    Firmware 1.19RC5 released - last chance to report issues
    Firmware installation
    17
    73
    8.2k
      @Kulitorum:
      Also, any positive movement with my U axis, with S1 defined ignores any F data and just runs at full speed. RC5
      Can you confirm that you have a space character in the command string immediately before the letter F ?
      • DjDemonDundefined
        DjDemonD
        I don't know if it helps but the issue I reported under RC1 (in that thread) on my corexy with the duet board crashing and trying to send information to the USB was still happening earlier today. I upgraded to RC5 and it is working normally. Many thanks for all the hard work.
        www.precisionpiezo.co.uk
          Thanks for the feedback! Good to know that it is fixed.
          • Kulitorumundefined
            Kulitorum
            Yes, there is a space.
            U at 211:
            G1 U300 F100 S1
            https://www.youtube.com/watch?v=Zy6cDdJbkhY
            • sigxcpuundefined
              sigxcpu
              @dc42:
              @sigxcpu:
              OK, I am ready to try again 1.19, but I fail to find "the important upgrade notes". There are references in "what's new" page, but there is no actual link.
              Upgrade notes are always in the WHATS_NEW file in the root of my RepRapFirmware github repository, as linked to in the first post in this thread. If you look past the list of new features (which is rather long for this release) and the list of bug fixes, you will find the upgrade notes.
              That is what happens when you read the first two paragraphs of that huge page 🙂
              Did the upgrade, everything looks fine. No real print yet (CoreXY 300x300x300)
                @Kulitorum:
                U at 211:
                G1 U300 F100 S1
                I still can't reproduce this. Please can you give me the exact sequence you are using from power on to make this happen.
                There are a few things not quite right with your config and homing files, although I don't think they are relevant to this issue, but please try them anyway:
                • In your M574 command in config.g you should have U2 not U1 because the U endstop is at the high end
                • In your M208 S0 command the U parameter should be the point at which the endstop switch triggers
                • The G1 S1 commands in your homing files should be executed in relative mode. For example, homex.g:
                ; homex.g
                ; called to home the X axis
                ; generated by RepRapFirmware Configuration Tool on Wed May 17 2017 18:05:05 GMT+0200 (Romance Daylight Time)
                ; Lift Z relative to current position
                G91
                G1 Z1 F6000
                ; Move quickly to X axis endstop and stop there (first pass)
                G1 X-255 F3000 S1
                ; Go back a few mm
                G1 X5 F3000
                ; Move slowly to X axis endstop once more (second pass)
                G1 X-10 F360 S1
                ; Lower Z again
                G1 Z-1 F6000
                G90
                Homeu.g:
                ; homeu.g
                ; called to home the U axis
                G91
                G1 Z1 F6000
                G1 U370 F6000 S1
                ; Go back a few mm
                G1 U-5 F6000
                G1 U10 F360 S1
                ; Lower Z again
                G1 Z-1 F6000
                G90
                [Edited the above to make somie corrections to homeu.g]
                You don't need the G92 commands as long as you have set the U axis maximum in your M208 command to the point at which the switch triggers.
                Also the zip file you provided had an old version of iap4e.bin in it.
                  Kulitorum
                  I applied your changes, and it made no difference.
                  So I made a test.gcode file with one line:
                  G1 U400 F2000 S1 ; test
                  And when I "Emergency stop" and print that file, it runs at full speed.
                  But when I "Emergency stop" and paste the same line "G1 U400 F2000 S1 ; test" into "Send Gcode" field in the top left of the web interface, it runs at the requested speed.
                  Until I press "-100" for the U axis (executes correctly) and then press "Send" again - then it runs at too high speed.
                  I hope this makes sense.
                  • chrishammundefined
                    chrishamm administrators
                    To those testing this firmware release: I have just pushed DWC 1.19-RC1 to my GitHub repository, see https://github.com/chrishamm/DuetWebControl/tree/dev
                    If you decide to try it out and find any bugs, please report them here or open a new issue on my GitHub page.
                    Duet software engineer
                      Kulitorum
                      Chrishamm, I installed it, and so far it works fine. Where can I find a "What's new" file?
                        @Kulitorum:
                        I don't include a "Whats new" file with my DWC releases yet, but you can find all the changes in the commit message on GitHub: https://github.com/chrishamm/DuetWebControl/commit/fa10a75ab8b9003d3faced9c9d2db448ad150a62
                        0 chrishamm committed to chrishamm/DuetWebControl
                        Version 1.19-RC1
                        Added message box controls for XY axes
                        Implemented new "Mix" option on the extrude/retract panel
                        Bug fix: After reconnecting the active message box was not displayed
                        Bug fix: Sometimes the current tool was not underlined
                        Bug fix: ABC axes weren't displayed properly
                        • whosrdaddyundefined
                          whosrdaddy
                          @Chrishamm, did you see my pull request?
