    Fan Controll Issue
    1.5k
    • PeterAundefined
      PeterA
      Hi all Help Appreciated. So I have everything except my Parts cooling fans working. I cannot get them to turn on when i use the fan slider in the web interface, nor on the panel due. The sliders work OK, in other words what i set the slider % to on the web interface is reflected on the panel due as the same.
      However even when i get the temps up on the hot end and even the bed, just in case, the fans do not rotate. I know they work as they where working with a slider on the old firmware, with assignment issues, but they worked. Any help appreciated.
      Below are the facts.
      • The fans are physically connected to the fan pin 1 not 0. For some reason pin 0 is faulty and hasn't worked, however pin 1 has.
      • The hot end fan is connected to always on and works fine.
      I have tried a number of config.g settings but no positive results. It almost like this pin is no not working as well. Not sure if there is something physical to look at like a fuse??
      here is part of my config.g settings and a pic.
      ; ##### Heaters #####
      M307 H0 A94.6 C545.4 D2.4 S1.00 V24.1 B0 ;PID tuning for Bed
      M307 H1 A309.5 C152.4 D4.9 S1 S1 V24.1 ;PID tuning for Nozzel
      M143 H1 S310 ; set temperature limit for heater 1 to 310C
      ; ##### Fans #####
      M950 F0 C"fan0" Q500 ; create fan 0 and fan1 on pin0 and set its frequency
      M106 P0 S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
      M950 F1 C"Parts Fan" Q500 ; create fan on pin1 and set its frequency
      M106 P1 S1 L41 X255 B1 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on
      ; ##### Tools #####
      M563 P0 S"Mosquito" D0 H1 F0 ; define tool 0
      The fans work together in the red circle, that's OK. The problem is the parts cooling fans on fan pin 1 don't spin up.
      Any help or advice appreciated.
      • Vetiundefined
        Veti
        @PeterA said in Fan Controll Issue:
        do you see the problem?
        PeterAundefined 1 Reply Last reply Reply Quote 0
        • Vetiundefined
          Veti
          also Parts Fan is not a valid pin
          • PeterAundefined
            PeterA @Veti
            @Veti
            Not sure, is the F) meant to read F1?
            Im no programmer.
            • Vetiundefined
              Veti
              you said its connected to pin 1 but you configured pin0 "fan0" is the pin on the board
              • PeterAundefined
                PeterA @Veti
                @Veti said in Fan Controll Issue:
                Parts Fan
                Ok so should it read
                M950 F1 C'fan1" Q500
                and then
                M950 F1 C"fan1" Q500
                or do i just put that in once?
                Vetiundefined 1 Reply Last reply Reply Quote 0
                • Vetiundefined
                  Veti @PeterA
                  if you connect the second fan to always on you can not control it.
                  therefore the config to control the fan is not required
                  delete
                  • Vetiundefined
                    Veti
                    and dont change the f parameter
                    • PeterAundefined
                      PeterA
                      Thank ok ill delete it. then do i change the other code to
                      Its not my field o expertise?
                      • Vetiundefined
                        Veti
                        again dont change the f parameter
                        • PeterAundefined
                          PeterA
                          sorry didnt see that
                          • Vetiundefined
                            Veti
                            if you change the config. its a good idea to read the documentation what the parameters do.
                            e.g
                            https://duet3d.dozuki.com/Wiki/Gcode#Section_M950_Create_heater_fan_or_GPIO_servo_pin
                            • PeterAundefined
                              PeterA
                              Ok I'm trying this, hope I understood correctly, I've been through that document but I'm not getting it I guess. Its not through lack of trying 😉
                              ; ##### Fans #####
                              M950 F0 C"fan1" Q500 ; create fan 0 and fan1 on pin0 and set its frequency
                              ;M950 F1 C"Parts Fan" Q500 ; create fan on pin1 and set its frequency
                              ;M106 P1 S1 L41 X255 B1 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on
                              • PeterAundefined
                                PeterA
                                It's not working. Or did I misunderstand and I cant control them??
                                • PeterAundefined
                                  PeterA
                                  The tool fan or hot end fan is always on and i don't want to control that, the parts cooling fan is connected to the pin in the diagram that i circled, and that's the one i want to control. I can not get them to come on at all anymore.
                                  • Vetiundefined
                                    Veti
                                    check that the fan is working by connecting it to the always on fan.
                                    however, if you for example swapped the polarity by mistake and connect the fan, you can blow the mosfet. then the port will either stay on or off, depending on how the mosfet failed.
                                    • PeterAundefined
                                      PeterA
                                      Thanks, I didn't change the connections and it was working, I'm not sure. The first pin Pin0 failed a while back so if you say the config is ok then I guess i have a failed mosfet. Not sure if that's changeable, I've changed a few on my Arduino board.
                                      • Vetiundefined
                                        Veti
                                        issue
                                        M106 P0 S1
                                        see if the fan turns on.
                                        if not. try fan2 port
                                        • Vetiundefined
                                          Veti
                                          and just to be sure. you restarted the duet after you made those changes?
                                          • PeterAundefined
                                            PeterA
                                            Thanks ill go try, the software rebooted the duet, ill try turn in off and on physically now
