    Need help to set up filament runout sensor
    734
    • PuddingBaer91
      PuddingBaer91 last edited by
      Hi
      yesterday i updated my anycubic predator also to a duet wifi 2 board. Now i have the smart effector with the duet board ๐Ÿ™‚ ๐Ÿ™‚
      I managed all to work except the filament runout sensor.
      In my config.g i added this line:
      M591 P2 C"e0stop" S1 D0                                ; Activate filament sensor connected to E0 endstop
      if i send M591 D0 to the duet i get "filament=no" if filament is not present and "filament=yes" if it is present. So the sensor itself works fine i think.
      What i want is: run a "anyname.g" - file when a filament sensor change is happened (from active to non active (from filament present to not present))
      To test the sensor working like i want i created in system folder the trigger4.g file which contains the command to enable the part cooling fans to 100 % (Just to test the state change from sensor)
      In config.g i added the lines to call the trigger4.g:
      trigger4.g
      M581 T4 S0 R0 E0             ; trigger for filament runout sensor, T4 = trigger number
      because of R0 it should trigger even when not printing. But if i pull out the filament from the sensor the part cooling will not activate.
      I read the wiki and tried some things but it's not clear to me how i assign a trigger number (T4) to a .g file. May i understood this wrong. Hope you can help me ๐Ÿ™‚ Thank you
      This is my config.g:
      ; generated by RepRapFirmware Configuration Tool v3.2.2 on Thu Jan 28 2021 13:01:46 GMT+0100 (Mitteleuropรคische Normalzeit)
      G90                                                    ; send absolute coordinates...
      M83                                                    ; ...but relative extruder moves
      M550 P"Anycubic Predator"                              ; set printer name
      M665 R236.801 L440.51 B185 H414.429 X0.094 Y-0.331 Z0  ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0.490 Y-0.110 Z-0.381 A0.00 B0.00                ; put your endstop adjustments here, or let auto calibration find them
      M552 S1                                                ; enable network
      M586 P0 S1                                             ; enable HTTP
      M586 P1 S0                                             ; disable FTP
      M586 P2 S0                                             ; disable Telnet
      M569 P0 S0                                             ; physical drive 0 goes backwards a
      M569 P1 S0                                             ; physical drive 1 goes backwards b
      M569 P2 S0                                             ; physical drive 2 goes backwards c
      M569 P3 S1                                             ; physical drive 3 goes backwards e
      M584 X0 Y1 Z2 E3                                       ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                                ; configure microstepping with interpolation
      M92 X160.00 Y160.00 Z160.00 E415.00                    ; set steps per mm
      M566 X1200.00 Y1200.00 Z1200.00 E1200.00               ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z18000.00 E1200.00            ; set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z1000.00 E1000.00               ; set accelerations (mm/s^2)
      M906 X950 Y950 Z950 E800 I50                           ; set motor currents (mA) and motor idle factor in per cent
      M84 S120                                               ; Set idle timeout
      M208 Z0 S1                                             ; set minimum Z
      M574 X2 S1 P"xstop"                                    ; configure active-high endstop for high end on X via pin xstop
      M574 Y2 S1 P"ystop"                                    ; configure active-high endstop for high end on Y via pin ystop
      M574 Z2 S1 P"zstop"                                    ; configure active-high endstop for high end on Z via pin zstop
      M558 P5 R0.4 C"zprobe.in+zprobe.mod" H5 F600 T6000    ; set Z probe type to effector and the dive height + speeds old 15
      G31 P100 X0 Y0 Z-0.1                                   ; set Z probe trigger value, offset and trigger height
      M557 R115 S20                                          ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4092         ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0                                  ; create bed heater output on bedheat and map it to sensor 0
      M307 H0 B0 S1.00                                       ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                                ; map heated bed to heater 0
      M143 H0 S120                                           ; set temperature limit for heater 0 to 120C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                                   ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 B0 S1.00                                       ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S260                                           ; set temperature limit for heater 1 to 260C
      M950 F0 C"fan0" Q500                                   ; create fan 0 on pin fan0 and set its frequency
      M106 P0 C"Part Cooling" S0 H-1                         ; set fan 0 name and value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                                   ; create fan 1 on pin fan1 and set its frequency
      M106 P1 C"Hotend" S1 H1 T45                            ; set fan 1 name and value. Thermostatic control is turned on
      M950 F2 C"fan2" Q500                                   ; create fan 2 on pin fan2 and set its frequency
      M106 P2 C"Filter Fan" S0 H-1                           ; set fan 2 name and value. Thermostatic control is turned off
      M563 P0 D0 H1 F0 S"Extruder"                           ; define tool 0
      G10 P0 X0 Y0 Z0                                        ; set tool 0 axis offsets
      G10 P0 R0 S0                                           ; set initial tool 0 active and standby temperatures to 0C
      M307 H0 R0.431 C575.303:575.303 D1.31 S1.00 V24.2 B0   ; PID parameters for heatbed
      M307 H1 R2.452 C213.022:213.022 D6.25 S1.00 V24.1 B0   ; PID parameters for extruder
      trigger4.g
      M581 T4 S0 R0 E0                                       ; trigger for filament runout sensor T2 = trigger number
      M501                                                   ; load saved parameters from non-volatile memory
      this is my trigger4.g:
      M106 P0 S255
        Please report the results of sending M122 and M98 P"config.g"
        • PuddingBaer91
          @Phaedrux said in Need help to set up filament runout sensor:
          M122
          29.1.2021, 19:20:39	M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet WiFi 1.02 or later
          Board ID: 0JD0M-9P6M2-NW4SN-6J9D2-3SJ6R-9BUBK
          Used output buffers: 2 of 24 (11 max)
          Static ram: 23460
          Dynamic ram: 72804 of which 24 recycled
          Never used RAM 15792, free system stack 189 words
          Tasks: NETWORK(ready,183) HEAT(blocked,295) MAIN(running,452) IDLE(ready,19)
          Owned mutexes: WiFi(NETWORK) HTTP(MAIN)
          Last reset 00:01:36 ago, cause: power up
          Last software reset at 2021-01-29 16:11, reason: User, GCodes spinning, available RAM 15792, slot 1
          Error status: 0x00
          Aux0 errors 0,0,0
          MCU temperature: min 23.7, current 28.5, max 28.7
          Supply voltage: min 24.0, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: position 125740, standstill, SG min/max not available
          Driver 1: position 125740, standstill, SG min/max not available
          Driver 2: position 125740, standstill, SG min/max not available
          Driver 5: position 0
          Driver 6: position 0
          Driver 7: position 0
          Driver 8: position 0
          Driver 9: position 0
          Driver 10: position 0
          Driver 11: position 0
          Date/time: 2021-01-29 19:20:38
          Cache data hit count 116224094
          Slowest loop: 3.48ms; fastest: 0.21ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 1.2ms, write time 0.0ms, max retries 0
          === MainDDARing ===
          === AuxDDARing ===
          Segments left: 0
          Movement lock held by null
          HTTP is ready with "M122 " in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 15.88ms; fastest: 0.00ms
          HTTP sessions: 1 of 8
          - WiFi -
          Network state is active
          WiFi firmware version 1.25
          WiFi MAC address 40:f5:20:1d:bf:a8
          WiFi Vcc 3.37, reset reason Turned on by main processor
          WiFi flash size 4194304, free heap 27056
          WiFi IP address 192.168.1.43
          WiFi signal strength -74dBm, mode 802.11n, reconnections 0, sleep mode modem
          Clock register 00002002
          === Filament sensors ===
          Extruder 0 sensor: no filament
          29.1.2021, 19:21:17	M98 P"config.g"
          HTTP is enabled on port 80
          FTP is disabled
          TELNET is disabled
          Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 272C
          Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 547C
          Error: Bad command: trigger4.g
            Put a ; in front of trigger4.g
            lemme double check the usage of M591 and M581
            PuddingBaer91 1 Reply Last reply Reply Quote 0
            • PuddingBaer91
              PuddingBaer91 @Phaedrux last edited by
              @Phaedrux the added the ; but no change. I only added this line because i thought this way the T4 parameter is assigned to this file...
                I think the problem is that you are trying to use the same switch for filament sensing and as a trigger at the same time.
                The filament sensor behavior is to send a pause command when the filament is not present.
                If you want to use the switch to trigger a custom macro, you would just use M581.
                It has been requested previously to allow for a custom macro on filament runout and it's on the work list.
                https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M591_Configure_filament_sensing
                https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M581_Configure_external_trigger
                So in the meantime, configure as one or the other.
                • PuddingBaer91
                  @Phaedrux thank you i will try. Also found that trigger T1 resets the board, T2 pauses and all numbers above executes triggerX.g files. Is this in RRF3 still the case? I can't find this info in the wiki. I found it by google...
                  Thank you for your help. Will report the result ๐Ÿ˜‰
                  • PuddingBaer91
                    Okay now it works. I just deleted the trigger code...
                    A few other questions i dont want to open a new thread:
                    I always calibrated my delta in cold state (heaters off) now if i want to always calibrate before a print starts should i do this in cold state? I ask because if i also want to use mesh compensation i have to do this with heated bed state. Should i also always do a mesh compensation after delta calibration before each print? Or just load a state after calibration?
                      Phaedrux Moderator @PuddingBaer91 last edited by
                      @PuddingBaer91 said in Need help to set up filament runout sensor:
                      It's literally in the link I posted above.
                      Trigger number 0 causes an emergency stop as if M112 had been received. Trigger number 1 causes the print to be paused as if M25 had been received. Any trigger number # greater than 1 causes the macro file sys/trigger#.g to be executed. Polling for further trigger conditions is suspended until the trigger macro file has been completed. RepRapFirmware does not wait for all queued moves to be completed before executing the macro, so you may wish to use the M400 command at the start of your macro file. If several triggers are pending, the one with the lowest trigger number takes priority.
                      I think it's usually best to perform any calibration in a hot state to better match the thermal expansion changes that happen during the actual print.
                      • PuddingBaer91
                        thank you ๐Ÿ™‚
                        Another thing i noticed: If i probe the bed in DWC the z-probe shows most time 0 but sometimes it shows a red 1000. Is this normal? Probe triggers at all cases correct...
                          @PuddingBaer91 Yes that's normal. The web interface can't update fast enough for probes that only briefly show the triggered state.
                          • PuddingBaer91
                            thank you again ๐Ÿ™‚
                            another thing ๐Ÿ˜„
                            If i heat the hot end the probe led flickers. If i set the sensity to 70 it's gone. Is this way okay or do i have to check/change something?
                              What does this mean?
                              If the probe is still functioning normally I wouldn't worry about the flicker.
                              • PuddingBaer91
                                i meant the sensity parameter for smart effector:
                                M672 S105:70:185