                          I added dutch translation for DWC.
                          Will crosscheck with 1.19 to see if additional strings have been added.
                            @Kulitorum:
                            Thanks, I've just tried that but I still can't reproduce the problem.
                            Please can you do one more thing. Connect the Duet to a PC running Pronterface or similar over USB. Set up the printer ready to exhibit the problem. Send M111 S1 P4 and M111 S1 P6 to enable full movement debugging. Then run the G1 U400 F2000 S1 to cause the incorrect speed issue. Paste the debug output (DDA and DM info) that appears in Pronterface here.
                              Kulitorum
                              Sorry for the late reply, I had some problems getting USB to work and I had to downgrade to 19b11 and then back to RC5 to make the USB port work again.
                              Here you go - it's a bit long, but I include all of it for completeness.
                              To provoke the error, I just turn on the machine and print test2.gcode. that file contains one line, pasted here:
                              G1 U400 F2000 S1 ; Executes correct. Sets U pos to 314.5 when done (max U coord)
                              I hope this helps.
                              PS: The buttplug.gcode is not really a buttplug 🙂
                              23:41:31.668 : No start signal detected - forcing start
                              23:41:31.673 : RepRapFirmware for Duet WiFi Version 1.19RC5 dated 2017-08-07
                              23:41:31.673 : Executing config.g…Attempt to emulate unsupported firmware.
                              23:41:31.673 : FTP is enabled on port 21
                              23:41:31.673 : Done!
                              23:41:31.673 : RepRapFirmware for Duet WiFi is up and running.
                              23:41:31.673 : WiFi module started
                              23:41:31.673 : Wifi module is connected to access point Internet, IP address 192.168.1.180
                              23:41:31.682 : FIRMWARE_NAME: RepRapFirmware for Duet WiFi FIRMWARE_VERSION: 1.19RC5 ELECTRONICS: Duet WiFi 1.0 + DueX5 FIRMWARE_DATE: 2017-08-07
                              23:41:31.688 : X: 0.000 Y: 0.000 Z: -0.048 U: 0.000 E0: 0.0 E1: 0.0 E2: 0.0 E3: 0.0 E4: 0.0 E5: 0.0 E6: 0.0 E7: 0.0 Count 0 0 0 0 User 0.0 0.0 0.0 0.0
                              23:41:31.688 : serial: N6 T060
                              23:41:31.691 : Heater 1 switched on
                              23:41:31.694 : serial: N7 M20
                              22
                              23:41:31.703 : Begin file list
                              23:41:31.703 : HollowDodecahedron.gcode
                              23:41:31.703 : TestPrint.gcode
                              23:41:31.703 : octagon-test-delta.gcode
                              23:41:31.703 : setheight.gcode
                              23:41:31.703 : EscherLizard.gcode
                              23:41:31.703 : BletClamps
                              23:41:31.703 : Calibration.gcode
                              23:41:31.703 : UnitTriangle.gcode
                              23:41:31.703 : 7_inch_PanelDue_screen_holder.3.gcode
                              23:41:31.703 : Button.gcode
                              23:41:31.703 : Wire Clamp Test With Spring.gcode
                              23:41:31.703 : Extruderparts_FanMounts_V01.gcode
                              23:41:31.703 : UnitBox.gcode
                              23:41:31.703 : UntiSquares.factory
                              23:41:31.703 : Ooze spring mounts.gcode
                              23:41:31.703 : AM3_BeltClamps.gcode
                              23:41:31.703 : Z-motor-standoff.gcode
                              23:41:31.703 : AM3Wifi_3DBenchy_Dual.gcode
                              23:41:31.703 : CircleGrid.gcode
                              23:41:31.703 : 20mmUnitBox.gcode
                              23:41:31.703 : Sorteringskasse.gcode
                              23:41:31.703 : Sorteringskasse_Head1.gcode
                              23:41:31.703 : RadiusTest_Head1.gcode
                              23:41:31.703 : RadiusTest_Head2.gcode
                              23:41:31.703 : roundedbox.gcode
                              23:41:31.703 : 8x4-wire clamp with spring loose.gcode
                              23:41:31.703 : 8x3-wire clamp with spring loose.gcode
                              23:41:31.703 : 8x10 coupler.gcode
                              23:41:31.703 : Gasket.gcode
                              23:41:31.704 : RocketForMegaScaling_rot.gcode
                              23:41:31.704 : 6mm_standoff.gcode
                              23:41:31.704 : ButtPlug_rot_rot.gcode
                              23:41:31.704 : test-wall_rot.gcode
                              23:41:31.704 : 20mm box.gcode
                              23:41:31.704 : Z-motor-standoffs-48mm.gcode
                              23:41:31.704 : IdlerSpacer.gcode
                              23:41:31.704 : y-belt-tightners.gcode
                              23:41:31.704 : 2color 4x20mm box.gcode
                              23:41:31.704 : nozzle.3.gcode
                              23:41:31.704 : 20mm box2.gcode
                              23:41:31.704 : 20mm box3.gcode
                              23:41:31.704 : test.gcode
                              23:41:31.704 : 20mm box4.gcode
                              23:41:31.704 : DC42Test.gcode
                              23:41:31.704 : test2.gcode
                              23:41:31.704 : End file list
                              23:41:31.706 : serial: N8 M111 S6111
                              23:41:31.709 : serial: N9 T0
                              51
                              23:41:31.712 : serial: N10 M8042
                              23:41:31.715 : serial: N11 M105
                              23
