    Firmware 1.19RC5 released - last chance to report issues
    Firmware installation
    17
    73
    8.2k
    • Neotkoundefined
      Neotko
      Today tried to update to the final 1.19 I seen on the github.
      I still can't find a way to connect to my router. I followed every single step and still can't put my router info on the N587, it has only letters and numbers caps and minus, but nothing special. I can't figure out how to insert my router wifi on this 1.19
      But if I run my SetNetwork macro, it doesn't work, and it doesn't even write it on the M588 list. I'm really lost on what to do.
      I suppose the old adhock method of configuring it is out of the table right?
      Things I did:
      • Follow step by step to the letter. bins are updated and all ok.
      • Printrun connect to the duet3d by usb.
      • Executed the network macro with my Router info
      • I do a M98 P/macros/NET and I get a
        Wifi module started
      • I do a M587 to check the networks and I get
        "No remembered networks"
      So… I'm truly lost
      I can manually insert a fake M587 S"ONODUET" P"WOCAWOCA"
      I also did a M588 S"*" to check and I can remove the fake info, but the macro doesn't feed the data to the network list.
      Is there any MANUAL way to edit this? I really can't care les about security if it's something that can be done by usb. I just want to connect and use the new version 😄
      It's there ANY way to set caps/minus directly by USB connection? Because when I do that manually the fake info goes in. And I really CANT change the modem password to something simple, that would defeat the pourpose of this extra security of now having the adhoc now? Dunno...
      Any suggestions??
      BTW for MAC users. If you guys edit the TXT files with TexEdit, remember to DISABLE automatic Quotation marks or it will change the " to the writters style, killing the macro info.
      • Neotkoundefined
        Neotko
        @Neotko:
        Things I did:
          Wifi module started
        So… I'm truly lost
        Any suggestions??
        Ok all fixed.. Nothing like taking a break to check everything again. I was using M589 on the macro… So dumb me. Working, connected, super!
        Btw the MAC user thing, that did happen to me for 1h and I was lost as hell until I noticed that the TextEdit was changing the " with the Writter style ", and that was so dumb too.
        Thanks for the great Duet3D firmware!
        • MrBlomundefined
          MrBlom
          with out reading all pages
          i just want to say
          the z-offset is not 100%
          it only works when z-hop i active and is not calculated on first move
          at least it like that for me
          for example when using (-minus values in g10) it drags to nozzle to place then it activates the offset
          i by pass this by adding a move down in the post/free files
          i can make a video if you like ?<
          _–---------------
          Firmware Name: RepRapFirmware for Duet WiFi
          Firmware Electronics: Duet WiFi 1.0
          Firmware Version: 1.19beta11 (2017-07-25)
          WiFi Server Version: 1.19beta10
          Web Interface Version: 1.17+2
            You need to activate the tool before the first G1 move is executed, then the offset will be applied to that move.
            • Neotkoundefined
              Neotko
              My first impressions after updating to the 1.19 is that the wifi is way more unstable than before. I can't get the connection stable and I have to turn off/on the machine to get access back. What can be done to make it more stable? With the 1.18 latest version it was working quite nicely for the last months.
              For example. Launched a print (after turning it off/on to get access back). Then now that the print has finish I tried to get access again but even the ping gives 'Host is down'.
              • T3P3Tonyundefined
                T3P3Tony administrators
                Neotko the WiFi web server was changed between 1.18 and 1.19. what sort of WiFi issues are you getting?
                www.duet3d.com
                • Neotkoundefined
                  Neotko
                  @T3P3Tony:
                  The service disappears, so I cant connect to the ip of the printer. Even doing pings the service shows that's down.
                  So before 1.18 sometimes the service went off, but only after launching a print. Now with 1.19 the connection disappears suddenly.
                  I'll test changing my router settings to see if it's something related to that, but it's weird. Will do more tests to see if remains unstable or get's back to normal.
                    Someone else reported that the connection was unstable when they configured the router to use channel 1 or 2, but they had much better results on channel 6. I don't know whether this was due to their local circumstances or not.
                    With firmware 1.19, the M122 diagnostic report includes the received WiFi signal strength (RSSI). See http://www.metageek.com/training/resources/understanding-rssi.html for a description of RSSI.
                    If you do lose the connection and you have a PanelDue or USB connection, sending M552 S0 followed by M552 S1 may get it back again.
                    • Neotkoundefined
                      Neotko
                      Weird and weird. Changing to channel 6, rather than the auto made a huge difference. Will keep testing but seems that that’s. Ofc I did test resetting the router before changing that.
                      The weird part imo is that before 1.19 was working ok.
                      Anyway very glad with the update the webcontrol 1.19 works much faster.
                      • Jareryundefined
                        Jarery
                        Perhaps I just did something wrong or in wrong order, but I dropped the duetWifi Firmware onto the webbowser update files section, it updated, and now I get "Wifi module started Error:failed to initialize wifi module, code -10"
                        Typing M551 S0 M552 S1 isn't starting it.
                        Can you link me to a wiki page or other instructions for fixing ?
                        Never mind, found the instructions here https://www.duet3d.com/forum/thread.php?id=2290#p21818
                          Sounds like you didn't do the simultaneous update of the main firmware and the WiFi firmware. So you will have to copy the WiFi firmware to the SD card on a PC instead, then install it using M997 S1.
                          • Jareryundefined
                            Jarery
                            Good deduction skills, that was my error exactly, I've now fixed it and am redoing the height map.
                            Sorry to bother you 🙂
                              I'm closing this thread now. Anyone still using a 1.19 beta or RC, please update to the 1.19 release and report any related issues in the thread about that release.
