    Failed to start Duet Control Server.
    • Reine
      Reine last edited by
      I just attempted to start my Duet 6CH with a RPi4, but have already run into a problem.
      I've tried both the bundled micro-sd card and also the latest image (light) from the website but both result in the same issue.
      Both are individually powered from separate PSUs.
      What have I missed?
      Jan 27 17:19:48 duet3 systemd[1]: Starting Duet Control Server...
      Jan 27 17:19:49 duet3 DuetControlServer[397]: Duet Control Server v3.2.0
      Jan 27 17:19:49 duet3 DuetControlServer[397]: Written by Christian Hammacher for Duet3D
      Jan 27 17:19:49 duet3 DuetControlServer[397]: Licensed under the terms of the GNU Public License Version 3
      Jan 27 17:19:50 duet3 DuetControlServer[397]: [info] Settings loaded
      Jan 27 17:19:50 duet3 DuetControlServer[397]: [info] Environment initialized
      Jan 27 17:19:51 duet3 DuetControlServer[397]: [fatal] Could not connect to Duet (Timeout while waiting for transfer ready pin)
      Jan 27 17:19:51 duet3 systemd[1]: duetcontrolserver.service: Failed with result 'protocol'.
      Jan 27 17:19:51 duet3 systemd[1]: Failed to start Duet Control Server.
      Jan 27 17:19:51 duet3 systemd[1]: duetcontrolserver.service: Service RestartSec=100ms expired, scheduling restart.
      Jan 27 17:19:51 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 1.
      Jan 27 17:19:51 duet3 systemd[1]: Stopped Duet Control Server.
      • Reine
        I've found the issue. When I picked up the RPi4 today they had a very nicely priced package deal with an RPi4, psu, microsd-card and a case.
        The case seams to be of great quality, the entire top part acts as a passive cpu cooler and is manufactured by a known company.
        https://www.coolermaster.com/catalog/cases/raspberry-pi/pi-case-40/
        It also gives access to all ports from the sides so the gpio port has this 90 degree adapter built in. What wasn't very obvious was the little programmable button they added to it. It seams like the button alters the pins somehow and that was what caused the connection issue to the Duet board.
          Phaedrux Moderator @Reine last edited by Phaedrux
          I noticed that with the Argon Pi4 case as well. The integrated fan and power buttons utilize the GPIO pins and pass them through to the outside of the case with with PCB. Does not work with the Duet. I've added a note to the SBC setup page.