                              23:41:32.286 : New conn on socket 0 for local port 80
                              23:41:32.287 : HTTP connection accepted
                              23:41:32.288 : Found responder
                              23:41:32.289 : Received 394 bytes
                              23:41:32.292 : Sending reply, file = no
                              23:41:32.293 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:32.313 : New conn on socket 0 for local port 80
                              23:41:32.314 : HTTP connection accepted
                              23:41:32.315 : Found responder
                              23:41:32.316 : Received 362 bytes
                              23:41:32.317 : Sending reply, file = no
                              23:41:32.318 : HTTP req, command words { GET /rr_reply HTTP/1.1 }, parameters { }
                              23:41:32.318 : Sending G-Code reply to client 1 of 1 (length 21)
                              23:41:33.292 : New conn on socket 0 for local port 80
                              23:41:33.293 : HTTP connection accepted
                              23:41:33.294 : Found responder
                              23:41:33.295 : Received 394 bytes
                              23:41:33.298 : Sending reply, file = no
                              23:41:33.299 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:34.317 : New conn on socket 0 for local port 80
                              23:41:34.318 : HTTP connection accepted
                              23:41:34.319 : Found responder
                              23:41:34.320 : Received 394 bytes
                              23:41:34.323 : Sending reply, file = no
                              23:41:34.324 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:34.689 : serial: N12 M10520
                              23:41:35.343 : New conn on socket 0 for local port 80
                              23:41:35.344 : HTTP connection accepted
                              23:41:35.345 : Found responder
                              23:41:35.346 : Received 394 bytes
                              23:41:35.349 : Sending reply, file = no
                              23:41:35.350 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:36.285 : New conn on socket 0 for local port 80
                              23:41:36.285 : HTTP connection accepted
                              23:41:36.287 : Found responder
                              23:41:36.287 : Received 394 bytes
                              23:41:36.291 : Sending reply, file = no
                              23:41:36.292 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=2 }
                              23:41:36.497 : serial: N13 M111 P4 S1
                              22
                              23:41:36.499 : Debugging enabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) ?(12)
                              23:41:36.499 : Debugging disabled for modules:
                              23:41:37.288 : New conn on socket 0 for local port 80
                              23:41:37.289 : HTTP connection accepted
                              23:41:37.290 : Found responder
                              23:41:37.291 : Received 394 bytes
                              23:41:37.294 : Sending reply, file = no
                              23:41:37.295 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:37.310 : New conn on socket 0 for local port 80
                              23:41:37.311 : HTTP connection accepted
                              23:41:37.312 : Found responder
                              23:41:37.313 : Received 362 bytes
                              23:41:37.314 : Sending reply, file = no
                              23:41:37.315 : HTTP req, command words { GET /rr_reply HTTP/1.1 }, parameters { }
                              23:41:37.315 : Sending G-Code reply to client 1 of 1 (length 203)
                              23:41:37.748 : serial: N14 M10518
                              23:41:38.286 : New conn on socket 0 for local port 80
                              23:41:38.287 : HTTP connection accepted
                              23:41:38.288 : Found responder
                              23:41:38.289 : Received 394 bytes
                              23:41:38.292 : Sending reply, file = no
                              23:41:38.293 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:39.285 : New conn on socket 0 for local port 80
                              23:41:39.286 : HTTP connection accepted
                              23:41:39.287 : Found responder
                              23:41:39.288 : Received 394 bytes
                              23:41:39.292 : Sending reply, file = no
                              23:41:39.293 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:40.321 : New conn on socket 0 for local port 80
                              23:41:40.322 : HTTP connection accepted
                              23:41:40.323 : Found responder
                              23:41:40.324 : Received 394 bytes
                              23:41:40.327 : Sending reply, file = no
                              23:41:40.328 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:40.810 : serial: N15 M105
                              19
                              23:41:41.284 : New conn on socket 0 for local port 80
                              23:41:41.285 : HTTP connection accepted
                              23:41:41.286 : Found responder
                              23:41:41.287 : Received 394 bytes
                              23:41:41.290 : Sending reply, file = no
                              23:41:41.291 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:42.286 : New conn on socket 0 for local port 80
                              23:41:42.287 : HTTP connection accepted
                              23:41:42.288 : Found responder
                              23:41:42.289 : Received 394 bytes
