Network Port Not Working
I'm not sure how the config tool gave a standby temp of 170. I'm unable to duplicate that and as far as I can find there is no way to set it. Setting a temp or moving a motor in config.g is bad practice. Are you sure it came from the config tool?
@GoremanX said in Network Port Not Working:
Perhaps this could be prevented by changing the firmware so that the network comes up as soon as M540/M550/M551/M552/M586
I think the reason it's delayed is to allow time for the wifi module to initialize.
@Phaedrux I don't know how the default standby temperature got added to my config.g, I don't think it's something that RRF-config did. It's too coincidental that that's the safe-probing temperature on my larger delta printer with Duet Smart Effector, even though this printer isn't a delta. May have gotten carried over somehow (although that delta printer doesn't actually use that setting in config.g). But there's reasons to set a default standby temperature without actually wanting the hotend to be set to its standby temperature on startup.
My point is mostly that there's a myriad things in config.g that might cause initialization to be delayed or never complete, and network port initialization should not be pre-empted as a result. The network port should be powered on as soon as it's possible to do so, whether it's ethernet or wifi.
