    Z_probe issues with Anet A8
    73
    • Jagofletch
      Jagofletch last edited by T3P3Tony
      To those with experience adding a Duet 2 Wifi to the Anet A8...
      I have a Z homing issue. I can happily home X and Y, the Z motor will even move slightly while I'm homing those axis, so I know the motors are getting a signal from the board.
      When I come to home the Z axis I get the error :
      "G28 Z Error: Z probe already triggered at start of probing move"
      I've included my wiring set up and config.g
      ; generated by RepRapFirmware Configuration Tool v3.2.2 on Wed Feb 03 2021 17:45:53 GMT+0000 (GMT)
      M550 P"Anet A8" ; set printer name
      M551 P"[password]" ; set password
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M92 X100.00 Y100.00 Z400.00 E100.00 ; set steps per mm
      M566 X600.00 Y600.00 Z18.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
      M201 X1500.00 Y1500.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
      M906 X500 Y500 Z500 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X-33 Y-10 Z0 S1 ; set axis minima
      M208 X220 Y220 Z240 S0 ; set axis maxima
      M574 X1 S0 P"xstop" ; configure active-low endstop for low end on X via pin xstop
      M574 Y1 S0 P"ystop" ; configure active-low endstop for low end on Y via pin ystop
      M574 Z0 S0 ; configure Z-probe endstop for low end on Z
      M558 P5 C"!^zprobe.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
      G31 P500 X25 Y40 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X20:200 Y20:200 S40 ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin bedtemp
      M143 H0 S130 ; set temperature limit for heater 0 to 130C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
      M143 H1 S275 ; set temperature limit for heater 1 to 275C
      T0 ; select first tool
      • Veti
        Veti last edited by
        @Jagofletch said in Z_probe issues with Anet A8:
        remove the !
        • Jagofletch
          Thanks for your answer but I'm still getting the same issue after that change.
          • Veti
            Veti last edited by
            post the output of m119
            • Jagofletch
              I've managed to get the Z axis motors working with the following change..
              I have an NO probe, so M558 required the "I1" command to invert the signal
              M558 P4 C"^zprobe.in" H5 F120 T6000
              changed to
              M558 P4 C"^zprobe.in" I1 H5 F120 T6000
              Now I'm still left with the issue of the probe recognising the bed (LED lights up when it's close enough) but the board not telling the motors to disengage.
              M119
              Endstops - X: at min stop, Y: at min stop, Z: not stopped, Z probe: at min stop
              • Veti
                Veti last edited by
                I1 is a version 2 command. inversion is done with !
                if the z probe is always triggered there is a problem wit your wiring.
                • Jagofletch
                  The motors weren't engaging with ! but they've started working with the version 2 I1
                  My probe isn't always triggered. It will trigger (LED on) when it senses the bed, as you would expect. I've checked the wiring for the Z probe multiple times but I will have a triple check.
                  • Veti
                    Veti last edited by
                    the relevent information about triggering is what m119 reports
                    • Jagofletch
                      Jagofletch last edited by Jagofletch
                      Sorry, I must've deleted that from my last reply.
                      M119
                      I'm wondering if it may be that I'm using the wrong diode from the Probe in
                      • Veti
                        Veti last edited by
                        if that is an npn probe
                        Duet 3, Duet 2 Maestro, or revision 1.04 or later of Duet 2 WiFi or Duet 2 Ethernet: you can connect the output of the sensor directly to the Z-probe IN pin.
                        • Jagofletch
                          I have 12v feeding the sensor, can the Z probe in handle that voltage? I'm not entirely sure what an NPN outputs on its signal wire.
                          • Veti
                            Veti last edited by
                            see
                            https://duet3d.dozuki.com/Wiki/Hardware_Overview
                            PCB revision v1.04
                            The Z probe input improved to tolerate inputs up to 30V.
                            so just make sure you have revision 1.04
                            • Veti
                              Veti last edited by
                              if you are not sure if your probe is npn why did you wire it as npn?
                              • Jagofletch
                                Oh I was sure it was NPN. I'm just very new to Duet and there's a lot of info I'm having to juggle. So I may not be putting my point across properly.
                                  Can you post the results of M122 to check the firmware version? Also post the results of M98 P"config.g"
                                  • Jagofletch
                                    M122
                                    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03beta3 running on Duet WiFi 1.02 or later
                                    Board ID: 0JD0M-9P6M2-NW4SS-6JKFD-3SD6N-KUZBL
                                    Used output buffers: 1 of 20 (10 max)
                                    Static ram: 25632
                                    Dynamic ram: 93680 of which 0 recycled
                                    Exception stack ram used: 276
                                    Never used ram: 11484
                                    Tasks: NETWORK(ready,652) HEAT(blocked,852) MAIN(running,3816) IDLE(ready,196)
                                    Owned mutexes:
                                    Last reset 00:03:01 ago, cause: power up
                                    Last software reset at 2021-02-05 20:20, reason: User, spinning module GCodes, available RAM 11356 bytes (slot 1)
                                    Error status: 0
                                    Free file entries: 10
                                    MCU temperature: min 24.6, current 26.7, max 26.8
                                    Supply voltage: min 12.4, current 12.5, max 12.5, under voltage events: 0, over voltage events: 0, power good: yes
                                    Date/time: 2021-02-05 20:27:09
                                    Cache data hit count 646318362
                                    Slowest loop: 2.08ms; fastest: 0.07ms
                                    I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
                                    Hiccups: 0, FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                                    Bed compensation in use: none
                                    === MainDDARing ===
                                    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                                    === AuxDDARing ===
                                    Heater 1 is on, I-accum = 0.0
                                    Segments left: 0, aux move: no
                                    Movement lock held by null
                                    http is idle in state(s) 0
                                    telnet is idle in state(s) 0
                                    file is idle in state(s) 0
                                    serial is idle in state(s) 0
                                    aux is idle in state(s) 0
                                    daemon is idle in state(s) 0
                                    queue is idle in state(s) 0
                                    Code queue is empty.
                                    === Network ===
                                    Slowest loop: 15.44ms; fastest: 0.00ms
                                    HTTP sessions: 1 of 8
                                    • WiFi -
                                      Network state is running
                                      WiFi firmware version 1.23
                                      WiFi MAC address 24:a1:60:2f:8c:06
                                      WiFi Vcc 3.33, reset reason Turned on by main processor
                                      WiFi flash size 4194304, free heap 23648
                                      WiFi IP address 172.20.10.2
                                      WiFi signal strength -65dBm, reconnections 0, sleep mode modem
                                    M98 P"config.g"
                                    HTTP is enabled on port 80
                                    FTP is disabled
                                    TELNET is disabled
                                    Warning: M308 command is not supported
                                    Warning: M950 command is not supported
                                      Your config is trying to use the command syntax for RRF3 but you only have RRF2 installed. I suggest you update.
                                      If you still have access to DWC. Upload these 3 zip files, one at a time in the system tab. Don't extract them. Reboot after each. Use M115 to verify the firmware has been applied.
                                      https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
                                      https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/Duet2and3Firmware-3.2.zip
                                      That will get your firmware and DWC up to date.
                                      For your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3.
                                      https://configtool.reprapfirmware.org/Start
                                      • Jagofletch
                                        If anybody else is reading this and having the same troubles I will be back to post my methods for getting everything working. At the moment I have had some troubles with upgrading from 2.x to 3.x, that's now sorted, but it has messed with my configuration. Some of the axis don't respond, the probe still doesn't register and the axis that do work are reversed (even reversing the direction in config.g doesn't solve the issue). I have a few weeks of freelance work before I can get back to it.
