    Core XYUV homing going squiffy
    • pcsentinelundefined
      pcsentinel
      Hi All, I am trying to sort out my homing files for my new core XYUV. every time I think I am getting somewhere then another issue raises its head.
      My Axis and endstops are set as follows
      M208 X320 Y320 U350 Z250 S0 ; Set axis maxima
      M208 X-33 Y0 U0 Z0 S1 ; Set axis minima
      M574 X1 S1
      M574 Y2 S1
      M574 U2 S1
      M574 V1 S0
      M574 Z2 S1
      So
      X Endstp is to the left and results in -33X
      U endstop is to the right and results in +350U
      Y Endstop is to the back and results in +320Y
      Home X is:
      G91 ; relative positioning
      G1 H1 X-700 F1800 ; move quickly to X axis endstop and stop there (first pass)
      G1 X10 F1800 ; go back a few mm
      G1 H1 X-700 F360 ; move slowly to X axis endstop once more (second pass)
      G90 ; absolute positioning
      Home U is:
      G1 H1 U700 F1800; move quickly to X axis endstop and stop there (first pass)
      G1 U-10 F1800 ; go back a few mm
      G1 H1 U700 F360 ; move slowly to X axis endstop once more (second pass)
      Home Y is:
      G1 H1 Y700 F1800 ; move quickly to Y axis endstop and stop there (first pass)
      G1 Y-10 F1800 ; go back a few mm
      G1 H1 Y700 F360 ; move slowly to Y axis endstop once more (second pass)
      The problem that I am facing is that after startup I home X then X position shows as -33 which is what I would expect. If I then Home Y, then the reported X position goes to 0 and the reported Y position goes to 320. If I then home U then the X and Y positions are 0 and the U position shows as 350.
      I don't understand why the other 2 positions are being negated.
      I haven't even included dropping the bed and raising it again yet. It all seems very strange.
        Please post your full config.g please along with the results of M122 and M98 P"config.g".
          pcsentinel
          M111 S0 ; Debugging off
          M84 S120 ; Set idle timeout
          ;Movement
          M669 K5 ; switch to CoreXY mode
          M569 P0 S1 ; X Drive 1 goes backwards
          M569 P1 S1 ; Y Drive 1 goes forwards
          M569 P5 S0 ; U Drive 1 goes backwards
          M569 P6 S0 ; V Drive 1 goes forwards
          M569 P3 S0 ; E0 Drive 3 goes forwards
          M569 P8 S0 ; Z Left Drive 8 goes forwards
          M569 P9 S0 ; Z Right Drive 9 goes forwards
          M584 X0 Y1 U5 V6 Z8:9 E3:4 P4; assign drives to axis
          M574 X1 S1
          M574 Y2 S1
          M574 U2 S1
          M574 V1 S0
          M574 Z2 S1
          ;M574 Z2 S0
          ;M574 Y2 S1
          ;M574 X1 Y1 U0 Z2 S0 ; Set endstop configuration (X and Y endstops at low end, U endstop at high end, active high, no Z endstop)
          M906 X1000 Y1000 U1000 V1000 Z1000 E1000:1000; Set motor currents (mA) and motor idle factor in per cent
          M201 X1000 Y1000 U1000 V1000 Z250 E250,250 I30; Set accelerations (mm/s^2)
          M203 X5000 Y5000 U5000 V5000 Z500 E1200:1200 ; Set maximum speeds (mm/min) bumped up extruder settings
          ; the above settings are set by using the EMF Calculator  on RepRapFirware.org essentially limiting max speed to 80mm/s
          M566 X1200 Y1200 U1200 V1200 Z250 E420:420 ; Set maximum instantaneous speed changes (mm/min) bumped up extruder settings
          ; The above settings are set to 25% of desired maximum printing speed of 70mm/s = 1050
          M92 X160 Y160 U160 V160 Z400 E837:837 ; Set steps per mm
          M350 X16 Y16 U16 V16 Z16 E16:16 I1 ; Configure microstepping with interpolation
          G21 ; Work in millimetres
          ; Z Probe
          M558 P1 H3 F120 T6000 A2; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
          G31 P500 X30 Y0 Z2.18; with an elephant foot compensation of 0.1
          M143 S260 ; Set maximum heater temperature to 260C
          M305 P0 T100000 B4725 C7.060000e-8 R4700 ; Set Bed thermistor + ADC parameters
          M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set Heater 1 thermistor + ADC parameters
          M305 P2 T100000 B4725 C7.060000e-8 R4700 ; Set Heater 2 thermistor + ADC parameters
          M563 P0 D0 H1 F1; Define tool 0
          G10 P0 X0 Y0 Z0 S0 R0 ; Set tool 0 axis offsets
          M563 P1 D1 H2 X3 F2; Define tool 1
          G10 P1 Y0 U0 Z0 S0 R0 ; Set tool 1 axis offsets
          M550 P"K8200Duet" ; Set machine name
          ;M552 S1 ; Enable network and acquire dynamic address via DHCP
          M552 S2 ; Enable access point mode
          M106 P0 S1 I0 F500 H1 T45 ; Set fan 0 value, Extruder 1 Fan. PWM signal inversion and frequency. Thermostatic control is turned on
          M106 P1 S1 I0 F500 H2 T45 ; Set fan 1 value, Extruder 2 Fan. PWM signal inversion and frequency. Thermostatic control is turned on
          M106 P2 S0 I0 F500 H-1 ; Set fan 1 value, Extruder 1 Part Fan. PWM signal inversion and frequency. Thermostatic control is turned off
          M106 P3 S0 I0 F500 H-1 ; Set fan 2 value, Extruder 2 Part Fan.PWM signal inversion and frequency. Thermostatic control is turned off
