SOLVED 3.3Beta1 reverse to 3.2.2
Hi, i have install the 3.3.1 but as i can't access files through the web page, i wanted to revert to 3.2.2 as it was working as intended but, i can't find how.
If i upload previous version, it didn't install it, i tried putting the files directly in firmware folder and update with M997 S0 but not working too..
Is there a way to revert to 3.2.2 ?
Are you getting any error messages?
Try uploading the full zip file for 3.2.2
https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/Duet2and3Firmware-3.2.2.zip
No error message, it's even telling that it's installing the update but nothing change.
I think M997 don't take the file in the firmware folder yet so i'm a bit stuck now
The web control don't upload to firmware folder yet i think as it's 3.2.2.
If it don't install the combined bin, I don't think the zip will make it, i'll still try.
@Phaedrux I was wrong, you were right, the Zip worked ! Thanks !
Did you read the 3.3beta1 upgrade notes?
@dc42 Yes I've read it, especially duet2 related, i wanted to try if the problem i have with filament-error routine is still here as it is in 3.2.2, but i'll wait finally wait until 3.3 have the matching DWC.
@Krohm-Koala said in 3.3Beta1 reverse to 3.2.2:
The bit you may have missed is the bit telling you that you need to upload the new IAP file too.
@dc42 Oh yes, missed it
my bad, it helps to give the access to the firmware folder through the DWC ?
DWC 3.x was already prepared for the change in location of the firmware files, but the IAP binaries were not.
@dc42 Okay thanks
make sense
