    Multiple Web Cameras
    Duet Web Control wishlist
    • adamj12bundefined
      adamj12b
      I have done quite a bit of searching, but Im umable to find a way to display multiple web camera streams in DWC.
      My setup includes a wide view and a nozzle view and I would like to switch back and forth between them. Currently this is the only thing Octoprint doing for me.
      OwenDundefined 1 Reply Last reply Reply Quote 0
        I don't think that is currently possible as you can only enter one url at a time. Will move to wishlist.
        • OwenDundefined
          OwenD @adamj12b
          @adamj12b
          You could put the URL of the first camera in the normal DWC camera configuration and the URL of the second camera in the section that says something like "URL when image clicked"
          I'm not near my printer to check exact wording
          adamj12bundefined 1 Reply Last reply Reply Quote 1
          • Martin1454undefined
            Martin1454
            Maybe you can run OBS stream, either on another device - Or if you have a duet 3 with an RPI, then on the RPI it self - That should be able to merge the 2 streams
            • adamj12bundefined
              adamj12b @OwenD
              @OwenD said in Multiple Web Cameras:
              @adamj12b
              Thats a good short term work around!
              @Martin1454 said in Multiple Web Cameras:
              I have not heard of OBS, but I will look into it and see if it could do this. I dont want to run anything too heavy on the Pi, as it will already be serving the 2 camera streams as well as taking to the 6HC and running NodeRed.
