    Adjusting flow rate via gcode
    • 3DPMicroundefined
      3DPMicro
      I would like to tweak the flow rate at a particular layer similar to grabbing the slider and pulling 5% out but with gcode that I can manually insert or script then cancelling it. Ideas?
      Thanks
      Duet controlled Jet Lathe, scratch built micro mill and 3d printer. 1992 Haas VF2 VMC retrofit
      • fcwiltundefined
        fcwilt
        Check out M221 - "Set extrude factor override percentage"
        • 3DPMicroundefined
          3DPMicro
          Great. Thank you.
