    Error: bad Command XXX W/RRF 3.2 and leveling issue
    147
    10.3k
    • martin7404undefined
      martin7404
      Here is the beginning of the code
      ; generated by PrusaSlicer 2.3.0+win64 on 2021-02-17 at 12:32:24 UTC
      ; external perimeters extrusion width = 0.45mm
      ; perimeters extrusion width = 0.45mm
      ; infill extrusion width = 0.45mm
      ; solid infill extrusion width = 0.45mm
      ; top infill extrusion width = 0.40mm
      ; first layer extrusion width = 0.42mm
      M107
      ;TYPE:Custom
      M140 S90 ; set bed temp
      G10 P1 R240 S260 ; set standby and active temps for tool 1
      T1 P0 ; shortly activate tool 1 so that it goes to standby temp afterwards
      T-1 P0 ; deselect any tool
      G28 Y ; home Y axis
      G28 XU ; home X and U axis
      M190 S90 ; wait for bed temp
      G28 Z ; bed probing and leveling
      G29 S1 ; call saved bed shape map
      T1 ; select tool 1
      M116 P1 ; wait tool 1 active temp
      G1 X135 Y-3 F8000 ; move above prime line start position
      G1 Z0.25 ; get close to bed
      G92 E0.0 ; reset extruder position
      G1 X235 E22 F1000.0 ; prime line with first tool
      M221 S95 D1
      G21 ; set units to millimeters
      G90 ; use absolute coordinates
      M83 ; use relative distances for extrusion
      ;LAYER_CHANGE
      ;Z:0.3
      ;HEIGHT:0.3
      G1 Z0.300 F10800.000
      G1 E-0.60000 F2400.000
      G1 Z0.700 F10800.000
      G1 X198.287 Y128.383
      G1 Z0.300
      G1 E0.60000 F2400.000
      M204 S1000
      ;TYPE:Skirt
      ;WIDTH:0.42
      G1 F1124.798
      G1 X199.050 Y127.844 E0.04350
      G1 X199.959 Y127.645 E0.04333
      G1 X240.004 Y127.644 E1.86499
      G1 X240.884 Y127.817 E0.04177
      G1 X241.633 Y128.303 E0.04160
      Muldex IDEX Duet2+Duex5
      Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
      Sapphire Pro with Duet2, with closed-loop motors
      custom high temp E3D tool changer with Duet2+Duex
      3DPrintingWorldundefined 1 Reply Last reply Reply Quote 0
      • 3DPrintingWorldundefined
        3DPrintingWorld @martin7404
        @martin7404 Should the offset be negative instead of positive? Sorry I'm not sure which one is longer, or shorter.
        martin7404undefined 1 Reply Last reply Reply Quote 0
          martin7404
          I am not quite sure, but in manual, I do tool change and on 10.5 Z my gauge is spot on. I tested the right extruder month ago, but with changing the system ofset. When negative it is not right. Looking at e3d tool changer it is negative, you might be right
            martin7404 @3DPrintingWorld
            @3DPrintingWorld The V6 is shorter, otherwise, I would make them equal in Z. I hate that thing with tools and the Z shown on the screen since old Fanuc millnig CNC controls. Exactly why for tooling work I do not use length compensation and just switch the WCS (G54 , G55 etc) for each tool
              @martin7404 Yeah, I think you would have a hard time trying to find 2.5mm to remove from the height. When I switched from the nimble to the BMG I really fought to keep the extruder as low to the bearing as I could.
                @3DPrintingWorld The problem for me is that there is no info how duet handles tool offsets I made it successfully on Dual lifting hotends but it was on PRF 2.5 and the moving extruder was longer
                  @martin7404 According to this you change the offset of T1. This tells me that the number can be positive or negative because otherwise you would have to modify T0 offset if the number was negative.
                    martin7404
                    @3DPrintingWorld link ?
                      3DPrintingWorld
                      https://duet3d.dozuki.com/Wiki/ConfiguringMultipleIndependentXcarriagesCartesian
                        @3DPrintingWorld thank you
                        I still do not see what I am doing wrong
                          @martin7404 so making it a negative number didn't help?
                            @3DPrintingWorld I am remote to the printer 😉 IT is in the shop and I am at home and I am afraid to test it on the camera
                              @martin7404 To be safe you could change it to a negative on the T1 offset then add 2.55mm to your T0 probe offset.
                                @3DPrintingWorld I am printing it now with 5 mm offset from the slicer
                                  @martin7404 Got it! You are doing it differently but I just wanted to clear up what I said, to add to the probe height you would actually have to subtract.
                                    martin7404
                                    YES and I canceled it , because slicer offset do not affect the priming
                                      martin7404
                                      IT is working, showing 0.3 on the DWS screen. IT is in the air , but I can not tell from the camera
                                        martin7404
                                        I did check one of my backups of the settings a month ago the offset for tool 1 was - and then testing it in manual with panel due I did switch it in some moment
                                          @martin7404 That explains it!
                                          Last night I erased the firmware a reloaded 3.1.1 and I still have all the same issues..... I must be missing something somewhere.
                                            martin7404
                                            V3.22 now it shows correct height but prints in the air.
                                            Now testing with positive offset.
                                            Installed 2nd camera as far I have to go home
                                            One more thing on simulation it shows normal heights with positive offset and with printing shows layer+offset
