    Forum Suggestion: Proper Code Highlighting
    86
    • GoremanX
      GoremanX last edited by
      Since the vast majority of code that gets posted on here is gcode, it sure would be nice if the code highlighting was consistent with that. I'm not sure if there's markup to select what kind of code we're posting, but if there is, perhaps gcode could be set as the default? And if not, perhaps the highlighting could be changed to gcode in the backend?
      fcwilt 1 Reply Last reply Reply Quote 0
      • fcwilt
        fcwilt @GoremanX last edited by
        @GoremanX said in Forum Suggestion: Proper Code Highlighting:
        The code tag </> doesn't seem to highlight as one might expect but it's a step in the right direction.
        GoremanX 1 Reply Last reply Reply Quote 0
        • GoremanX
          GoremanX @fcwilt last edited by
          @fcwilt said in Forum Suggestion: Proper Code Highlighting:
          Yes that's what I'm referring to. Some forums allow to select the highlight syntax within that markup. This forum does not
          A Former User 1 Reply Last reply Reply Quote 0
          • A Former User
            A Former User @GoremanX last edited by
            nothing a handjob can't fix
            ```bash
            #code goes here
            ```text
            unformattted
            and so on
            fcwilt 1 Reply Last reply Reply Quote 1
            • fcwilt
              fcwilt @Guest last edited by
              @bearer said in Forum Suggestion: Proper Code Highlighting:
              ```bash
              #code goes here
              And what is that supposed to do?
              • A Former User
                A Former User @fcwilt last edited by
                it sets the language for highlighting as OP requested, haven't checked if there is a gcode language, wasn't one last time. json does seem to be second best thing after some experimenting
                • GoremanX
                  I can't help but notice that DWC 3.2 has a nice syntax highlighter when editing gcode files in Chrome-based browsers (though it appears to be disabled in Firefox). I wonder if that could be somehow ported to this forum's code markup processing.
                  • A Former User
                    A Former User @GoremanX last edited by A Former User
                    markup
                    the markup markdown stuff does have a gcode highligter, but but this version didn't last time it was a topic iirc.
                    btw to show the ``` - nest it in four of those..
                    ````language
                    ```language
                    stuff
                      ; Add default wifi network
                      M291 R"Add default WIFI network? Y/N" P"This will add duetwifi access point." S3 T10
                      M552 S0			; Disable network module
                      G4 S5			; wait 5 seconds
                      M587 S"NETWORKNAME" P"PASSWORD"			; Add duet wifi SSID to remembered networks list
                      M552 S1			; reenable wifi module
                      M291 R"duetwifi SSID added." P"Check console to verify IP address."
                      The json tag seems to highlight fairly well for gcode.
                      • GoremanX
                        GoremanX @Phaedrux last edited by GoremanX
                        @Phaedrux Cool! Would be nice if it defaulted to that when we click the </> button. I couldn't easily find any way to set it to different languages (not that I tried very hard), but now that I know, I'll do so