          ;M106 P8 S1	    ; Turn on light
          ;M140 S30	    ; Preheat Bed
          M501                ; Run config-override.g
          ;G29 S1 		    ; Load the heightmap
          T0                  ; Select the first head
          M122:
          M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later + DueX5
          Board ID: 08DAM-999TL-MQ4S8-6JTD2-3SD6R-9N8RZ
          Used output buffers: 3 of 24 (15 max)
          Static ram: 25712
          Dynamic ram: 93980 of which 84 recycled
          Exception stack ram used: 656
          Never used ram: 10640
          Tasks: NETWORK(ready,628) HEAT(blocked,1232) DUEX(suspended,160) MAIN(running,3736) IDLE(ready,160)
          Owned mutexes:
          Last reset 00:34:37 ago, cause: software
          Last software reset at 2021-02-03 16:23, reason: User, spinning module GCodes, available RAM 10640 bytes (slot 3)
          Error status: 0
          Free file entries: 10
          MCU temperature: min 31.7, current 32.4, max 33.3
          Supply voltage: min 24.1, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: standstill, SG min/max 0/1023
          Driver 1: standstill, SG min/max 0/1023
          Driver 5: standstill, SG min/max 0/1023
          Driver 6: standstill, SG min/max 0/205
          Driver 7: standstill, SG min/max not available
          Driver 8: standstill, SG min/max not available
          Driver 9: standstill, SG min/max not available
          Date/time: 2021-02-03 16:58:31
          Slowest loop: 5.07ms; fastest: 0.07ms
          Hiccups: 6, FreeDm: 160, MinFreeDm: 152, MaxWait: 447017ms
          === DDARing ===
          Scheduled moves: 67, completed moves: 67, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
          Heater 1 is on, I-accum = 0.0
          Segments left: 0
          Movement lock held by null
          http is idle in state(s) 0
          telnet is idle in state(s) 0
          file is idle in state(s) 0
          serial is idle in state(s) 0
          aux is idle in state(s) 0
          daemon is idle in state(s) 0
          queue is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 26.34ms; fastest: 0.01ms
          HTTP sessions: 1 of 8
          - WiFi -
          Network state is running
          WiFi module is providing access point
          WiFi firmware version 1.23
          WiFi MAC address a2:20:a6:16:e6:70
          WiFi Vcc 3.44, reset reason Turned on by main processor
          WiFi flash size 4194304, free heap 24840
          WiFi IP address 192.168.51.10
          Connected clients 1
          M98 P"config.g".
          Error: Invalid kinematics matrix
          Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 770C.
          Warning: Heater 2 appears to be over-powered. If left on at full power, its temperature is predicted to reach 904C.
            Before we go much farther there are two things I can see immediately that we should probably resolve.
            First, Error: Invalid kinematics matrix
            https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M669_Set_kinematics_type_and_kinematics_parameters
            Looks like you should be using K8
            Second, is the firmware version. If this is a new build it makes more sense to start with the latest firmware version. 3.2. Firmware 2.05 is over a year old at this point.
            If you still have access to DWC. Upload these 3 zip files, one at a time in the system tab. Don't extract them. Reboot after each. Use M115 to verify the firmware has been applied.
            https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
            https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/Duet2and3Firmware-3.2.zip
            That will get your firmware and DWC up to date.
            For your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3.
            https://configtool.reprapfirmware.org/Start
            Start with the basic config and then start adding in your UV axis changes.
            pcsentinelundefined 1 Reply Last reply Reply Quote 0
              pcsentinel
              Ok, I'll give it a try tomorrow, as this is a completely new build, I was hoping to stay with 2.05 as applying the old adage of not changing everything at once, but I will go ahead.
              Re Is it an XYUV or XYU i.e. M669 5 or 8, this seems in dispute from the forums, my machine has 4 motors driving a single Y carriage with an X and U heads. All movement is working with K5, but I could try K8.
                pcsentinel @Phaedrux
                @Phaedrux
                Thanks to your prompts, I searched for "invalid matrix" and found this thread: https://forum.duet3d.com/topic/20164/g30-g32-issues-on-duet-wifi-corexyu-with-inductive-probe/7?_=1612371745630
                M669 K1 X1:1:0:0 Y1👎0:1 Z0:0:1:0 U0:0:0:1 it seems to have sorted the issue. (at least for now, I have to check the Z drop and raise and home all works first) roll on tomorrow.
                  Based on that thread it would appear it's a bug that's been fixed in 3.2
