    Fan Controll Issue
    1.5k
    • PeterAundefined
      PeterA @Veti
      @Veti
      OK, i don't have any issues with the hot end or bed heating up and maintaining temp, not sure i understand the connection with the fans?
      Vetiundefined 1 Reply Last reply Reply Quote 0
      • Vetiundefined
        Veti @PeterA
        @PeterA
        its not connected. but an incorrect value with result in an incorrect temperature being displayed.
        it could show 200 but the actual temperature could easily be 180
        • PeterAundefined
          PeterA
          @Veti said in Fan Controll Issue:
          M106 P0 S1
          OK ill look into that, but just to confirm its not related to the fan issue?
          • Vetiundefined
            Veti @PeterA
            @PeterA
            that command is to enable the fan to 100%
            • PeterAundefined
              PeterA
              B4138
              ok, after changing that the fans still don't come on at all. Ive put the jumper onto always on and the fans con on just fine.
              • Vetiundefined
                Veti @PeterA
                @PeterA
                no the beta has nothing to do with the fan
                what jumper?
                • PeterAundefined
                  PeterA
                  Ok.. so after plugging the jumper into always on then back to pin 1 they are now working????
                  • PeterAundefined
                    PeterA
                    Must be like a faulty wiring connection.??
                    • PeterAundefined
                      PeterA
                      Jip, everything now seems to work, I'll replace the connector, it looks OK but somethings off.
                      • PeterAundefined
                        PeterA
                        B4138
                        Thanks for your help.
                        Regarding the B4138, i don't have any documentation regarding that. Ive looked through old setups and that's the one that its always used. How could i test this is correct?
                        • Vetiundefined
                          Veti
                          where did you buy the equipment?
                          and you never answered the question about what jumper you are talking about?
                          • PeterAundefined
                            PeterA
                            Ill go see where it came from. Sorry not a jumper, I meant the connector from the fans that go onto the board.
                            • PeterAundefined
                              PeterA
                              @Veti said in Fan Control Issue:
                              find the correct beta value in your thermistor
                              Evidently my hot end temp sensor
                              is as follows:
                              2M NTC 3950 100K Ohm High Temperature Resistance
                              Could i ask how and what setting to put in to the config.g for this?
                              • Vetiundefined
                                Veti @PeterA
                                @PeterA
                                B3950
                                • PeterAundefined
                                  PeterA
                                  B3950
                                  Thank you I'll type that in.
                                  • PeterAundefined
                                    PeterA
                                    Thanks for your help Veti
