    PanelDueFirmware 3.2.11 released
    PanelDue
    334
    • wilriker
      wilriker Moderator last edited by
      This is a pure bugfix release to address issues with setups having multiple fans and/or extruders assigned to multiple tools.
      Version 3.2.11
      Upgrade Notes:
      • This release is compatible with RepRapFirmware 3.2 or later.
      Limitations
      • Due to the lack of RAM this build will not run on version 1 or early version 2 PanelDue boards that use the ATSAM3S2B chip.
        • Version 1.0, 1.1 and earlier v2 PanelDue: ATSAM3S2B processor (64MHz, 32kb RAM, 128kB flash) - these are the ones that the new firmware probably won't run on.
        • Version 2 PanelDue manufactured from August 2016: ATSAM3S4B processor (64MHz, 48kb RAM, 256kb flash). Will run the new firmware, but not as fast as version 3 will.
        • Version 3 PanelDue, including all 5i and 7i: ATSAM4S4B processor, 120MHz, 64kB RAM, 256kb flash. Will run the new firmware.
      Bug fixes:
      • When multiple tools used the same extruder or fan only the first tool using it was considered
      • When multiple beds/chambers used the same heater status was only updated for the first one
      Downloads and Instructions
      Binaries can be found at https://github.com/Duet3D/PanelDueFirmware/releases/tag/3.2.11
      Flashing instructions can be found at https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update
      Manuel
      My Tool Collection
      • MartinNYHC
        MartinNYHC last edited by
        Would it be possibe to add a configuration parameter to set the baby stepping value for the Paneldue? That would be nice.
        wilriker 1 Reply Last reply Reply Quote 0
        • wilriker
          wilriker Moderator @MartinNYHC last edited by
          @MartinNYHC That's already present. Just look on the Setup tab. There you can choose from 4 different values (user-entered values are not planned but I would accept one or two further values if the available ones are totally inacceptable for you).
          Manuel
          My Tool Collection
          MartinNYHC 1 Reply Last reply Reply Quote 0
          • MartinNYHC
            MartinNYHC @wilriker last edited by
            @wilriker Ups....never recognized that 🤕 Thanks.
            • MartinNYHC
              Just recognized that there is a small typo in the README on github.
              On Linux: Run this Linux command to append it to the binary: cat PanelDue-v3-5.0-nologo.bin myimage.bin > PanelDueFirmware.bin
              should read
              On Linux: Run this Linux command to append it to the binary: cat PanelDue-v3-5.0-nologo.bin myimage.bin >> PanelDueFirmware.bin
              • wilriker
                @martinnyhc said in PanelDueFirmware 3.2.11 released:
                should read
                Actually the former command is correct because it will create a new file PanelDueFirmware.bin from the con_cat_enation of the two input files PanelDue-v3-5.0-nologo.bin and myimage.bin. The second command will work as long as there is no PanelDueFirmware.bin already present. If that is the case it would append the result to the existing file making it an invalid (and too large) firmware binary.
                Manuel
                My Tool Collection
                • MartinNYHC
                  @wilriker OMG....I just ignored the second input file 🤠
                  • wilriker
                    No worries, hardly anyone (still) uses cat for what it originally was intended (neither do I). 😁
                    Manuel
                    My Tool Collection
