    Auto Tool Height Measurement
    265
    • Terry
      Terry last edited by
      I am trying to add tool height measurement to the E3D Toolchanger using a touch-off switch on the wiper gantry.
      The idea was that the gantry (on axis V) would home to a known absolute position using the microswitch at the bottom of travel (just visible on top of the motor, by the rail).
      The tool tip would be centred using a camera and then positioned in XY over the touch switch. I was planning to use G1 V1 H4 F1000 to move the gantry in the upward direction until the switch contacted the tool, then calculate the difference between the absolute position and the calibrated Z0 to get the new tool offset.
      Unfortunately, setting a second end stop on the V axis seems to overwrite the first? Any suggestions as to how I could work around this bug, please?
      fcwilt 1 Reply Last reply Reply Quote 0
      • fcwilt
        fcwilt @Terry last edited by
        @Terry
        You can set the end stop settings as needed for each phase of the operation.
        • Veti
          Veti last edited by
          interesting concept. how is the repeatability of the button?
          Terry 1 Reply Last reply Reply Quote 0
          • Terry
            Ok, setting and resetting the endstops in the macro allows me to sense the button press but unfortunately G1 H4 doesn't do what I expected. It seems that what it does is travel until the switch is triggered and then sets the user position to the value of the move that was commanded.
            This means that I lose my original calibration and thus can't calculate a position.
            I need a way to move until a switch is triggered without any side effects?
            fcwilt 2 Replies Last reply Reply Quote 0
            • Terry
              Terry @Veti last edited by
              @Veti Not able to test yet for this specific manufacturer, but there are commercial machines that use these switches for this purpose, so I expect it to be as repeatable as a microswitch.
              • fcwilt
                @Terry said in Auto Tool Height Measurement:
                How about:
                H3 terminate the move when the endstop switch is triggered and set the axis limit to the current position, overriding the value that was set by M208.
                Then you can use M208 to put things back as they should be.
                • Terry
                  H3 appears to do the same as H4, but also changes the min travel extent value.
                  I think this maybe a bug as that isn't the expected behaviour.
                  • fcwilt
                    fcwilt @Terry last edited by fcwilt
                    If it does that it would seem to be a bug - nothing in the docs suggests it should do that.
                    What firmware version are you using?
                    I have 3.2.2 and can test that.
                    • Terry
                      Thanks. I am on 3.2.0 currently and this axis and switches are on a Duet 3 Expansion 3HC board.
                      • Terry
                        On a typical CNC platform, I would expect at least 3 triggers per axis.
                        Endstops would be min and max travel indicators and would be continuously active unless explicitly disabled so they could stop motion before a physical collision (the machine may also include emergency stop cutouts at the physical limits to cut power in a runaway controller scenario). It should be possible to detect unexpected over-travel as a result of lost steps and recover by re-homing.
                        One or more reference triggers should also exist, for accurate and efficient homing. These should be inboard of the travel limits to avoid harm to the machine during homing operations and may sit in the middle of the travel range to enable efficient re-calibration during long operations. Typically they would only be active during reference operations.
                        Endstops need to be active during homing in case the assumed start position or travel direction is wrong.
                        Single active endstop-as-home-reference is a cost-saving hack that is acceptable for a $500 3D printer but can result in injury or physical damage to the machine in larger and more powerful setups, so it would be nice if we could support best practice in the future?
                        • fcwilt
                          Could you use G60 along with G1 moves with the R parameter to obtain the desired result?
                          • fcwilt
                            You can do that with triggers. From one of my printers:
                            ; external buttons (P = pin #, T = trigger #, R = when to trigger (0 = always, 1 = printing), S = what edge (I->A = 1, A->I = 0, -1 = ignored)
                            ; --- T0 does emergency stop
                            ; --- T1 does pause (see M25)
                            ; --- T# runs macro trigger#.g
                            M950 J2 C"!^duex.e6stop"
                            M581 P2 T0 R0 S0			; does emergency stop
                            M950 J1 C"^e0stop"
                            M581 P1 T2 R0 S0			; runs trigger2 which does M999 (board reset)
                            • fcwilt
                              I think I did not understand what you were saying.
                              With G1 H4 and G1 H3 the axis is at some position when the end stop is triggered - this position should be what appears in the DWC.
                              Does that not happen?
                              • Terry
                                Terry last edited by Terry
                                With both G1 H3 and G1 H4, the machine and user positions are overwritten as soon as the switch is triggered. In absolute mode, the axis value is set equal to the destination value that was commanded in the move. In relative mode, the axis position value is set to 1.
                                So, for example, starting at machine coordinate V=50 and commanding G1 H4 V2, the axis will move towards V=2 but if the switch is pressed before it gets there, motion will stop and the current position of V will be declared to be V=2, changing the calibration.
                                • Terry
                                  Terry @fcwilt last edited by
                                  @fcwilt G60 wouldn't work because calibration is lost.
                                  • Terry
                                    @fcwilt Triggers can't stop motion in a controlled manner, so at best you can call an emergency stop and lose system calibration. This is why endstop circuitry needs to exist inside the motion control loop - the endstop triggers need to be interrupts that can cancel motion at very low latency without losing position.
                                    • fcwilt
                                      How so?
                                      If you save the current position and then return to it how does that affect calibration?
                                      • Terry
                                        G60 would store a position relative to the calibration referenced against the fixed endstop. Any move detecting the mobile endstop will cause the axis to re-reference against that position. Any subsequent G2 R would return to a saved position relative to the new calibration, so not the original absolute position in the machine framework.
                                        • fcwilt
                                          Under firmware 3.2.2 I did a H3 move.
                                          When the end stop was triggered the movement stopped and the M208 setting for Z min was updated using the Z position at the moment the end stop was triggered.
                                          How does that cause the reference for the axis to change?
                                          • Terry
                                            But did your machine and user position for that axis also change?
                                            • Terry
                                              This will only be visible if you are testing against an endstop that is different to the one you referenced from in your homing move...
                                              • Terry
                                                For clarity, I home in the positive direction (but physically downwards) for my axis and reference this as the highest axis distance. I then swap out the high end endstop for the low end endstop and probe in the negative direction (physically upwards) until the switch hits the tool.
                                                This recalibrates the axis position to the target value that was in the move command, losing the information about how far I have actually moved in the original coordinate system.
                                                • Terry
                                                  Ideally, what is needed is a generic probing command that supports motion on any axis. This would be necessary for a 3 degrees of freedom probe mounted in a spindle if you wanted to touch off on a workpiece in X, Y and Z, in any case.
                                                  • fcwilt
                                                    Different in what way?
                                                    I don't think it is possible to have more than one end stop configured at the same time for a given axis - aside from the situation where you have multiple Z steppers with an end stop for each.
                                                    I did this:
                                                    I moved Z down to 100 and issued G91 G1 H3 Z-150.
                                                    I waited a bit and triggered the end stop - it was around 47.
                                                    M208 now reported min of 47. I reset Z min with M208 Z0:240 which is correct for my printer.
                                                    Moving to 0 and the end stop was just triggered as it should be.
                                                    This I did this:
                                                    I moved Z down to 100 and issued G91 G1 H4 Z-150.
                                                    I waited a bit and triggered the end stop - it was around 53.
                                                    Nothing else appears to have changed.
                                                    • Terry
                                                      Just found G38.2, which appears to be more suitable.
                                                      After testing with
                                                      M558 K1 P8 C"!1.io2.in" F1000
                                                      G38.2 V1 P1
                                                      I get the same problem! There appears to be a bug where the machine and user positions are always updated to be equal to the requested destination move, even though the move was interrupted by an endstop or probe trigger.
