    run code / trigger relay when heater 0 is active or standby?
    Gcode meta commands
    • Martin1454undefined
      Martin1454
      Is it possible to setup the firmware to enable an output when you enable the heater 0 (off-> active?)
      I have an mechanical relay that is in series with my bed heater, but I'm using PS_ON to enable my 24V supply - So is there a way to make one of the GPIO high or low if im changing the state of the heater?
      I know that I can write a gcode to change the state of the GPIO, but I would like to avoid having to write that GCODE each time im trying to heat up the bed.
      Thanks for the help!
        You could set up a monitoring loop in daemon.g to check the heater status perhaps.
        https://duet3d.dozuki.com/Wiki/Macros#Section_daemon_g
        https://duet3d.dozuki.com/Wiki/GCode_Meta_Commands
        Martin1454undefined 1 Reply Last reply Reply Quote 1
          Martin1454 @Phaedrux
          @Phaedrux said in run code / trigger relay when heater 0 is active or standby?:
          That seems like a good way to do it - Do we know what the status variable is called for the bed heater? or is there an overview somewhere where I can find it?
            Yes it would be in the object model.
            https://duet3d.dozuki.com/Wiki/Object_Model_of_RepRapFirmware
            In 3.2 you can load the object model browser plugin to explore the machine state and all of the objects available. That's where you can get the names.
            Martin1454undefined 1 Reply Last reply Reply Quote 0
              @Phaedrux That is perfect, I will try to use that!