                              23:41:42.292 : Sending reply, file = no
                              23:41:42.293 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:42.439 : serial: N16 M111 P6 S117
                              23:41:42.441 : Debugging enabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) ?(12)
                              23:41:42.441 : Debugging disabled for modules:
                              23:41:43.285 : New conn on socket 0 for local port 80
                              23:41:43.286 : HTTP connection accepted
                              23:41:43.287 : Found responder
                              23:41:43.288 : Received 394 bytes
                              23:41:43.291 : Sending reply, file = no
                              23:41:43.292 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:43.309 : New conn on socket 0 for local port 80
                              23:41:43.310 : HTTP connection accepted
                              23:41:43.311 : Found responder
                              23:41:43.312 : Received 362 bytes
                              23:41:43.313 : Sending reply, file = no
                              23:41:43.314 : HTTP req, command words { GET /rr_reply HTTP/1.1 }, parameters { }
                              23:41:43.314 : Sending G-Code reply to client 1 of 1 (length 203)
                              23:41:43.874 : serial: N17 M105
                              17
                              23:41:44.291 : New conn on socket 0 for local port 80
                              23:41:44.292 : HTTP connection accepted
                              23:41:44.293 : Found responder
                              23:41:44.294 : Received 394 bytes
                              23:41:44.297 : Sending reply, file = no
                              23:41:44.298 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:44.690 : New conn on socket 0 for local port 80
                              23:41:44.690 : HTTP connection accepted
                              23:41:44.692 : Found responder
                              23:41:44.692 : Received 394 bytes
                              23:41:44.696 : Sending reply, file = no
                              23:41:44.697 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:45.010 : New conn on socket 0 for local port 80
                              23:41:45.011 : HTTP connection accepted
                              23:41:45.012 : Found responder
                              23:41:45.013 : Received 394 bytes
                              23:41:45.017 : Sending reply, file = no
                              23:41:45.018 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=2 }
                              23:41:45.311 : New conn on socket 0 for local port 80
                              23:41:45.311 : HTTP connection accepted
                              23:41:45.312 : Found responder
                              23:41:45.313 : Received 394 bytes
                              23:41:45.317 : Sending reply, file = no
                              23:41:45.318 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:45.593 : New conn on socket 0 for local port 80
                              23:41:45.594 : HTTP connection accepted
                              23:41:45.595 : Found responder
                              23:41:45.596 : Received 394 bytes
                              23:41:45.599 : Sending reply, file = no
                              23:41:45.600 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:45.881 : New conn on socket 0 for local port 80
                              23:41:45.882 : HTTP connection accepted
                              23:41:45.883 : Found responder
                              23:41:45.884 : Received 394 bytes
                              23:41:45.887 : Sending reply, file = no
                              23:41:45.888 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:46.175 : New conn on socket 0 for local port 80
                              23:41:46.176 : HTTP connection accepted
                              23:41:46.177 : Found responder
                              23:41:46.178 : Received 394 bytes
                              23:41:46.181 : Sending reply, file = no
                              23:41:46.182 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:46.464 : New conn on socket 0 for local port 80
                              23:41:46.465 : HTTP connection accepted
                              23:41:46.466 : Found responder
                              23:41:46.467 : Received 394 bytes
                              23:41:46.470 : Sending reply, file = no
                              23:41:46.471 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:46.754 : New conn on socket 0 for local port 80
                              23:41:46.755 : HTTP connection accepted
                              23:41:46.756 : Found responder
                              23:41:46.757 : Received 394 bytes
                              23:41:46.760 : Sending reply, file = no
                              23:41:46.761 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:46.934 : serial: N18 M10530
                              23:41:47.043 : New conn on socket 0 for local port 80
                              23:41:47.043 : HTTP connection accepted
                              23:41:47.045 : Found responder
                              23:41:47.045 : Received 394 bytes
                              23:41:47.049 : Sending reply, file = no
                              23:41:47.050 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:47.331 : New conn on socket 0 for local port 80
                              23:41:47.331 : HTTP connection accepted
                              23:41:47.332 : Found responder
                              23:41:47.334 : Received 394 bytes
                              23:41:47.337 : Sending reply, file = no
