    Same .gcode file - two different printers - very different results
    2249
    • Sink
      Sink last edited by
      I noticed that a print coming off my P3 -Duet looked smaller than expected so ran a test ..
      Same file - once on P3 -Duet once on MK2S and the results are very different ..
      The pieces coming off the P3 are about half the size of the MK2S ..
      Are there some values in the config files that overrule the .gcode file on layer thickness or the such?
      • Dougal1957
        Dougal1957 last edited by
        Sounds like your steps per mm may be out. is it all axis or just the Z?
          My guess is that you have configured 2x the microstepping on the Duet (M360 M350 in config.g), but you have configured the steps/mm (M92 in config.g) after that and haven't doubled the steps/mm.
          Do the jog buttons in DWC move the head by the correct amount?
          • Sink
            Sink last edited by
            Appears to be just the Z .. all other dimensions are fine .. Will look at the config and check .. Thanks
            • Sink
              Sink last edited by
              Here is the config pertinent I could find :
              M92 X80 Y80 Z2560 ; Set axis steps/mm
              M92 E420:420 ; Set extruder steps per mm
              I find no M360 entry in the config or the override ..
              The Z2560 is the problem?
              • Dougal1957
                what have you set for your microstepping rates? The M350 line and where is it in your Config.G in relation to the M92 line (Before or after)
                  Sorry, I meant M350 not M360.
                  • Sink
                    Sink last edited by
                    Don't see that either .. Here it is :
                    ; Prusa i3 config file for dc42 Duet firmware
                    ; Prologue and comms section
                    M111 S0 ; Debug off
                    M550 PPrusai3 ; Machine name (can be anything you like)
                    M551 Preprap ; Machine password
                    ;*** If you have more than one Duet on your network, they must all have different MAC addresses, so change the last digits
                    M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address
                    ;*** Adjust the IP address and gateway in the following 2 lines to suit your network
                    M552 P0.0.0.0 ; IP address (0 = use DHCP)
                    M554 P192.168.1.1 ; Gateway
                    M553 P255.255.255.0 ; Netmask
                    M555 P2 ; Set output to look like Marlin
                    M575 P1 B57600 S1 ; Comms parameters for PanelDue
                    M552 S1
                    ; Movement section
                    M569 P0 S0 ; Drive 0 goes forwards (change to S0 to reverse it)
                    M569 P4 S1 ; Drive 4 goes forwards
                    M574 X1 Y1 Z1 S1 ; set endstop configuration (X and Y endstops only, at low end, active high)
                    M906 X800 Y800 Z800 E1000 ; Set motor currents (mA)
                    M201 X800 Y800 Z15 E1000 ; Accelerations (mm/s^2)
                    M203 X15000 Y15000 Z100 E3600 ; Maximum speeds (mm/min)
                    M566 X600 Y600 Z30 E20 ; Minimum speeds mm/minute
                    M208 X200 Y250 Z200 ; set axis maximam (adjust to suit your machine)
                    M208 X0 Y0 Z0 S1 ; set axis minimum (adjust to make X=0 and Y=0 the edge of the bed)
                    G21 ; Work in millimetres
                    ; Z probe section
                    ;M558 P1 X0 Y0 Z1 H3 F200 T5000 ; Smart IR Z probe, used for homing Z axis, dive height 3mm, probe speed 200mm/min, travel speed 5000mm/min
                    ;G31 X11.0 Y0.5 Z1.20 P500 ; Set the probe height and threshold (put your own values here)
                    ; Heater and thermistor section
                    ;*** If you have a Duet board with 1K thermistor series resistors, change R4700 to R1000 to the following M305 commands
                    M305 P0 R4700 H0 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction
                    M305 P1 R4700 H0 L0 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction
                    M305 P2 R4700 H0 L0 ; Put your own H and/or L values here to set the second nozzle thermistor ADC correction
                    M301 H1 P10 I0.10 D100 T0.50 S1.0 ; PID settings for extruder 0
                    M301 H2 P10 I0.10 D100 T0.50 S1.0 ; PID settings for extruder 1
                    M570 S120 ; Increase to allow extra heating time if needed
                    ; Tool definition section
                    M563 P0 D0 H1 ; Define tool 0 to use extruder drive 0 and heater 1
                    G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures
                    ;*** If you have a dual-nozzle build, un-comment the following 2 lines
                    ;M563 P1 D1 H2 ; Define tool 1
                    ;G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures
                    ; Bed probe section (not needed if you use a bed.g file)
                    ;*** Adjust the XY coordinates in the following M557 commands to suit your build and the position of your Z probe
                    M557 P0 X60 Y0 ; Four...
                    M557 P1 X60 Y165 ; ...probe points...
                    M557 P2 X200 Y165 ; ...for bed...
