Dual hotend cooling fan
Hi all,
With my conversion of my ultimaker 2 to Duet I ran into the issue that my hotend cooling fan only turns on when hotend 1 is above 40C. How would I configure a hotend cooling fan for two hotends (that turns on when either of them is above 40C)? Currently I use the following configuration: -
change it from H1 to H1:2 (assuming heater 2 is used on the second hot end) on line 55
Thank you! That seemed to do the trick.