                              23:41:47.338 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:47.621 : New conn on socket 0 for local port 80
                              23:41:47.622 : HTTP connection accepted
                              23:41:47.623 : Found responder
                              23:41:47.624 : Received 394 bytes
                              23:41:47.627 : Sending reply, file = no
                              23:41:47.628 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:47.923 : New conn on socket 0 for local port 80
                              23:41:47.924 : HTTP connection accepted
                              23:41:47.925 : Found responder
                              23:41:47.926 : Received 394 bytes
                              23:41:47.930 : Sending reply, file = no
                              23:41:47.931 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=2 }
                              23:41:48.235 : New conn on socket 0 for local port 80
                              23:41:48.236 : HTTP connection accepted
                              23:41:48.237 : Found responder
                              23:41:48.238 : Received 394 bytes
                              23:41:48.241 : Sending reply, file = no
                              23:41:48.242 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:48.583 : New conn on socket 0 for local port 80
                              23:41:48.584 : HTTP connection accepted
                              23:41:48.585 : Found responder
                              23:41:48.586 : Received 394 bytes
                              23:41:48.589 : Sending reply, file = no
                              23:41:48.590 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:48.959 : New conn on socket 0 for local port 80
                              23:41:48.960 : HTTP connection accepted
                              23:41:48.961 : Found responder
                              23:41:48.962 : Received 394 bytes
                              23:41:48.965 : Sending reply, file = no
                              23:41:48.966 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:49.247 : New conn on socket 0 for local port 80
                              23:41:49.248 : HTTP connection accepted
                              23:41:49.249 : Found responder
                              23:41:49.250 : Received 394 bytes
                              23:41:49.252 : Sending reply, file = no
                              23:41:49.254 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:49.542 : New conn on socket 0 for local port 80
                              23:41:49.543 : HTTP connection accepted
                              23:41:49.544 : Found responder
                              23:41:49.545 : Received 394 bytes
                              23:41:49.548 : Sending reply, file = no
                              23:41:49.549 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:49.826 : New conn on socket 0 for local port 80
                              23:41:49.826 : HTTP connection accepted
                              23:41:49.827 : Found responder
                              23:41:49.829 : Received 394 bytes
                              23:41:49.832 : Sending reply, file = no
                              23:41:49.833 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:49.999 : serial: N19 M105
                              31
                              23:41:50.108 : New conn on socket 0 for local port 80
                              23:41:50.109 : HTTP connection accepted
                              23:41:50.110 : Found responder
                              23:41:50.111 : Received 394 bytes
                              23:41:50.114 : Sending reply, file = no
                              23:41:50.115 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:50.392 : New conn on socket 0 for local port 80
                              23:41:50.393 : HTTP connection accepted
                              23:41:50.394 : Found responder
                              23:41:50.395 : Received 394 bytes
                              23:41:50.399 : Sending reply, file = no
                              23:41:50.399 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:50.678 : New conn on socket 0 for local port 80
                              23:41:50.679 : HTTP connection accepted
                              23:41:50.680 : Found responder
                              23:41:50.681 : Received 394 bytes
                              23:41:50.684 : Sending reply, file = no
                              23:41:50.685 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:50.970 : New conn on socket 0 for local port 80
                              23:41:50.971 : HTTP connection accepted
                              23:41:50.972 : Found responder
                              23:41:50.973 : Received 394 bytes
                              23:41:50.977 : Sending reply, file = no
                              23:41:50.978 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=2 }
                              23:41:51.259 : New conn on socket 0 for local port 80
                              23:41:51.260 : HTTP connection accepted
                              23:41:51.261 : Found responder
                              23:41:51.262 : Received 394 bytes
                              23:41:51.265 : Sending reply, file = no
                              23:41:51.266 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:51.546 : New conn on socket 0 for local port 80
                              23:41:51.547 : HTTP connection accepted
                              23:41:51.548 : Found responder
                              23:41:51.549 : Received 394 bytes
                              23:41:51.552 : Sending reply, file = no
                              23:41:51.553 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:51.840 : New conn on socket 0 for local port 80
                              23:41:51.841 : HTTP connection accepted
