    Connecting 3 wire fan Toolboard
    • dk
      dk last edited by
      Hello
      I try to connect 3 wire FAN BLOWER 35X10MM 12VDC WIRE (Delta Electronics BFB03512HHA-AF00) to Out 1 of Toolboard.
      Fan start spinning at the power up and continues to spin at a constant speed regardless of the settings and commands M106 and M107.
      Wires connected: Black to GND, Red to +12V, Blue to out1
      M950 F0 C"20.out1" Q1000 ; create fan 0 part cooling on pin 20.out1 and set its frequency
      M106 P0 S0 ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"20.out2" Q500 ; create fan 1 heatsink on pin 20.out2 and set its frequency
      M106 P1 S0 H1 T45 ; set fan 1 value. Thermostatic control is turned on 45C
      I tried several Q parameters. H-1 at M106 also didn't help.
      any ideas that I messed up?
        Please share your full config.g and the output of M122 and M122 B1
        What commands did you send specifically?
        • dk
          dk last edited by
          M106 with S250 S0 S10 S100 and M107 does not effect on blower
          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Sep 01 2020 22:07:15 GMT-0400 (EDT)
          M550 P"Duet 3" ; set printer name
          M665 L460.000:460.000:460.000 R244.194 H673.6 B190.0 X-0.140 Y-0.034 Z0.000 ; Set delta radius, diagonal rod length, printable radius and homed height
          M666 X0.22 Y0.12 Z-0.34 A0.00 B0.00 ; put your endstop adjustments here, or let auto calibration find them
          M569 P0.0 S1 ; physical drive 0.0 upper 0 tower goes back
          M569 P0.1 S0 ; physical drive 0.1 upper 1 tower goes forwards
          M569 P0.2 S1 ; physical drive 0.2 upper 2 tower goes back
          M569 P0.3 S0 ; physical drive 0.3 lower 2 tower goes forwards
          M569 P0.4 S0 ; physical drive 0.4 lower 1 tower forwards
          M569 P0.5 S0 ; physical drive 0.5 lower 0 tower goes forwards
          M569 P20.0 S0 ; physical drive 20.0 - extruder on board 20 goes Back
          M584 X0.1:0.4 Y0.0:0.5 Z0.2:0.3 E20.0 ; set drive mapping
          M92 X160.00 Y160.00 Z160.00 E415.00 ; set steps per mm
          M566 X800.00 Y800.00 Z800.00 E600.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X5000.00 Y5000.00 Z5000.00 E600.00 ; set maximum speeds (mm/min)
          M201 X2000.00 Y2000.00 Z2000.00 E1000.00 ; set accelerations (mm/s^2)
          M906 X1600 Y1600 Z1600 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 Z0 S1 ; set minimum Z
          M574 X2 S1 P"io1.in" ; configure active-high endstop for HIGH end on X via pin io0.in
          M574 Y2 S1 P"io0.in" ; configure active-high endstop for HIGH end on Y via pin io1.in
          M574 Z2 S1 P"io2.in" ; configure active-high endstop for HIGH end on Z via pin io2.in
          M558 P8 C"20.io0.in" ; set Z probe type to 8 and
          G31 P50 X-21 Y-8 Z1 ; set Z probe trigger value, offset and trigger height
          M557 R150 S50 ; define mesh grid
          M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp3
          M950 H0 C"out0" T0 ; create bed heater output on out1 and map it to sensor 0
          M308 S1 P"20.temp0" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin 20.temp0
          M950 H1 C"20.out0" T1 ; create nozzle heater output on 20.out0 and map it to sensor 1
          M501
          M122
          RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode)
          Board ID: 08DJM-956L2-G43S4-6JTDJ-3SJ6S-986GH
          Used output buffers: 1 of 40 (10 max)
          Static ram: 154604
          Dynamic ram: 161704 of which 160 recycled
          Exception stack ram used: 416
          Never used ram: 76332
          Tasks: NETWORK(ready,1972) HEAT(blocked,1188) CanReceiv(suspended,3460) CanSender(suspended,1460) CanClock(blocked,1436) TMC(blocked,68) MAIN(running,4960) IDLE(ready,76)
          Owned mutexes:
          Last reset 00:49:42 ago, cause: software
          Last software reset at 2021-01-28 23:24, reason: User, spinning module LinuxInterface, available RAM 75988 bytes (slot 2)
          Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
          Error status: 0
          MCU temperature: min 46.5, current 47.0, max 47.3
          Supply voltage: min 25.9, current 26.0, max 26.0, under voltage events: 0, over voltage events: 0, power good: yes
          12V rail voltage: min 12.2, current 12.3, max 12.3, under voltage events: 0
          Driver 0: standstill, reads 48539, writes 19 timeouts 0, SG min/max 0/199
          Driver 1: standstill, reads 48539, writes 19 timeouts 0, SG min/max 0/210
          Driver 2: standstill, reads 48540, writes 19 timeouts 0, SG min/max 0/220
          Driver 3: standstill, reads 48540, writes 19 timeouts 0, SG min/max 0/255
          Driver 4: standstill, reads 48541, writes 19 timeouts 0, SG min/max 0/207
          Driver 5: standstill, reads 48541, writes 19 timeouts 0, SG min/max 0/233
          Date/time: 2021-01-29 00:13:55
          Slowest loop: 4.77ms; fastest: 0.14ms
          === Storage ===
          Free file entries: 10
          Hiccups: 0(0), FreeDm: 375, MinFreeDm: 369, MaxWait: 10723ms
          === MainDDARing ===
          Scheduled moves: 5, completed moves: 5, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
          === AuxDDARing ===
          Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
          Segments left: 0
          Movement lock held by null
          HTTP* is ready with "M122" in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          SBC is idle in state(s) 0
          Daemon* is idle in state(s) 0 0, running macro
          Aux2 is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 0.82ms; fastest: 0.01ms
          Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
          HTTP sessions: 0 of 8
          • Ethernet -
            State: disabled
            Error counts: 0 0 0 0 0
            === CAN ===
            Messages sent 11917, longest wait 3ms for type 6011
            === Linux interface ===
            State: 0, failed transfers: 0
            Last transfer: 22ms ago
            RX/TX seq numbers: 30007/30009
            SPI underruns 0, overruns 0
            Number of disconnects: 0
            Buffer RX/TX: 0/0-0
            === Duet Control Server ===
            Duet Control Server v3.1.1
            Code buffer space: 4096
            Configured SPI speed: 8000000 Hz
            Full transfers per second: 32.10
          M122 B20
          Diagnostics for board 20:
          Board TOOL1LC firmware 3.1.0 (2020-05-15b1)
          Never used RAM 8.5Kb, max stack 368b
          HEAT 1064 CanAsync 1428 CanRecv 1384 TMC 196 AIN 524 MAIN 2284
          Last reset 01:01:12 ago, cause: power up
          Driver 0: standstill, SG min/max 0/0, read errors 0, write errors 0, ifcount 13, reads 1283, writes 13, timeouts 1, DMA errors 0, failedOp 0x80
          Moves scheduled 0, completed 0, hiccups 0
          VIN: 26.1V
          MCU temperature: min 33.7C, current 36.8C, max 37.2C
          Ticks since heat task active 152, ADC conversions started 3658040, completed 3658038, timed out 0
          Last sensors broadcast 00000002 found 1 155 ticks ago
          Free CAN buffers: 36
          NVM user row b1d088a9 fffff8bb d33ea5c7 72796b23
          TSENS 000e6e GAIN 014eb1 OFFS 002812 CAL 1f2c
            Can you do a sudo apt update followed by sudo apt upgrade to update your firmware? Check the versions again after updating. Both the main board and tool board should be 3.2.
              dc42 administrators @dk last edited by dc42
              @dk said in Connecting 3 wire fan Toolboard:
              That's the wrong connection for a 3-wire fan. It should be: Red to +12V, black to OUT1_NEG, blue to OUT1_TACHO.
              The tacho reading will only be correct when the fan is running at full PWM, or off.
              dk 1 Reply Last reply Reply Quote 0
              • dk
                dk @dc42 last edited by
                @dc42 Thank you David!
