    IDEX Printer - And now?
    • toddel
      toddel last edited by
      Hey guys...
      i built a IDEX Printer.. .So far, so good 😉
      It has a Duet2Wifi latest FW and a DUEX5. Setup seems finished, all axis are working as they should... Printing with left Extruder is fine...
      But what now? 😄
      I read this: https://duet3d.dozuki.com/Wiki/ConfiguringMultipleIndependentXcarriagesCartesian
      But i understand - not much...
      What do i need to print
      a) mirror and
      b) copy?
      Currently i use prusaslicer. Can i use these modes there? Or a new slicer?
      Any IDEX User out there?
      Thanks a lot!!!
      G90																	; Send absolute coordinates...
      M83																	; ...but relative extruder moves
      M550 P"VCast"														; Set machine name
      M552 S1																; Enable network
      M586 P0 S1															; Enable HTTP
      M586 P1 S0															; Disable FTP
      M586 P2 S0															; Disable Telnet
      M569 P0 S0															; Drive 0 (U) goes backwards
      M569 P1 S0															; Drive 1 (X) goes forwards
      M569 P3 S0															; Drive 3 (E1) goes backwards
      M569 P4 S0															; Drive 4 (E2) goes backwards
      M569 P8 S1															; Drive 5 (Z2) goes forwards
      M569 P9 S0															; Drive 6 (Y) goes forwards
      M569 P7 S1															; Drive 7 (Z1) goes forwards
      M584 X1 U0 Y9 Z8:7 E3:4 											; Driver 3=X, 1=Y, 2+4=Z, 5+6=E0+E1
      M92 X80 Y160 Z400 U80 E823	  									; Set steps/mm
      M350 X16 Y32 Z16 U16 E32 I1											; Configure micro-stepping with interpolation for all drives
      M203 X18000 Y18000 Z18000 U18000 E3600								; Set maximum speeds (mm/min)
      M201 X500 Y500 Z100 U500 E10000										; Set accelerations (mm/s^2)
      M566 X600 Y600 Z60 U600 E1200										; Set maximum instantaneous speed changes (mm/min)
      M906 X2000 Y2000 Z2000 U2000 E500 I25								; Set motor currents (mA) and motor idle factor in per cent
      M84 S10		                                                        ; Set idle timeout
      ;PanelDue
      M575 P1 S1 B57600
      ;M208 X-51.80 Y-26.00 Z0 U5 S1										; Set axes minima
      M208 X-51.80 Y-29.00 Z0 U0 S1										; Set axes minima
      ;M208 X300 Y320 Z300 U361.20 S0										; Set axes maxima
      M208 X300 Y304 Z270 U356.20 S0										; Set axes maxima
      M574 X1 S3             						                      	; configure sensorless endstop for low end on X
      M574 U2 S3             						                      	; configure sensorless endstop for low end on X
      M574 Y1 S3                      					             	; configure sensorless endstop for low end on Y
      M574 Z1 S2                       					            	; configure Z-probe endstop for low end on Z
      ; BLTouch Z-Probe
      M574 Z1 S2															; Define Z endstop at a probe
      M558 P9 C"^zprobe.in" H10 F480 T12000 A1							; Set Z probe to BLTouch, 5mm dive at 8mm/s, 5 attempts
      M950 S0 C"duex.pwm5"												; Create a servo pin on Duex PWM5 header
      G31 P25 X-29.75 Y-14.50 Z3.77										; Set Z probe trigger value, nozzle offsets, and trigger height
      M557 X35:270 Y25:295 P7:7											; Define a 10x10 bed mesh
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 C0 R4700				; Define Sensor0 as the heated bed temperature
      M950 H0 C"bedheat" T0												; Define Heater0 as the heated bed, bind to Sensor0
      M140 H0 P0															; Define Heated Bed
      M307 H0 A378.7 C518.9 D2.3 S1.00 V24.2								; PID Tuning for Heater0 (Bed)
      M143 H0 S120														; Set temperature limit for Heater0 to 120C
      M308 S1 P"e0_temp" Y"thermistor" T100000 B4725 C7.06e-8 			; define E0 temperature sensor