                              23:41:51.842 : Found responder
                              23:41:51.843 : Received 394 bytes
                              23:41:51.846 : Sending reply, file = no
                              23:41:51.847 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:52.128 : New conn on socket 0 for local port 80
                              23:41:52.129 : HTTP connection accepted
                              23:41:52.130 : Found responder
                              23:41:52.131 : Received 394 bytes
                              23:41:52.134 : Sending reply, file = no
                              23:41:52.135 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:52.308 : New conn on socket 0 for local port 80
                              23:41:52.309 : HTTP connection accepted
                              23:41:52.310 : Found responder
                              23:41:52.311 : Received 410 bytes
                              23:41:52.312 : Sending reply, file = no
                              23:41:52.313 : http: M32 test2.gcode
                              23:41:52.314 : HTTP req, command words { GET /rr_gcode HTTP/1.1 }, parameters { gcode=M32 test2.gcode }
                              23:41:52.339 : -- Parsing file test2.gcode --
                              23:41:52.339 : Header complete, processed 83 bytes, read time 0.001s, parse time 0.000s
                              23:41:52.339 : Footer complete, processed 4096 bytes, read time 0.000s, parse time 0.001s, seek time 0.000s
                              23:41:52.339 : file: G1 U400 F2000 S1
                              23:41:52.340 : Transformed 0.00 0.00 -0.05 to 0 0 -77
                              23:41:52.351 : DDA: d=0.048000 vec=[0.000000 0.000000 -1.000000 8333.333984 0.000000]
                              23:41:52.352 : a=0.360000 reqv=0.500000 topv=0.131453 startv=0.000000 endv=0.000000
                              23:41:52.352 : daccel=0.024000 ddecel=0.024000 cks=684653
                              23:41:52.353 : DMZ: dir=B steps=77 next=1 rev=78 interval=55170 sstcda=0 acmadtcdts=171163 tstcdapdsc=684652 2dtstc2diva=234374600548
                              23:41:52.353 : accelStopStep=39 decelStartStep=39 2CsqtMmPerStepDivA=3043831552
                              23:41:52.354 : mmPerStepTimesCdivtopSpeed=4552499 fmsdmtstdca2=0
                              23:41:52.354 : DMU: dir=F steps=32000 next=1 rev=32001 interval=2706 sstcda=0 acmadtcdts=171163 tstcdapdsc=684652 2dtstc2diva=234374600548
                              23:41:52.356 : accelStopStep=16001 decelStartStep=16001 2CsqtMmPerStepDivA=7324218
                              23:41:52.356 : mmPerStepTimesCdivtopSpeed=10954 fmsdmtstdca2=0
                              23:41:52.416 : New conn on socket 0 for local port 80
                              23:41:52.417 : HTTP connection accepted
                              23:41:52.418 : Found responder
                              23:41:52.419 : Received 394 bytes
                              23:41:52.423 : Sending reply, file = no
                              23:41:52.424 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:52.441 : New conn on socket 0 for local port 80
                              23:41:52.442 : HTTP connection accepted
                              23:41:52.443 : Found responder
                              23:41:52.444 : Received 389 bytes
                              23:41:52.445 : HTTP req, command words { GET /rr_fileinfo HTTP/1.1 }, parameters { }
                              23:41:52.446 : Sending reply, file = no
                              23:41:52.487 : New conn on socket 0 for local port 80
                              23:41:52.488 : HTTP connection accepted
                              23:41:52.489 : Found responder
                              23:41:52.490 : Received 362 bytes
                              23:41:52.491 : Sending reply, file = no
                              23:41:52.492 : HTTP req, command words { GET /rr_reply HTTP/1.1 }, parameters { }
                              23:41:52.492 : Sending G-Code reply to client 1 of 1 (length 39)
                              23:41:52.754 : New conn on socket 0 for local port 80
                              23:41:52.755 : HTTP connection accepted
                              23:41:52.756 : Found responder
                              23:41:52.757 : Received 394 bytes
                              23:41:52.761 : Sending reply, file = no
                              23:41:52.762 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=3 }
                              23:41:53.046 : New conn on socket 0 for local port 80
                              23:41:53.047 : HTTP connection accepted
                              23:41:53.048 : Found responder
                              23:41:53.049 : Received 394 bytes
                              23:41:53.054 : Sending reply, file = no
                              23:41:53.055 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=3 }
                              23:41:53.062 : serial: N20 M10521
                              23:41:53.112 : Done printing file
                              23:41:53.112 : – Parsing file test2.gcode --
                              23:41:53.112 : Header complete, processed 83 bytes, read time 0.000s, parse time 0.001s
                              23:41:53.112 : Footer complete, processed 4096 bytes, read time 0.000s, parse time 0.000s, seek time 0.000s
                              23:41:53.334 : New conn on socket 0 for local port 80
                              23:41:53.335 : HTTP connection accepted
                              23:41:53.336 : Found responder
                              23:41:53.337 : Received 394 bytes
                              23:41:53.341 : Sending reply, file = no
                              23:41:53.342 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=3 }
                              23:41:53.356 : New conn on socket 0 for local port 80
