    [SOLVED] Can't connect to Duet 3 mini 5+ after firmware upgrade
    • pkosundefined
      pkos
      So it seems like my problems never end 😉
      I was working on configuring a CoreXZ printer today and I noticed some weird behavior when moving on the Z axis (seems as if movement is multiplied by 10).
      I thought it might be just the firmware, so I tried updating it. I downloaded the package (zip file with all Duet2 and 3 firmwares) and uploaded it via DWC.
      I was asked if I want to update, I clicked yes, and then, the board stopped and never came back up. The Status led is flashing red at about 1Hz.
      I tried replacing the files on the SD card - nothing.
      I tried connecting to the board with YAT and Bossa - not possible. They both immediately complain that they can't connect.
      I tried switching over to Mac and trying either screen or SerialTools - I can connect, but I am not getting any responses from the board. I tried Bossa for Mac - I can connect to the board, get info on the chip, but when I try to upload the uf2 file - I get an error telling me memory is exceeded) - and I can't connect the boot to flash option.
      When I connect the board to Windows - I can see for a moment - DuetBOOT appears and I have three files there (current.uf2, .html file that redirects to the Duet web site and info_uf2.txt).
      It appears in the device manager just fine for about 20 seconds and then disappears.
      Seems to be the same on the Mac. I tried copying the files over from DuetBOOT, but can't - I get a disconnection message almost immediately.
      Any tips/hints on how to bring the board back from the dead?
      Voron 2.4 (Duet 3 6HC + 3HC standalone), Voron SW (Duet 3 mini 5+ standalone), Voron Trident (Duet 3 mini 5+ standalone), Voron 0.1
        jay_s_uk @pkos
        @pkos here you go https://duet3d.dozuki.com/Wiki/Duet_3_Mini_5plus_Firmware#Section_Updating_firmware_via_USB
        It doesn't use bossa
        • pkosundefined
          pkos
          Man I'm blind... That did it! Thanks 😉
