    Duet Wifi - how to set cooling fan?
    Firmware installation
    961
    • eranglrundefined
      eranglr @jay_s_uk
      @jay_s_uk My cooling fan is connected to FAN0, but when sending M106 S0 it doesn't do anything (it's always on).
        jay_s_uk
        is it always on when the sd card is not inserted into the board and then the board is powered on?
        eranglrundefined 1 Reply Last reply Reply Quote 0
          droftarts administrators @eranglr
          @eranglr You have it mapped to the tool T0 with M563 P0 D0 H1 F0. So it won't be active until the tool is active. Actually, that's not it at all!
          Check that you have connected the fan to FAN0, and not the 'Always on' pins. See the wiring diagram: https://duet3d.dozuki.com/Wiki/Duet_Wiring_Diagrams
          eranglrundefined 2 Replies Last reply Reply Quote 0
          • eranglrundefined
            eranglr @droftarts
            @droftarts connected it to FAN0 (not always on).
            The fan is always on even when I turn the duet with no SD card inside.
            • eranglrundefined
              eranglr @droftarts
              This post is deleted!
                @eranglr Can you send M122 and post the reply?
                • eranglrundefined
                  eranglr @jay_s_uk
                  @jay_s_uk yes, it is.
                  Could it be a jumper or something like that?
                  • eranglrundefined
                    eranglr @droftarts
                    @droftarts
                    M122
                    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later
                    Board ID: 08DJM-9178L-L4MSJ-6J1FL-3SN6T-TV16Q
                    Used output buffers: 3 of 24 (11 max)
                    Static ram: 23460
                    Dynamic ram: 73136 of which 40 recycled
                    Never used RAM 15444, free system stack 182 words
                    Tasks: NETWORK(ready,188) HEAT(blocked,308) MAIN(running,379) IDLE(ready,20)
                    Owned mutexes: WiFi(NETWORK)
                    Last reset 00:00:43 ago, cause: power up
                    Last software reset at 2021-02-24 17:24, reason: User, GCodes spinning, available RAM 15444, slot 1
                    Error status: 0x00
                    Aux0 errors 0,0,0
                    MCU temperature: min 35.1, current 38.2, max 38.5
                    Supply voltage: min 26.8, current 26.9, max 27.2, under voltage events: 0, over voltage events: 0, power good: yes
                    Driver 0: position 0, standstill, SG min/max not available
                    Driver 1: position 0, standstill, SG min/max not available
                    Driver 2: position 0, standstill, SG min/max not available
                    Driver 5: position 0
                    Driver 6: position 0
                    Driver 7: position 0
                    Driver 8: position 0
                    Driver 9: position 0
                    Driver 10: position 0
                    Driver 11: position 0
                    Date/time: 2021-02-24 17:40:35
                    Cache data hit count 51187488
                    Slowest loop: 4.02ms; fastest: 0.21ms
                    === Storage ===
                    Free file entries: 10
                    SD card longest read time 0.9ms, write time 0.0ms, max retries 0
                    === MainDDARing ===
                    === AuxDDARing ===
                    Segments left: 0
                    Movement lock held by null
                    HTTP is idle in state(s) 0
                    Telnet is idle in state(s) 0
                    File is idle in state(s) 0
                    USB is idle in state(s) 0
                    Aux is idle in state(s) 0
                    Trigger is idle in state(s) 0
                    Queue is idle in state(s) 0
                    LCD is idle in state(s) 0
                    Daemon is idle in state(s) 0
                    Code queue is empty.
                    === Network ===
                    Slowest loop: 16.13ms; fastest: 0.00ms
                    HTTP sessions: 1 of 8
                    • WiFi -
                      Network state is active
                      WiFi firmware version 1.23
                      WiFi MAC address bc:dd:c2:31:9f:e7
                      WiFi Vcc 3.37, reset reason Turned on by main processor
                      WiFi flash size 4194304, free heap 24208
                      WiFi IP address 192.168.202.42
                      WiFi signal strength -64dBm, mode none, reconnections 0, sleep mode modem
                      Clock register ffffffff
                      jay_s_uk @eranglr
                      @eranglr my guess is you've blown the fan mosfet.
                      Can you take a high quality close up photo of the area around the connector, specifically the area between the fan connectors and the two LCD headers
                      • eranglrundefined
                        eranglr @jay_s_uk
                        @jay_s_uk This is a brand new card, so I doubt if I blow the MOSFET.
                          jay_s_uk
                          ok then, i'll let someone else step in and support
                          • eranglrundefined
                            eranglr @jay_s_uk
                            @jay_s_uk Just for fun, where's the mosfet, and are there 3 mosfet (one for each fan)?
                              @eranglr And it would be very unlucky if it's blown all the mosfets, as he said it was the same for FAN1 and FAN2.
                              Is there any chance the fan you are using is shorting out to ground somewhere else? Is it wired directly to the fan pin, or does it go through something else?
                              The MOSFETs work on the negative side of the fan, so the fan gets +ve volts all the time, so if there is a short on the negative side, it will always be on.
                              If you can post a photo of your wiring, that may help.
                                jay_s_uk
                                • eranglrundefined
                                  eranglr @jay_s_uk
                                  @jay_s_uk Doesn't look burnt.
                                  • eranglrundefined
                                    eranglr @droftarts
                                    @droftarts The fan should be connected directly, but I'll check again to make sure.
                                    • eranglrundefined
                                      eranglr @droftarts
                                      @droftarts Well, you were right!!
                                      I connected a different fan directly and it worked perfectly.
                                      I guess that the fan minus is touching the ground somewhere.. I'll need to check where.
                                      Thank you!!
                                      droftartsundefined 1 Reply Last reply Reply Quote 1
                                        @eranglr You're welcome!
                                        • eranglrundefined
                                          eranglr @droftarts
                                          @droftarts Is there a smart solution to the wiring on my printer:
                                          I have two fans that their negative is shared.
                                          Is there a way to control the cooling fan somehow, or do I have to re-wire the fan to have an isolated ground?
                                          droftartsundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                                            @eranglr I don't really see a way. Fan polarity is important; see https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans#Section_Caution
                                            You could wire the positives together, but to switch them individually, you need the negative side connected to individual fan (or heater) MOSFETs. You may also have problems if the fans draw different current. Best to wire them separately.
