    RTSP Camera Stream instead of mjpeg?
    Duet Web Control
    • toddelundefined
      toddel
      Hi.
      I have a hard time to find a small wifi cam for my Duet... Mostly they only have Rtsp stream but no mjpeg or they are expensive...
      So is there maybe a plugin to integrate the rtsp stream? I have a Tapo C100...
        Not that I'm aware of and from what I gather browsers no longer even allow RTSP streams.
        My suggestion is a Raspberry Pi Zero W and camera module running MotionOS.
        • stuartofmtundefined
          stuartofmt
          As @Phaedrux says, it would likely be quicker and cheaper to go the Pi Zero route. I have found that motionOS can be a bit heavy and use lots of CPU although this does seem to vary a lot between users. I had that experience and instead use this as a lightweight streaming solution with the Pi camera. Of course - I run other things on the Pi. If you are just using it for serving up images then it will not matter.
          http://picamera.readthedocs.io/en/latest/recipes2.html#web-streaming
          Another alternative is an RTSP to MJPEG "converter". Depending on your platform, programing experience, and tolerance for time (noting that almost nothing works as described in google searches 🙂 ) - something like one of these approaches may be interesting.
          https://stackoverflow.com/questions/43953966/rtsp-to-http-mjpeg-transcoding-embedded-in-website
          https://gist.github.com/n3wtron/4624820
