Power Failure
Hi DC42
I set the M911 on RC4
But for printing resurrect.g ? I use M98 Psys/resurrect.g not work !
My PSU is 12v … i change the value for this ( example /2) is correct ?
After the power is restored, you can print file sys/resurrect.g to resume the print from where it stopped
Thanks Giorgio
Use the system files editor in DWC to see whether resurrect.g was actually created. There needs to be a certain amount of power in reserve for it to be created, and with 12V power that's less likely.
I plan to do some more work on this feature in release 1.20 to reduce the amount of reserve power that it needs.
The resurrect.g is actually on SYS
created ! but for run ? Is exact M98?
Yes, M98 P/sys/resurrect.g should work, or just M98 Presurrect.g. Where are you sending the command from: PanelDue, DWC, or a USB host program?
Send on DWC
Did anything happen at all?
Yes I create this macro on SYS
files sys/powerfail.g, sys/powerrestore.g and sys/resurrect-prologue.g
copy the example for Delta …itwork fine the system but not run the resurrect.g for printing
What I meant was: if you send M98 Presurrect.g, does anything happen at all? Do you get any messages in the Console window of DWC?
Please post the contents of resurrect.g.
on config,g
…....;Power Failure
M911 S6.0:9.75:11.0 ; PSU 12V.........
Editing 0:/sys/resurrect.g
; File "Test100.gcode" resume print after auto-pause at 2017-07-07 11:33
M140 S40.0
G10 S212 R0
T0 P0
G92 E6.965
G29 S1
M98 Presurrect-prologue.g
M106 P0 S0.00
M106 P1 S0.00
M106 P2 S0.00
M106 P3 S0.00
M106 P4 S0.00
M106 P5 S0.00
M106 P6 S0.00
M106 P7 S0.00
M106 P8 S0.00
M106 S0.00
M116
M290 S0.000
M23 Test100.gcode
M26 S6011
G1 F6000 X-52.85 Y51.40 Z0.20
G1 F1470.0 P0
M24Send on DWC M98 Presurrect.g
reponse from DWC
15:47:25M98 PRESURRECT.G
Macro file resurrect-prologue.g not found.on SYS Editing 0:/sys/resume-prologue.g
M116
G28
M83
G1 E2 F3600NOT the file resurrect-prologue.g ?
I'm sorry, you need to rename resume-prologue.g to resurrect-prologue.g. I changed the filename during development, and when I updated that wiki page I updated all occurrences of that filename… except one. I've corrected it now.
Ok i test now ….thaks David
i post after the result
There is a bug in the resume mechanism if you were using absolute extrusion or volumetric extrusion. I've just fixed those, the fixes will be in RC5.
NOW WORK !!!!!! thanks David DC2
Giorgio
absolute extrusion …..Simply3D v4
6:45:31M98 P0:/macros/RICUPERO Down Power
File Test100.gcode selected for printing
16:42:09Connection established!
16:42:04Disconnected.
16:37:25Attempt to move the head of a Delta or SCARA printer before homing the towers
16:37:21M80
Error: Homing failed
16:36:50Connection established!
16:36:44Disconnected.
16:36:32Print cancelled due to low voltage
Printing resumed
16:36:29Resume-after-power-fail state saved
Print auto-paused due to low voltage
Print auto-resumed
16:32:33M98 PRESURRECT.G
16:30:40Attempt to move the head of a Delta or SCARA printer before homing the towers
16:30:36G28
Attempt to move the head of a Delta or SCARA printer before homing the towersHOME PROBLEMS ??
As far as I can see, there are no commands in resurrect.g prior to the M98 Presurrect-prologue.g call that command movement. So it sounds to me like the G28 command in resurrect-prologue.g failed. A common reason for homing failures in delta printers is that the G1 S1 command in homedelta.g has X, Y and Z parameters that are less than the maximum distance you may need to move the carriages to home them.
Ok ….just one little BUG
M291: Display message and optionally wait for response
Supported in firmware version 1.19beta7 and later.Parameters
P"message" The message to display, which must be enclosed in double quotation marks. if the message itself contains a double quotation mark, use two double quotation marks to represent it.
R"message" Optional title for the message box. Must be enclosed in double quotation marks too.
Sn 0 = no acknowledgement needed (default), 1 = display an OK button and wait for it to be pressed (the user interface then sends M292 to indicate that is has been acknowledged)
Tn Timeout in seconds, ignored if S=1. The message will be cancelled after this amount of time, if the user does not cancel it before then. A zero or negative value means that the message does not time (it may still be cancelled by the user). The default value is 10 seconds
Zn 0 = no special action, 1 = display Z jog buttons alongside the message to allow the user to adjust the height of the print headif set Z0 appear the jog control ,also is set Z1
