    Duet WiFi Can't get BLTouch to work after Upgrade to FW 3.2.2
    • Protoberance
      Protoberance last edited by
      Hey Guys, i am struggling to get my bltouch working ( again ) and hope you can help.
      I configured the probe as follows :config.g
      M950 H3 C"nil"
      M558 P9 C"^zprobe.in" H5 F150 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X20.14 Y29.88 Z1.5 ; set Z probe trigger value, offset and trigger height
      M557 X30:240 Y30:260 S40 ; define mesh grid
      When i power on the printer the probe does it's POST pin down and up thing.
      But I don't get any response from M280 P0 S10
      I wired the sensor this way : acede04a-e8b7-42ab-89da-a88cbf21a20b-grafik.png
      The BLtouch is an old version with metal pin. Strange thing is, on my other printer i have the same wiring and configuration but with FW Version 3.1.1 and the probe works flawlessly.
      DIY-O-Sphere 1 Reply Last reply Reply Quote 0
      • DIY-O-Sphere
        DIY-O-Sphere @Protoberance last edited by DIY-O-Sphere
        @Protoberance
        Try switching to exp.heater7.
        Edit:
        M950 H3 C"nil"
        Is not neccesary for that release.
        (UTC+1)
        • Protoberance
          DAMN ! How should i've known 🙂 Thank you so much, the pin is moving now. Let's check if can produce a heatmap.
