bl touch
  • having trouble getting two different errors
    one is zprobe won't deploy and other is driver disconnected rrf 3.2 duet 1.04 Configuration file for
    also when I try mesh leveling carriage goes violently to side than front etc
    Duet WiFi (firmware version 3)
    ; generated by RepRapFirmware Configuration Tool v3.2.2 on Sat Feb 06 2021 08:39:37 GMT-0800 (Pacific Standard Time)
    M550 P"My Printer" ; set printer name
    M669 K1 ; select CoreXY mode
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S1 ; enable FTP
    M586 P2 S1 ; enable Telnet
    M569 P3 S0 ; physical drive 3 goes backwards
    M92 X80.00 Y80.00 Z415.00 E420.00 ; set steps per mm
    M566 X1800.00 Y1800.00 Z120.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X18000.00 Y18000.00 Z600.00 E1200.00 ; set maximum speeds (mm/min)
    M201 X3000.00 Y3000.00 Z500.00 E10000.00 ; set accelerations (mm/s^2)
    M906 X950 Y950 Z950 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X300 Y300 Z350 S0 ; set axis maxima
    M574 Z1 S2 ; Define Z to use Probe. Home to Min
    ;Z-Probe
    M307 H7 A-1 C-1 D-1 ; Disable Heater 7 for use with BLTouch
    M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
    M558 P9 C"^zprobe.in" H5 F120 T12000 ; set Z probe type to bltouch and the dive height +
    G31 P500 X2 Y20 Z2.5 ; set Z probe trigger value, offset and trigger height
    M557 X15:280 Y15:280 S20 ; define mesh grid
    Heaters
    M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
    M307 H0 B0 S0 ; disable bang-bang mode for the bed heater and set PWM limit
    M143 H1 S320 ; set temperature limit for heater 1 to 320C
    M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
    M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
    M563 P0 S"Dragon " D0 H1 F0:1 ; define tool 0
    ; Custom settings
    m552 s1
  • @bks31 said in bl touch:
    this is not valid in rrf3
    B4138 is incorrect. find the correct value in your thermistor documentation.
    you did not post your deploy script.
    what does that mean?
    does normal movement work ok?
    did you acutally update to rrf3 ?
  • Moderator
    You've set a travel speed between probe points of 200mm/s which is a bit high. That could explain the violence.
  • @Phaedrux yes that makes sense and sorry for the ill-informed post I was at work and trying to remember what errors I was getting last night what info do you need
  • @Veti yeah the true value is actually in my config.override the only two things in there is the PID tuned for h1 and h2 didn't seem the need to post that since I was at inquiring about the BL touch and z homing
    what true value?
  • @Veti my bad sorry I was working and confused but somehow when I got home i must of switched my config file or something but everything was off got everythimg homing right and got bed heater and sensor working but heater is showing -273 °c I changed the thermistor checking for a short but that's the the case I ran a m98 and says missing p paramater not sure where tho but what should my h1 look like ; Configuration file for Duet WiFi (firmware version 3)
    ; generated by RepRapFirmware Configuration Tool v3.2.2 on Fri Feb 12 2021 23:35:01 GMT-0800 (Pacific Standard Time)
    M566 X18000.00 Y9000.00 Z300.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X36000.00 Y36000.00 Z600.00 E1200.00 ; set maximum speeds (mm/min)
    M201 X5000.00 Y5000.00 Z250.00 E10000.00 ; set accelerations (mm/s^2)
    M906 X1200 Y1200 Z1200 E1200 I30 ; set motor currents (mA) and motor idle factor in per cent
    M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop
    G31 P500 X0 Y40 Z2.5 ; set Z probe trigger value, offset and trigger height
    M556 S50 X0 Y0 Z0 ; set orthogonal axis compensation parameters
    M557 X15:300 Y15:215 S20 ; define mesh grid
    M308 S1 P"e1temp" Y"thermistor" T100000 B4092 C220 ; configure sensor 1 as thermistor on pin e1temp
    M143 H1 S325 ; set temperature limit for heater 1 to 325C
    ; Custom settings
    m552 s1
    m98
    M98 P"config.g"
    i dont know what you are referring to.
  • @Veti my heater config you said earlier b value doesn't belong trying to get my heater #1 for hotend not to fault
  • i said the beta value is incorrect.
    that is not for the heater but for the thermistor. the temperature measuring device.
    the beta values is used to determine the actual temperature.
    if you have a wrong value, the actual temperature will differ from the one displayed
  • @Veti yea I get that but wouldn't that cause for my heater to throw error code sorry let me clarify what would be the correct parameter for my hot end thermistor because temp shows -273
    find the correct value in the thermistor documentation
  • that file is protected
  • please link to the actual amazon page.
    maybe its in the description
  • its written in the details
    Negative Temperature Coefficient (NTC) Thermistor Model: B3950