      M950 H1 C"E0Heat" T1												; Define Heater0 as Extruder1 heater, bind to Sensor1
      M307 H1 A358.8 C172.6 D4.9 S1.00 V24.1								; PID Tuning for Heater1
      M143 H1 S285
      M308 S2 P"e1_temp" Y"thermistor" T100000 B4725 C7.06e-8 			; define E1 temperature sensor
      M950 H2 C"E1Heat" T2												; Define Heater1 as Extruder2 heater, bind to Sensor2
      ;M307 H2 A358.8 C172.6 D4.9 S1.00 V24.1								; PID Tuning for Heater2
      M143 H2 S285
      M950 F0 C"fan0" Q1											; Define Fan0 for T0 Part Cooling
      M106 P0 S0 H-1 C"X1 Part Cooling"									; Set Fan0 to default off, manual control
      M950 F1 C"fan1"														; Define Fan1 for T0 Hotend cooling
      M106 P1 S1 H1 T45 C"Hotend1"										; Set Fan1 to Thermostatic control, max RPM at 45C
      M950 F2 C"duex.fan3" Q1											; Define Fan0 for T0 Part Cooling
      M106 P2 S0 H-2 C"X2 Part Cooling"									; Set Fan0 to default off, manual control
      M950 F3 C"duex.fan4"												; Define Fan1 for T0 Hotend cooling
      M106 P3 S1 H2 T45 C"Hotend2"										; Set Fan1 to Thermostatic control, max RPM at 45C
      M563 P0 D1 H1 F0 S"E1"												; Tool0 uses Extruder0, Heater1 and Fan0
      M563 P1 D0 H2 X0 F2 S"E2"											; Tool1 uses Extruder1, Heater2 and Fan2. X-axis is mapped to U
      G10 P0 X0 Y0 Z0 R0 S0												; Set Tool0 axis offsets and temperatures
      G10 P1 X0 Y0 Z0 R0 S0												; Set Tool1 axis offsets and temperatures
      ; Additional Settings
      M671 X-93:393 Y150:150 S5.0											; Define Z-axis leadscrew positions for G32
      M404 N1.75															; Define filament diameter for print monitor
      T0																	; Activate T0 by default
        If you configure your IDEX printer as we suggest in that web page, then all prints will be centred at X0 Y0 and you will have four different tools corresponding to left, right, ditto and mirror modes. The only thing you need to do to switch between them is to select which tool you want in the slicer.
        Your config.g currently is not configured to centre prints at X0 Y0.
        • Rushmere3D
          Rushmere3D last edited by
          I'll be doing write up on my iDEX setup soon (maybe the weekend?) But for now follow the guidelines you linked to create your tools etc.
          Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
          • toddel
            toddel last edited by toddel
            I have it printing! Nice and sweet...
            I created a macro (PrintInCopyMode)
            M563 P2 D0:1 H1:2 X0:3 F1:1 ; tool 2 uses both extruders and hot end heaters, maps X to both X and U, and uses both print cooling fans
            G10 P2 X0 Y0 U-150 S0 R0    ; set tool offsets and temperatures for tool 2
            M567 P2 E1:1 ; set mix ratio 100% on both extruders
            I have Tool 0, 1 and then the new one here... Is it possible to delete T0 and 1 before? So i could switch between both modes...
            Edit:
            Found it:
            M563 P0 D-1 H-1
            M563 P1 D-1 H-1
            So a Macro with:
            M563 P0 D-1 H-1
            M563 P1 D-1 H-1
            M563 P0 D0:1 H1:2 X0:3 F1:1 S"CopyMode"; tool 2 uses both extruders and hot end heaters, maps X to both X and U, and uses both print cooling fans
            G10 P0 X0 Y0 U-150 S0 R0    ; set tool offsets and temperatures for tool 2
            M567 P0 E1:1 ; set mix ratio 100% on both extruders
            would create just the CopyTool with a click on this macro... Vice Versa from CopyMode to normal...
            M563 P0 D-1 H-1
            M563 P1 D-1 H-1
            M563 P2 D-1 H-1
            M563 P3 D-1 H-1
            Works as it should... Nice!
