Grid Compensation only for a few layers ?
Hello, is there a possibility to use the grid compensation only for a certain height and then, for example, to let slowly weaken from 3mm or possibly switch off directly ? under my old repetier firmware this was possible. in the docu I found nothing about it. Thank you for the feedback
Compensation Taper: https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation#Section_Compensation_Taper
Super, thanks for the hint. I somehow overlooked or misinterpreted this
