    Checking the trigger height ; can't do step 8
    • EricE555undefined
      EricE555
      I am trying to follow https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation instructions for finding the trigger height of my probe (BLTouch). On step 8 it says to
      "Send G30 S-1 to probe the bed without resetting the Z=0 position" but when I do that, it fails with "insufficient axis homed". If I home the axis before I do it, I am no longer where I want to probe the bed AND it runs a G30 which resets my Z=0.
      What do I need to do to find my trigger height?
        jay_s_uk @EricE555
        @EricE555 if you follow the steps, you shouldn't be unhoming the axis
        i like using this macro to measure the trigger height
        ;Calibrate BL Touch trigger height
        ; When we get variables we can define one here
        ; Uncomment when ready to use
        ; var RunningTotal=0
        ; var average=0
        ; If the printer hasn't been homed, home it
        if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
          G28
        M564 S0 H0 ; Allow movement beyond limits
        if move.axes[2].machinePosition < 6 ; make sure we have probe clearance
        	G1 Z6
        M280 P0 S160 I1 ; reset BL Touch
        G4 S0.5
        M98 P"0:/sys/retractprobe.g" ; Ensure probe is retracted & reset
        G4 S0.5
        M290 R0 S0 ; clear any baby stepping
        ; Jog head to position
        M291 P"Jog nozzle to touch bed" R"Set nozzle to zero" S3 Z1
        G92 Z0
        M291 P"Press OK to begin" R"Ready?" S3;
        ; carry out 10 probes
        while iterations <= 9
        	G1 Z6
        	M400
        	if sensors.probes[0].value[0]=1000 ; if probe is in error state
        		echo "Probe in error state- resetting"
        		G4 S0.5
        		G4 S0.5
        	G30 S-1
        	M400
        	; Uncomment when variables allowed
        	; RunningTotal=RunningTotal + move.axes[2].machinePosition
        	;average=RunningTotal/(iterations+1)
        	G4 S0.5
        ; Until variables come use this
        M291 P"Check console for results and enter average value in G31 Z parameter of config.g"  R"Finished" S3
        ;When variables come uncomment this
        ;G31 Z{average}
        ;M291 P"Trigger height set to : " ^ sensors.probes[0].triggerHeight ^ " Press OK to save to config, cancel to use until restart" R"Finished" S2
        ;M500
        M564 S0 H1 ; Reset limits	                                                            ; Home Z
        • EricE555undefined
          EricE555
          Thank you for your prompt reply. I tried your script.
          When I run it I get 10 instances of "Insufficient Axes homed for bed probing" and then M292 -> Bad command: 0
          • EricE555undefined
            EricE555
            After figuring out what I did wrong, I was able to run this script.
            I had changed M84 (idle timeout) to 10 seconds because the motors make a little noise. Once I put that back to something reasonable, I had the necessary time to adjust nozzle to the bed height and then continue the script without the errors. 🙂
            Now we'll see if I can make use of this to have a good offset for the nozzle when printing.
