Duet3 KiCad library
I just forked the Duet3 project to tweak it to my needs :- Replacing VH connectors with XH ones (VH does not play well with common 26AWG wiring of small steppers)
- Probably removing unused hardware to gain some space
- Cram in some 12V to 24V 4A boost converter
- Probably beef up 5V rail and add protection on some extension ports to protect against servo-motors feeding back this rail.
I appreciate the github repo with the KiCad sources, but I failed to locate the Duet3 library used for parts. Can I get help with this library ?
Thanks
No one ? Does the Duet team not want to share the component library ? Or is it already shared and I am blind ?
apologies, I have added it to the Github Repository:
https://github.com/Duet3D/Duet3-Mainboard-6HC/tree/master/Duet3_Mainboard_v1.01/CAD
No worries, and thanks a lot !
This works perfect as soon as the lib is added to the project specific symbol libraries
