    G10 for temporary Z offset?
    18
    • DanS79
      DanS79 last edited by
      when I switch filaments I usually tweak the G31 z trigger height in my config.g to get a really good first layer. I'm switching filaments more regularly lately and that's getting annoying.
      is it possible to just include a G10 or something similar in my start-up gcode to
      to adjust the G31 by a small amount relative to its value in config.g
      I know i could do something hacky using G91, G92, and G90, but i was hoping a more elegant method existed that didn't rely on multiple configs or something similar.
      • fcwilt
        fcwilt last edited by
        You certainly don't need to change G31 in config.g. when you change filaments.
        Have you considered using the filament management feature of the DWC?
        I use it to set the bed and extruder temps and extrusion multiplier for each brand and type of filament that I use.
        DanS79 1 Reply Last reply Reply Quote 0
        • DanS79
          DanS79 @fcwilt last edited by
          @fcwilt said in G10 for temporary Z offset?:
          I do that in my slicer (idemaker), because I have several profiles per filament, all with different Pa, accel, jerk, Pa, and temp settings.
          in general my goal is to keep everything related to and on the machine as generic as possible and then make adjustments as needed in the slicer.
          fcwilt 1 Reply Last reply Reply Quote 0
          • DanS79
            I should add i can't test anything right now am my machine is down while I wait for parts, hence why i asked here.
            • fcwilt
              fcwilt @DanS79 last edited by
              @DanS79 said in G10 for temporary Z offset?:
              Just the opposite here. I try to keep the output of the slicer as generic as possible and tweak things as needed on my printers.
              Does baby-stepping not work for this?
              • DanS79
                @fcwilt
                It does/will, but you have to remember to do it.
                most of my printing is prototyping, so while one version is printing I'm inspecting the previous one and tweaking the design for the next one. Sometimes things get missed in the turn around.
                • fcwilt
                  @fcwilt
                  Then set the the needed value in your start up code.
                  • DanS79
                    @fcwilt Thats why i asked. I'm not sure G10 will work the way I need it to, and i wanted to see if other options existed.
                    and as i said i can't test at the moment as my machine is down till some parts arrive.
                    • fcwilt
                      I was thinking of M290 which allows adjusting the current value of baby-stepping.
                      • DanS79
                        @fcwilt Yea thats would work set it to a given value in the start gcode, then back to zero in the end gcode.
                        • fcwilt
                          Notice that you can use absolute or relative values - whatever works best for any given situation.
