    DUET2MAESTRO
    Using Duet Controllers
    • ansonyang
      ansonyang last edited by
      Thank you
      Does DUET2MAESTRO have an automatic shutdown function after work?
      • Veti
        Veti last edited by
        see
        https://duet3d.dozuki.com/Wiki/Power_Wiring#Section_Controlling_the_external_power_supply
        • T3P3Tony
          if you put M0 in your end gcode then whatever is in the "stop.g" file will be run.
          In that file you can have whatever actions you want the printer to take, see:
          https://duet3d.dozuki.com/Wiki/Gcode#Section_M0_Stop_or_Unconditional_stop
          • ansonyang
            I want to automatically turn off the power after printing
            • T3P3Tony
              T3P3Tony administrators @Veti last edited by
              @Veti said in DUET2MAESTRO:
              see
              • ansonyang
                Thank you
