    Heat spreader idea? Advice please
    My Duet controlled machine
    • Martin_S
      Martin_S last edited by
      Hello fellow makers, I'm in the process of rebuilding my delta. Right now it's a Rostock Max with a lot of upgrades and mods, but I want a really stiff and square machine.
      The bottom plate that will hold the 3 extrusions is going to be of milled aluminum, so I thought of using this as a heat spreader.
      https://c1.staticflickr.com/5/4333/35997018270_bc031d170e_o.jpg
      1. PEI Print Surface
      2. Borosilicate Glass
      3. Aluminum Base Plate (4 or 5mm thick)
      4. SeeMeCNC ONYX PCB Heated Bed
      Will this work? or it would dissipate way too much?
      I don't know if it has been done before, so any feedback is much appreciated.
      Martin.
      If it ain't broke, fix it till it is =)
      • fcwilt
        fcwilt last edited by
        My gut tells me you are going to lose a lot of heat to the plate and the towers - too much perhaps.
        Perhaps you could keep the plate and on top of it put a disc of some insulating material then the other three items, heater, glass and print surface?
        On my mini-delta I used a piece of 1/2" MDF (hex shaped) to mount a 3mm aluminum heater (round) and a piece of glass (round).
        It seems to be working well.
        • number40fan
          number40fan last edited by
          I think it would even cause heat expansion of the entire frame, throwing your level out of balance.
          • Martin_S
            @fcwilt:
            Thank you my good sir for the quick reply, that's what I feared.
            Indeed, I have it that way atm. Pei - glass - alum spreader - onyx - mdf base plate. A nice working sandwich.
            My common sense told me this wouldn't work, but I was hoping to hear yesss mate, do it! It's awesome! Some friend have it that way 🙂
            @number40fan:
            Good point. I didn't even thought about heat expansion.
            Thank you guys for your feedback.
            Martin.
            • WZ9V
              WZ9V last edited by
              The Tevo Little Monster uses an anodized plate with a machined lip to hold the glass in place with the heater glued to that. That is held in place by some standoffs and M5 bolts. Wouldn't be hard to adapt that idea to the Onyx stack. I like the removable glass on a Max V3 versus the glued in glass on the Tevo.