                    M557 P3 X200 Y0 ; ...levelling
                    ;M557 P4 X141 Y82.5 ; 5th probe point for levelling (un-comment this to get a 5th point at the centre of the bed)
                    ; Epilogue
                    ;*** If you are using axis compensation, put the figures in the following command
                    M556 S78 X0 Y0 Z0 ; Axis compensation here
                    T0
                      Some questions for you:
                      1. Is the model half the size it should be in all 3 of X, Y and Z?
                      2. Are you using 1.8 or 0.9deg motors?
                      3. Do the X, Y and Z jog buttons in Duet Web Control move the print head by the amounts you ask for?
                      • Sink
                        Sink last edited by
                        1- Only the Z axis appears different, X and Y look fine ..
                        2. 1.8 deg steppers on X.Y. Z .. (Extruder is titan w/ 0.9)
                        3. The jog buttons (the +/- X.Y.Z buttons?) .. I am not sure what you are asking here… They all move and in the right direction.. but I don't know whether they move the proper amount or not.. is that what you are asking? Sorry .. How do I ascertain that?
                        • Sink
                          Sink last edited by
                          https://photos.google.com/photo/AF1QipOlWXhrREuVYjKKfoCeHcI0rezTTRutaCMDOtgl
                          https://photos.google.com/photo/AF1QipNZ7kfGQyRioLUL7DPl8z_519Mvj0YaE8px4VjG
                          Sorry, photos not perfectly clear but they do show that the Z is different
                          • Sink
                            Sink last edited by
                            Is this the titan causing this wit the 0.9 motor?
                            • whosrdaddy
                              whosrdaddy last edited by
                              @Sink:
                              you can measure this using a ruler.
                              Move the Z-axis for example 100mm and verify if it really moved 100mm.
                              To me it seems your Z-axis steps are high, but it depends on the leadscrews you are using…
                              • Dougal1957
                                How is your Z Driven ie is it a screw if so what size screw is it also on your Ramps setup could you have had 1/8 microstepping set on the Z axis?
                                Doug
                                • Dougal1957
                                  @whosrdaddy:
                                  @Sink:
                                  2560 for Z would be correct for a 1.8 stepper driving the Z by a M5x0.8mm threaded rod assuming 1/16 microstepping
                                  • Sink
                                    Sink last edited by
                                    Z is screw driven .. no, there was no microsteppting on the Z under Ramps.. but there was some changes to the stepping for the extruder..
                                    This is from the titan docs:
                                    Usage
                                    Firmware Calibration
                                    Because Titan uses a known gearing ratio and a consistently machined drive gear, we can offer a fairly accurate steps / mm set-point. Forgot about that ..
                                    Steps per Unit (Extruder) = Motor Steps * Micro-stepping * Gear Ratio / (Hobb Diameter * Pi)
                                    Standard motor steps / rev = 400 for the new style motor or 200 for the old style motor (Refer to assembly steps if unsure which motor you have).
                                    Standard micro-stepping = 16x
                                    Gear Ratio = 3
                                    Hobb Diameter (Effective) = 7.3
                                    200 * 16 * 3 / (7.3 * 3.142) = 418.5
                                    400 * 16 * 3 / (7.3 * 3.142) = 837 "
                                    I changed that number under ramps .. Is there something similar under the RepRap configs?
                                    • Sink
                                      Sink last edited by
                                      There is this command in the config:
                                      looks like this has to change. but is this causing the problem ..
                                      will update it to:
                                      M92 E840:840 ; Set extruder steps per mm
                                      does this seem reasonable?
                                      Why not, giving it a try ..
                                      • Dougal1957
                                        No that will not affect your Z AXis hight at all?
                                        • Sink
                                          Sink last edited by
                                          Probably not, but sounds like it needs to be done anyway??
                                          • Sink
                                            Sink last edited by
                                            Looks like no difference .. when done printing will try to measure the "jog" on the Z axis ..
                                              What is the thread pitch on your Z axis screw? is there any gearing between the Z axis motor and the screw?
                                              Alternatively, do you know what Z steps/mm you were using in the firmware for the other board?
                                              • Sink
                                                Sink last edited by
                                                Tried a jog of +100 and measured 65 mm change.. Will repeat .. Pretty much same result ..
                                                Could this be a current problem to the Z steppers (2)
                                                • Sink
                                                  Sink last edited by
                                                  Looking to find your answers .. Have to find the old marlin code .. and of course it is not on this computer .. will be back when I have the answers .. I believe the P3 came with M5x295 screw rods if that helps ..
                                                    It could be that your Z steps/mm are wrong, or your X acceleration is too high, or your Z maximum speed is too high, or the Z motor current is too low. You should be able to get all of these details except the motor current from your Marlin config file.
                                                    One other possibility: if you have two Z motors and they are badly-chosen high inductance low current types, then the series connection used by the two Z motors connectors on the Duet won't work well with them, and you will need to connect them in parallel instead. Can you read the model number of the Z motors from the label?
                                                    • Sink
                                                      Sink last edited by
                                                      Some numbers :
                                                      Steppers SL42STH40-1684A
                                                      MARLIN:
                                                      DefaultAxisStepsPerUnit 80,80,4000, 775 – the 4000 looks bigger than the config val
                                                      Default Acceleration 3000
