capacitive sensors PNP (NC) 10-24V for endstops on a Duet Wifi
@Veti said in capacitive sensors PNP (NC) 10-24V for endstops on a Duet Wifi:
that should be interpreted as 0 and 1
yes it should, but it didn't
since its high on untriggered you might not need the pull up resistor.
try without the ^
try without the ^
Yes I also tried with the pullup resistor
I'll stop for today.
Thank you for your help and your patience!
Gerd
@Gerd said in capacitive sensors PNP (NC) 10-24V for endstops on a Duet Wifi:
If the connection between the two resistors measures one value and the pin measures another value there must be a problem in the connection from the resistors to the pin contact.
Here is how I do this:
You could do what I did when I had a proximity sensor, I used a 24v relay module. The sensor would trigger it and I used the relay output.
@Stephen6309 said in capacitive sensors PNP (NC) 10-24V for endstops on a Duet Wifi:
Interesting.
I would have thought the relay would have introduced an unacceptable delay.
@fcwilt I didn't on mine, since the Z axis not going fast enough to matter.
After some more frustrating tries I gave up and used some microswitches to complete the printer.
Would the situation with the PNP sensors be better with a Duet 3 board?
Gerd
Gerd
So you could not find a combination of resistors that yield the required logic levels?
Did you have the ^ character in the pin name? You definitely would not want that.
While the various sensors I tested needed different values/arrangement of resistors but I was able to get them all working.
@fcwilt said in capacitive sensors PNP (NC) 10-24V for endstops on a Duet Wifi:
Gerd
@fcwilt Frederick, would you like to test such an igus sensor? I could send you one.
What is a igus sensor?
I will be glad to test it and add it to my list.
https://www.igus.com/product/17829
Frederik, could you please send me your postal address?
Gerd