                              23:41:53.357 : HTTP connection accepted
                              23:41:53.358 : Found responder
                              23:41:53.359 : Received 362 bytes
                              23:41:53.360 : Sending reply, file = no
                              23:41:53.361 : HTTP req, command words { GET /rr_reply HTTP/1.1 }, parameters { }
                              23:41:53.361 : Sending G-Code reply to client 1 of 1 (length 19)
                              23:41:53.624 : New conn on socket 0 for local port 80
                              23:41:53.625 : HTTP connection accepted
                              23:41:53.626 : Found responder
                              23:41:53.627 : Received 394 bytes
                              23:41:53.630 : Sending reply, file = no
                              23:41:53.631 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:53.905 : New conn on socket 0 for local port 80
                              23:41:53.907 : HTTP connection accepted
                              23:41:53.907 : Found responder
                              23:41:53.908 : Received 394 bytes
                              23:41:53.913 : Sending reply, file = no
                              23:41:53.913 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=2 }
                              23:41:54.199 : New conn on socket 0 for local port 80
                              23:41:54.200 : HTTP connection accepted
                              23:41:54.201 : Found responder
                              23:41:54.202 : Received 394 bytes
                              23:41:54.205 : Sending reply, file = no
                              23:41:54.206 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:54.482 : New conn on socket 0 for local port 80
                              23:41:54.483 : HTTP connection accepted
                              23:41:54.484 : Found responder
                              23:41:54.485 : Received 394 bytes
                              23:41:54.488 : Sending reply, file = no
                              23:41:54.489 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:54.765 : New conn on socket 0 for local port 80
                              23:41:54.766 : HTTP connection accepted
                              23:41:54.767 : Found responder
                              23:41:54.768 : Received 394 bytes
                              23:41:54.771 : Sending reply, file = no
                              23:41:54.772 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:55.056 : New conn on socket 0 for local port 80
                              23:41:55.057 : HTTP connection accepted
                              23:41:55.058 : Found responder
                              23:41:55.059 : Received 394 bytes
                              23:41:55.062 : Sending reply, file = no
                              23:41:55.063 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:55.339 : New conn on socket 0 for local port 80
                              23:41:55.340 : HTTP connection accepted
                              23:41:55.341 : Found responder
                              23:41:55.342 : Received 394 bytes
                              23:41:55.345 : Sending reply, file = no
                              23:41:55.346 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:55.628 : New conn on socket 0 for local port 80
                              23:41:55.628 : HTTP connection accepted
                              23:41:55.629 : Found responder
                              23:41:55.630 : Received 394 bytes
                              23:41:55.633 : Sending reply, file = no
                              23:41:55.634 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:55.922 : New conn on socket 0 for local port 80
                              23:41:55.923 : HTTP connection accepted
                              23:41:55.924 : Found responder
                              23:41:55.925 : Received 394 bytes
                              23:41:55.928 : Sending reply, file = no
                              23:41:55.929 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:56.128 : serial: N21 M105
                              20
                              23:41:56.211 : New conn on socket 0 for local port 80
                              23:41:56.212 : HTTP connection accepted
                              23:41:56.213 : Found responder
                              23:41:56.214 : Received 394 bytes
                              23:41:56.217 : Sending reply, file = no
                              23:41:56.218 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:56.499 : New conn on socket 0 for local port 80
                              23:41:56.500 : HTTP connection accepted
                              23:41:56.500 : Found responder
                              23:41:56.501 : Received 394 bytes
                              23:41:56.505 : Sending reply, file = no
                              23:41:56.506 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
                              23:41:56.791 : New conn on socket 0 for local port 80
                              23:41:56.792 : HTTP connection accepted
                              23:41:56.793 : Found responder
                              23:41:56.794 : Received 394 bytes
                              23:41:56.798 : Sending reply, file = no
                              23:41:56.799 : HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=2 }
                                You must have entered the wrong M111 command, because you appear to have enabled all debugging instead of just Move and DDA debugging. But the info I wanted appears in the middle of it anyway. I can see what is happening: there is a small Z movement as well as the U movement, and I think the requested speed is being applied to just the Z component. Do you have a bed height map loaded, or any other form of bed or axis compensation applied?
