Duet 3 mini 5 + help with Superpinda
  • Hi there
    Completely new user to the Duet platform here, is it possible to get some help connecting up and configuring my setup? So far I've read as much as I can and come up with what I think of how to connect up. I have just got a superpinda (3 wires brown = gnd blue = 5V and black = signal) but know where to connect to??
    Here's my wiring config so far, the plan shows my old panda 2 but I wont be using that obviously and not using the panel due ribbon either but not sure where to connect the 4 wire cables?
  • Hi,
    Are you asking about how to connect your probe or your PanelDue?
    The probe can go where the old one went.
    My PanelDue uses the flat cable because the dedicated connector is already there.
    Any particular reason you don't want to use the flat cable?
    Thanks.
    A PanelDue would normally be connected using the ribbon cable. However, if you want to use a 4-wire cable (for example because you need it to be longer than the ribbon cable is allowed to be), you can connect it to IO0 in the same way as on the Duet 3 MB6HC. see https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Connecting_a_PanelDue.
