capacitive sensors PNP (NC) 10-24V for endstops on a Duet Wifi
are those really 10k and 68k resistors?
the colours dont match the ones i find online -
@Veti said in capacitive sensors PNP (NC) 10-24V for endstops on a Duet Wifi:
the colours dont match the ones i find online10k from GND to STP and 56K to Signal of the sensor
the wiki says 10k and 68K
i dont know what you are trying to tell me with that picture.
If R2 is 10K, then suitable values of R1 are 30K if the sensor is powered from +12V, and 68K if it is powered from +24V.
nowhere does it mention 56k resistors
I misunderstood, I think you mean the resistor I took is 68K.
Yes I also tested a 68K resistor, same problem. With the 68K I measured 2,95V untriggered.
@Gerd said in capacitive sensors PNP (NC) 10-24V for endstops on a Duet Wifi:
and triggerd?
and triggerd?
a few mV
that should be interpreted as 0 and 1
yes it should, but it didn't
since its high on untriggered you might not need the pull up resistor.
try without the ^
try without the ^
Yes I also tried with the pullup resistor
I'll stop for today.
Thank you for your help and your patience!
Gerd
If the connection between the two resistors measures one value and the pin measures another value there must be a problem in the connection from the resistors to the pin contact.
Here is how I do this:
You could do what I did when I had a proximity sensor, I used a 24v relay module. The sensor would trigger it and I used the relay output.
@Stephen6309 said in capacitive sensors PNP (NC) 10-24V for endstops on a Duet Wifi:
Interesting.
I would have thought the relay would have introduced an unacceptable delay.
@fcwilt I didn't on mine, since the Z axis not going fast enough to matter.
After some more frustrating tries I gave up and used some microswitches to complete the printer.
Would the situation with the PNP sensors be better with a Duet 3 board?
Gerd
Gerd
So you could not find a combination of resistors that yield the required logic levels?
Did you have the ^ character in the pin name? You definitely would not want that.
While the various sensors I tested needed different values/arrangement of resistors but I was able to get them all working.
@fcwilt said in capacitive sensors PNP (NC) 10-24V for endstops on a Duet Wifi:
Gerd
@fcwilt Frederick, would you like to test such an igus sensor? I could send you one.