                                • nytundefined
                                  nyt
                                  I reported a stuttering bug on github when pressure advance is enabled. It seemed to only happen on a skirt generated by s3d 4.0, but was quite strange. I assume it can happen in other scenarios.
                                    Kulitorum
                                    I copy-pasted your M111 commands.
                                    Yes, I am using grid autoleveling.
                                    Michael
                                      @nyt:
                                      The stuttering is caused by S3D generating strange gcode. Here is an example:
                                      G1 X203.690 Y182.089 E0.0139
                                      G1 X203.694 Y182.089 E0.0001
                                      G1 X204.940 Y182.306 E0.0525
                                      G1 X204.943 Y182.307 E0.0001
                                      G1 X205.241 Y182.368 E0.0126
                                      G1 X205.244 Y182.368 E0.0001
                                      G1 X206.364 Y182.633 E0.0477
                                      G1 X206.367 Y182.634 E0.0001
                                      G1 X206.683 Y182.720 E0.0135
                                      G1 X206.686 Y182.721 E0.0001
                                      Notice how every alternate move has an extrusion distance of just 0.0001. Transposed to a spreadsheet:
                                      X Y E XY distance extrusion/distance
                                      203.690 182.089 0.0139
                                      203.694 182.089 0.0001 0.004 5.49E-07
                                      204.940 182.306 0.0525 1.265 2.88E-04
                                      204.943 182.307 0.0001 0.003 5.49E-07
                                      205.241 182.368 0.0126 0.304 6.91E-05
                                      205.244 182.368 0.0001 0.003 5.48E-07
                                      206.364 182.633 0.0477 1.151 2.61E-04
                                      206.367 182.634 0.0001 0.003 5.48E-07
                                      206.683 182.720 0.0135 0.327 7.39E-05
                                      206.686 182.721 0.0001 0.003 5.47E-07
                                      The extrusion rate varies greatly between adjacent moves. This forces the extruder to slow down between them to adjust the extrusion rate, hence the stuttering. I guess we could detect ridiculously short moves and throw them away, but I don't see it as our job to compensate for stupid gcode generated by buggy slicers. Please file a bug report with S3D.
                                      Increasing allowed extruder jerk and/or acceleration may reduce the stuttering.
                                        @Kulitorum:
                                        Michael
                                        I guess you used Repetier host, because it enables full debug output by default when you connect, and I can see that you entered the correct debugging commands later in the session.
                                        I see now that you have G29 S1 in config.g. That explains why we get different behaviour. I am using a bench setup to simulate your system, so I have no heightmap.csv file. Now that I can see what is happening, it should be easy to fix. I just need to make sure that I don't upset the behaviour for users who use the U axis as an additional axis instead of a substitute X axis.
                                        I'll look at your report regarding G1 R2 as well.
                                        Thanks for all the feedback you are providing and the tests you are running, and for your patience.
                                          Kulitorum
                                          One of my other printers use the U axis as an additional axis (head rotation) so if you release a new RC, I can test that too.
                                          And thank you!
                                            After some discussion with other users (I can't remember if you were one of them), the specification of what the feed rate does was changed to:
                                            1. If there is any XYZ movement, then the F parameter relates to the combined XYZ speed, and any other axes have their speeds chosen to match that.
                                            2. Otherwise, the F parameter relates to the combined movement in hypercube space of all the motors that are moving. [An alternative choice wild have been to make it apply to the one that is moving the most.]
                                            When the U axis is used as a substitute X axis, then U movement counts as X movement in the above.
                                            What's happening in this case is that the bed compensation is causing #1 to be applied, when you want #2.
                                            Here are some possible solutions:
                                            A. Change definition #1 above to be "If there is any XY movement, then the F parameter relates to the combined XY speed, and any other axes have their speeds chosen to match that." The problem with this is that a pure Z movement may have a small XY component added if axis compensation is enabled, which would cause the Z speed to be wrong.
                                            B. Change specification #1 above to be "If there is any XY movement, then the F parameter relates to the combined XYZ speed, and any other axes have their speeds chosen to match that." I think this might work.
                                            C. Keep track of whether the movement of each axis was commanded by the user or was added by bed or axis compensation, and stick with the original specification except that XYZ movement not commanded by the user doesn't count in deciding whether to use #1 or #2.
                                            D. Add a configuration option to specify that a particular axis (in this case U) should be treated as an X axis when deciding on what the F parameter means.
                                            One thing that is puzzling me: as the U axis is not being treated as an X axis in this particular case, why is bed compensation being applied? Looks like I need to investigate some more.
