    Firmware 1.19RC5 released - last chance to report issues
    Firmware installation
    17
    73
    8.2k
    • JoeBoneundefined
      JoeBone
      Odd homing behavior with Height Map active.
      Firmware Name: RepRapFirmware for Duet WiFi
      Firmware Electronics: Duet WiFi 1.0
      Firmware Version: 1.19RC5 (2017-08-07)
      WiFi Server Version: 1.19beta10
      Web Interface Version: 1.17+2
      Machine homes correctly multiple times, as soon as I load the Height Map the machine lifts up on Z and either stops or it's moving VERY slowly. I placed my hand on the screw and it seems to be just slightly rotating.. almost impossible to tell.
      ; homeall.g
      ; called to home all axes
      ; Author: S. Halbrader
      ; Date: 5/16/2017
      ; Relative positioning
      G91
      ; Lift Z
      G1 Z10 F6000
      ; Course home X and Y
      G1 X-1005 Y-1005 F4500 S1
      ; Move away from the endstops
      G1 X5 Y5 F6000
      ; Fine home X and Y
      G1 X-1005 Y-1005 F360 S1
      ; Course home Z
      G1 Z-505 F2500 S1
      ; Lift Z
      G1 Z2 F2800
      ; Fine home Z
      G1 Z-505 F360 S1
      ; Absolute positioning
      G90
      • Kulitorumundefined
        Kulitorum
        Should I remind you that this worked in previous releases and RCs?
        Checking with RC4
          Kulitorum
          RC4 exhibits same problem.
          RC3 exhibits same problem.
          RC2 exhibits same problem.
          19beta11 works as expected.
          I don't have RC1 on hand.
            I have just released 1.19 RC6. Kulitorum and Joe in particular, please test this version to see whether it fixes the issues you reported. Also please upgrade DWC.
            Please note the following significant change in behaviour since RC5 and all previous releases:
            The behaviour of the R parameter in G1 commands has changed. Previously, G1 R1 with no additional parameters restored the head position for all axes to the values just prior to the last pause command, and G1 R2 with no additional parameters restored the head position for all axes to the values just prior to the last tool change. The behaviour now is that only axes that are mentioned in the G1 command have their values restored. So instead of using G1 R1 in resume.g to restore the head position, you must now use G1 R1 X0 Y0 Z0. As before, any non-zero axis parameters will be added to the saved position of that axis. This change has been made so that additional axes used as substitute X and Y axis are not automatically restored.
              Kulitorum
              Will check in an hour.
                Kulitorum
                Yep, works so far, on my IDEX machine. I will test on my rotating nozzle machine tomorrow morning.
                • nytundefined
                  nyt
                  @dc42:
                  The extrusion rate varies greatly between adjacent moves. This forces the extruder to slow down between them to adjust the extrusion rate, hence the stuttering. I guess we could detect ridiculously short moves and throw them away, but I don't see it as our job to compensate for stupid gcode generated by buggy slicers. Please file a bug report with S3D.
                  Increasing allowed extruder jerk and/or acceleration may reduce the stuttering.
                  Reported to S3d.
                  • martinbogoundefined
                    martinbogo
                    I seem to be having issues with WiFi Configuration:
                    SENT: M552 S1
                    READ: ok
                    READ: WiFi module started
                    READ: WiFi reported error: no known networks found
                    READ: Wifi module is idle
                    I updated the WiFi Server, as well as the firmware. I can't seem to get back to a point where I can configure the SSID.
                      martinbogo
                      Got it working .. had to write the SSID & password twice, then it started working again.
                      mDNS isn't working properly… no more going to [ndisname.local] anymore. OTOH, not a big deal.
                        Use M550 in config.g to set the machine name, because that forms the basis of the mdns name in firmware 1.19.
                          Kulitorum
                          FYI, my rotating head printer is also running fine with RC6, so it seems all my problems have been solved.
                          Thank you for all your hard work 🙂
                          Kulitorum
                            Thanks for the feedback! Looks like we can release 1.19 at last.
                            • JoeBoneundefined
                              JoeBone
                              Homing issue is fixed.
                              Thanks DC!
                              • JoeBoneundefined
                                JoeBone
                                I just noticed a problem with the Pause / Cancel / Resume buttons on the PanelDue.
                                I can pause a print, but I cannot cancel or resume it from the screen.
                                  @JoeBone:
                                  Strange, I just tested it, and it works for me. What version of PanelDue firmware are you running? Can you reproduce the problem?
                                  • JoeBoneundefined
                                    JoeBone
                                    firmware is 1.16
                                    Yes, it is repeatable. I didn't even think about the firmware.. I bet that's it.
                                      1.16 is current.
                                      • Eddiieundefined
                                        Eddiie
                                        I cancel print jobs from the panel due all the time.
                                        It works.
                                        • Eddiieundefined
                                          Eddiie
                                          I have noticed an issue that has existed for some time but just confirmed it really does exist….
                                          Power on, run Auto Delta Calibration from the panel due - the button.
                                          Now run it again.
                                          The second time seems to honor the dive height whereas on the first run it sort-of does. I mean, I have recently had to set my dive depth to 10m, which takes forever to complete a pass, but without 10m set the IR probe goes wonky between probe points.
                                          This is a change from 7mm I had set in earlier firmware releases.
                                          The first pass does not go 10mm dive height, the second does. I know this because the first pass completes is about 3/4 the time the second pass does.
                                          M558 P1 X0 Z0 H10
                                          Granted, I may need to dial my Z height in (again). First run result is something like 6.778 second and future calibrations ar 0.091 or so. Still, I seem to recall this pattern for quite awhile, maybe since an early beta.
                                          My current settings (heh):
                                          M92 X100 Y100 Z100 E150:150:150:95:95:95:95 ; Set axis steps/mm
                                          M665 R88 L215 B100 H355.00 ; tweaking height
                                          G31 X0 Y0 Z2.704 P500 ; Set the zprobe height and threshold (put your own values here) - for Z, bigger number means closer to bed
                                          Can someone with a delta and a ir probe double check what I am saying??
                                            Yes, it sounds to me that you need to adjust your M665 parameters in config.g to the values you get after running auto calibration twice. Or you can use M500 to write them to config-override.g.
