Connected inductive probe directly to Z probe
  • Hi, I finally managed to hurt my Duet Ethernet 1.03. I wasn't paying attention and sent the output of an inductive probe directly into the z probe port. It still reads but not very well. I switched to the Z end stop and that seems to be working for now. Is there a benefit to the z_probe vs z_stop pin?
    Also is there a schematic around? I'm thinking I either blew a cap or caused direct damage to the micro controller. I can fix either problem, but before I go trying to figure out the board layout, I wanted to ask.
  • Hi,
    We need more information.
    Are you using a 12 or 24 volt power supply?
    Was the inductive probe a 5 volt model or a 10-30 volt model.
    I use 10-30 volt inductive sensors and they often output a signal that is just a bit less then the power feeding them.
    This might damage a Duet input - depending on board model, board version, board input.
    Duet 2 Wiring Diagram
    Duet 2 Wiring Guide+Wiring+your+Duet+2+WiFi-Ethernet/9)
  • Hi 24V power supply and a 10-30 volt probe. It put 22V directly into the Z probe port. 😞
    And of course this is the 1.03 that was not tolerant of higher voltages.
    @fcwilt said in Connected inductive probe directly to Z probe:
  • @cbusillo said in Connected inductive probe directly to Z probe:
    Here.
  • This post is deleted!
  • Link was broken.
    Fixed Here.
    Oops.
    That could be bad.
    Even if the inputs are high voltage tolerant what are the logic levels?
    I've always used a couple of resistors to get the probe outputs down to valid and safe levels. Took some testing to figure out the values needed.
  • Thank you so much for the link. Kicad source is awesome. It goes through a 10k to the MCU. Its showing a much lower static resistance on one direction. I think that usually means a bad internal diode in the package. Oh well. I'll likely just live with it on this board.
    After the mishap I added a Schottky diode and its working on the Z stop. Thanks again.
