?
      Thanks.
      • number40fanundefined
        number40fan
        Command the print head down in small steps until the nozzle just touches the bed or just grips a sheet of paper. You may need to send M564 S0 to allow movement lower than where the firmware thinks Z=0 is. You may also wish to create a macro to lower the head by e.g. 0.02mm to get greater accuracy (G91 followed by G1 Z-0.02).
        Found this in the calibration wiki.
        • fcwiltundefined
          fcwilt
          @number40fan:
          I don't think the current (1.19 firmware) manual calibration routine will allow me to access a macro but I will give it a try.
          The current routine pops up a dialog with a couple of buttons to move up/down by 0.01mm until it just touches the bed.
          That dialog may prevent access to the macros.
          Thanks.
