    Duet 3 mini5+ and Ender 3 Pro: "grinding" motors?
    • yosh2000
      yosh2000 last edited by
      Installed my Duet 3 mini5+ board on my ender 3 pro this week. Followed the excellent guide, thanks Jason Znack!
      I fired up and all was well...it seemed. When I homed everything, the stepper motors sounded like they were grinding. I used the web interface to move around a little, and they still made the noise? Almost like they had sand in them, that sort of noise? They did not make this sound with the OEM creality board or two other aftermarket boards I have had installed on the printer in the past. This is suggesting to me that its the duet board, my config.g or my wiring (I followed the guide and simple cut off the guides rather than recrimping).
      Since I didnt see any smoke and they were still cool, I started a short 10 minute print. It printed overall pretty good, just the motors sounded like they were grinding away the entire time?
      Any ideas? Thanks!
      Below is my config.g file if that will help diagnose:
      ; Configuration file for Duet 3 Mini 5+ (firmware version 3)
      ; generated by RepRapFirmware Configuration Tool v3.2.2 on Mon Feb 15 2021 16:02:50 GMT-0700 (Mountain Standard Time)
      M550 P"E3P" ; set printer name
      M918 P1 E4 F2000000 ; configure direct-connect display
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0.0 S0 ; physical drive 0.0 goes backwards
      M569 P0.1 S0 ; physical drive 0.1 goes backwards
      M569 P0.2 S1 ; physical drive 0.2 goes forwards
      M569 P0.3 S0 ; physical drive 0.3 goes backwards
      M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
      M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z600.00 E3600.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z200.00 E2500.00 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X235 Y235 Z260 S0 ; set axis maxima
      M574 X1 S1 P"io5.in" ; configure active-high endstop for low end on X via pin io5.in
      M574 Y1 S1 P"io6.in" ; configure active-high endstop for low end on Y via pin io6.in
      M574 Z1 S1 P"io2.in" ; configure active-high endstop for low end on Z via pin io2.in
      M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
      M557 X20:200 Y20:200 S20 ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T98801 B4185 ; configure sensor 0 as thermistor on pin temp0
      M143 H0 S80 ; set temperature limit for heater 0 to 80C
      M308 S1 P"temp1" Y"thermistor" T98801 B4185 ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
      M143 H1 S250 ; set temperature limit for heater 1 to 250C
      M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency
      M106 P0 C"PartCool" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
      M950 F1 C"out4" Q500 ; create fan 1 on pin out4 and set its frequency
      M106 P1 C"HotEnd" S1 H1:0 T45 ; set fan 1 name and value. Thermostatic control is turned on
      M950 F2 C"out5" Q500 ; create fan 2 on pin out5 and set its frequency
      M106 P2 C"CaseFan" S1 H1:0 T45 ; set fan 2 name and value. Thermostatic control is turned on
      M563 P0 S"HotEnd" D0 H1 F0 ; define tool 0
      M911 S22 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
      T0 ; select first tool
      • jay_s_uk
        jay_s_uk last edited by
        Add D3 V40 for the X Y and Z motor M569 commands
        • yosh2000
          Awesome, thanks, that seemed to fix it. I will have to look up exactly what that did so I'm educated, but it worked!
